poopdevil Samba Member
Joined: September 03, 2008 Posts: 270 Location: Seattle
Posted: Thu Jul 08, 2021 1:09 pm Post subject: vacuum can failure? |
Hi all! My 57 is all original and I am having issues where fuel does not suck into the carburator.
I am currently rebuilding it because I thought it was possible the seals are bad.
I am not much of a mechanic but am learning as I go.
I have gone through everything and narrowed it down to the Carb needing to be rebuilt, the fuel pump itself or the vac canister
I did not even think about it but could it before but could it possibly be the vac canister failing so fuel does not go past the fuel filter into the carb?
I saw that these cans cannot be opened without destroying them so I will look for a NOS one if possible to keep the integrity of the engine.
Just looking for any advice anyone can give.
Thanks! |
janerick3 Samba Member
Posted: Thu Jul 08, 2021 1:56 pm Post subject: Re: vacuum can failure? |
Vacuum advance has nothing to do with fuel delivery.
If you live in an area where ethanol-free gas is not available, check both braided rubber lines on the suction side (before the fuel pump) for moist spots.
The ethanol rots the braided lines prematurely, allowing air to seep into the line. When that happens you break the siphon flow from the tank and end up pumping too much air and not enough gas, causing fuel starvation. The cotton braid sucks up the leaking gas like a sponge and it evaporates before it can drip onto the ground. There should also be a stronger-than-usual smell of gas in the garage. _________________ Thanks,
Jan K. |
Posted: Thu Jul 08, 2021 11:16 pm Post subject: Re: vacuum can failure? |
Hmmm. Well all of my lines are solid metal
Lines. No hoses and nothing braided. Well, I’ll rebuild
The carb and see what happens at this point. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Thu Jul 08, 2021 11:30 pm Post subject: Re: vacuum can failure? |
Original 36 hp Beetle distributors have a threaded steel line between the distributor and the carburetor. There is a soft line between the pan and the front engine tin but this shouldn't effect the issues you are having as above. NOS canisters are hard to find but not impossible. You can check the integrity of the canister by disconnecting the vacuum line at the carburetor and inserting a vacuum pimp on the line. If the gauge on the pump shows that it holds vacuum then it's good. If it leaks back to 0... _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Fri Jul 09, 2021 1:50 am Post subject: Re: vacuum can failure? |
janerick3 wrote: |
this. the can can be checked by sucking on the pipe and seeing if the distributor plate moves. prime suspect is surely the fuel pump... _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Fri Jul 09, 2021 11:34 am Post subject: Re: vacuum can failure? |
I was suspecting the pump too but I had some gas leaking from a seal
in the carburetor so decided to overhaul it. I see they sell a rebuild kit for the fuel pump as well. I’ll get that too in case I need it if it still has issues once the carburetor is back on!
Thanks guys! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Fri Jul 09, 2021 12:43 pm Post subject: Re: vacuum can failure? |
That translates to a bit over $71 usd a fair price. _________________ Roads Scholar &
Posted: Fri Jul 09, 2021 5:54 pm Post subject: Re: vacuum can failure? |
Thanks! One quick question. Soaked carb in chem dip. After rinsing there is a grey powdery film. Will this effect performance? Wiping
It with a towel and it keeps wiping off. |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 975 Location: Las Vegas, NV
Posted: Mon Jul 12, 2021 8:17 am Post subject: Re: vacuum can failure? |
If the fuel pump has never been rebuilt it is probably the 60+ year old diaphragm that has split and no longer functions. Wolfsburg West sells a rebuild kit. While you have the fuel pump out I recommend checking the small pin that is pressed into the fuel pump body that the lever inside the fuel pump pivots on. I've had that little guy come lose and walk it's way out of the fuel pump body, causing the pump to stop working and the engine dies. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6617 Location: Houston, Texas
