unknown spring on floor mat
Tvättbjörn
Tvättbjörn is offline
PostPosted: Tue Jul 06, 2021 6:37 pm    Post subject: unknown spring on floor mat Reply with quote
Found it on drivers side floor mat. Where did it come from?? 9 mm long and 5 mm dia. It is pretty strong and hard to push by hand. Had only gauges removed a while back.
EasternNotch
EasternNotch is offline
PostPosted: Wed Jul 07, 2021 7:37 am    Post subject: Re: unknown spring on floor mat Reply with quote
hmm almost looks like part of a horn ring screw, but they are about double that length
-lucas
1964 Notchback
1966 Squareback
1969 Type 34 Ghia
1969 Fastback
1989 Doka AFN TDI
raygreenwood
raygreenwood is offline
PostPosted: Wed Jul 07, 2021 8:33 am    Post subject: Re: unknown spring on floor mat Reply with quote
That looks like the type of spring from the tip of the gas tank lid release pull. Is your gas tank knob in place?
Here is a thread about rebuilding/repairing the gas tank flap. Scroll down and take a look at the cable end that screws into the knob and see what you think.
https://www.thesamba.com/vw/forum/viewtopic.php?t=656055&highlight
Is that a screw or tube going through the center of that spring?
Need a better picture.
Ray
Tvättbjörn
PostPosted: Wed Jul 07, 2021 9:30 am    Post subject: Re: unknown spring on floor mat Reply with quote
Ray
I have a 67 with no gas door. No idea where it came from. Not much under the dash. Looks just like dirt inside the spring.
Bobnotch
Bobnotch is offline
PostPosted: Wed Jul 07, 2021 1:19 pm    Post subject: Re: unknown spring on floor mat Reply with quote
-lucas
That was my thought as well. I wonder if it could be part of the turn signal switch, or maybe the column lock.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
vwpieces Premium Member
vwpieces is offline
PostPosted: Wed Jul 07, 2021 2:10 pm    Post subject: Re: unknown spring on floor mat Reply with quote
Is that a brass rivet in the middle of spring?
Ask cause it looks like a wire was crimped into it and the rivet is a contact.
For what? I Dunno. But you were gluing your Ignition in another post... ??
68 BUS
83 JETTA TURBO DIESEL
83 2dr JETTA 16V
81 Turbo Diesel Jabbit
raygreenwood
PostPosted: Wed Jul 07, 2021 2:30 pm    Post subject: Re: unknown spring on floor mat Reply with quote
Yep....looks like a tube in the middle to me.
Yes.....too small for what ai was thinking and he has no gas flap system.
Still maybe a little large in diameter for one of the springs inside of a dash switch.
Hmmmmm.
Ray
Tvättbjörn
PostPosted: Wed Jul 07, 2021 4:17 pm    Post subject: Re: unknown spring on floor mat Reply with quote
Just pulled it out of the spring. It is a brown, like a plastic tube with a slot in it. It is too small for a picture.
I have not worked on that ignition switch or the turn signal yet. Untouched. No work was done on the steering column for several years. However, I did install some wiring and relay for my new electric fuel pump last week. Had the factory fuse box lowered and the left gauge removed, but nothing else was touched.
flyinglow94
flyinglow94 is offline
PostPosted: Wed Jul 07, 2021 4:37 pm    Post subject: Re: unknown spring on floor mat Reply with quote
I noticed a post of yours a couple days ago on gluing an ignition plate. I would venture to guess that the spring might be out of your ignition. Is it returning normally? There is a detent ball in there as well. It's been a while sense I've had an ignition apart.
If you have more info on what you've had appart or pics of the column we might be able to pinpoint where the part came from.
"What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.."
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
Tvättbjörn
PostPosted: Thu Jul 08, 2021 9:02 pm    Post subject: Re: unknown spring on floor mat Reply with quote
removed steering lock today. The spring I found is not related to it.
One thing I noticed after the lock was removed and inspected. It appears the Bakelite contact piece shrinks over time ( decades ) and that is why it come out. The piece was 100% good and also no damage on the crimps . Just getting it back together is a .........
Makes you wonder how it was done at the factory
vwpieces is offline
PostPosted: Thu Jul 08, 2021 9:26 pm    Post subject: Re: unknown spring on floor mat Reply with quote
The electrical part and the lock cylinder can be removed from the actual ignition housing. Small pins need to be drilled out to separate the 3 main parts, electrical sw, lock cyl and cylindrical main housing.
Re-crimping the bakelite in electrical SW part is much easier once removed.
68 BUS
83 2dr JETTA 16V
Tvättbjörn
PostPosted: Thu Jul 08, 2021 11:12 pm    Post subject: Re: unknown spring on floor mat Reply with quote
Just looked at both units I have = same problem on both. I will re-crimp both units , but will not remove the electrical portion. The pin is just too tiny. Flat head screw driver and a tiny tiny tiny hammer should work. I did use some JB-weld already to give additional support to keep it in place.
