apihor Samba Member
Joined: February 22, 2015 Posts: 61 Location: Buena Park, CA
Posted: Mon Jul 05, 2021 3:44 pm Post subject: Noob Question: A/T engine to M/T Engine |
Hey Samba,
Sorry for the noob question, but I just bought an engine that came from an Automatic squareback and I am putting it in my Manual squareback . Is there anything different between the two? is there anything I need to make it work properly? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Jul 06, 2021 10:27 am Post subject: Re: Noob Question: A/T engine to M/T Engine |
I don't think there is anything to change except for the flex plate/clutch swap? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
apihor Samba Member
Posted: Tue Jul 06, 2021 10:30 am Post subject: Re: Noob Question: A/T engine to M/T Engine |
Mike Fisher wrote: |
I don't think there is anything to change except for the flex plate/clutch swap? |
Awesome thanks, that is what I was wondering... I am still waiting for the engine to be shipped. I will order a new clutch. |
galencurrington Samba Member
Joined: March 16, 2004 Posts: 426 Location: bowling green, ky
Posted: Tue Jul 06, 2021 10:36 am Post subject: Re: Noob Question: A/T engine to M/T Engine |
don't forget to buy a new main seal while you are at it. those motors are usually pretty nice on the thrust bearing not getting beat up from the clutch. _________________ "asking and getting are two different things" |
apihor Samba Member
Posted: Tue Jul 06, 2021 1:51 pm Post subject: Re: Noob Question: A/T engine to M/T Engine |
galencurrington wrote: |
don't forget to buy a new main seal while you are at it. those motors are usually pretty nice on the thrust bearing not getting beat up from the clutch. |
$5 will do, might as well replace that too |
Bobnotch Samba Member
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1963 Location: Manitowoc, WI
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Wed Oct 20, 2021 12:03 am Post subject: Re: Noob Question: A/T engine to M/T Engine |
Are there differences between the carbs on an auto and those on a manual? I'm not saying it wouldn't work, nor that you'd need to change them, but I have a feeling there is a difference.
This funky bit on the base plate of this carb is not on all type three carbs - I believe this is a type 3 feature
Dave |
KTPhil Samba Member
Posted: Wed Oct 20, 2021 9:57 am Post subject: Re: Noob Question: A/T engine to M/T Engine |
Minor trivia: The cup to close off the cam hole in the front case face area is fitted differently at the factory, depending on whether it is for a manual or automatic.
The manual cars had the cup facing inward (the flat part faces out), as all repair manuals recommend.
The automatics had it flipped so it is concave. This way that area of the case and plug could be clearanced in cases of excessive endplay, when the flex plate could hit the case or plug there.
So the "universal" approach when rebuilding is to fit the plug concave like the automatics, since it can be used on either tranny.
Now you know.
Posted: Wed Oct 20, 2021 1:54 pm Post subject: Re: Noob Question: A/T engine to M/T Engine |
bally wrote: |
Dave |
But since the OP is from the USA, he's more than likely dealing with FI, or doing a carb swap. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KTPhil Samba Member
Posted: Wed Oct 20, 2021 2:58 pm Post subject: Re: Noob Question: A/T engine to M/T Engine |
If it's FI, the automatic engines used an electric AAR; the manuals used a mechanical coil spring type. either can be fitted if the wiring is taken care of (it's there on all cars, but clipped short on manual chassis). |
bally Samba Member
Posted: Wed Oct 20, 2021 2:59 pm Post subject: Re: Noob Question: A/T engine to M/T Engine |
Good point Bob. I’d still like to know if this is a difference between auto and manual engines (I’m building an auto myself)
Dave |
Posted: Wed Oct 20, 2021 4:06 pm Post subject: Re: Noob Question: A/T engine to M/T Engine |
bally wrote: |
Dave |
The throttle linkage is different for the carburetor AT verses the fuel injection AT and it's scarce, but not critical.
I believe the springs are one thing different between them. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Thu Oct 21, 2021 11:56 am Post subject: Re: Noob Question: A/T engine to M/T Engine |
bally wrote: |
Dave |
There's a couple of little changes, and not all are related to the engine. The big difference is the vacuum modulator, as it's set for either FI or carbs, mainly due to the vacuum signal from the engine (VW says you need to change it). On my wife's 70 Fastback, we ran it for a few years with carbs (Solex 32s), then after I gathered up the bits, I converted it back to FI (still is). I never changed the Vacuum modulator or it's setting, as it was close enough for me. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
