2Dokas Samba Member
Joined: October 09, 2004 Posts: 758 Location: Santa Cruz, CA
Posted: Sun Jul 11, 2021 10:45 am Post subject: 2X epoxy primer - cleaning gun with? |
what do you use to clean up your gun after using Nason 491-10 2X epoxy?
paint thinner?
thanks
Peter _________________ 87 Doka 2WD Ej22,
56 Convertible |
bomberbob Samba Member
Posted: Mon Jul 12, 2021 4:47 am Post subject: Re: 2X epoxy primer - cleaning gun with? |
From the technical data sheet
CLEANING OF PAINT EQUIPMENT
Use Axalta® 105™ Gun Cleaner, Axalta® 107™ Low VOC Gun & Equipment Cleaning Solvent, or any other equipment cleaner as permitted by local regulations. _________________ 1968 Beetle torn apart again
1990 Jetta GLI megasquirted, burning E85 (currently in storage)
2004 Jetta turbo GLI
Marion, Iowa |
2Dokas Samba Member
Posted: Mon Jul 12, 2021 6:31 am Post subject: Re: 2X epoxy primer - cleaning gun with? |
thanks,
56 Convertible |
67ctbug Samba Member
Posted: Mon Jul 12, 2021 9:22 am Post subject: Re: 2X epoxy primer - cleaning gun with? |
Lacquer thinner, reducer, or a paint gun cleaner should work. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
| KentPS wrote: |
...or the PO envied the terrorists' bus in "Back to the Future".  |
| mukluk wrote: |
| He's fine, just waiting for the dragon in winklepickers to move out of his lane. |
viiking Samba Member
Joined: May 10, 2013 Posts: 3361 Location: Sydney Australia
Posted: Mon Jul 12, 2021 5:03 pm Post subject: Re: 2X epoxy primer - cleaning gun with? |
Axalta® 107™ Gun Cleaner, Axalta from their MSDS is ~90% acetone!
Axalta® 105™ Gun Cleaner, Axalta from their MSDS is ~50-75% methanol with some acetone, toluene and benzene. Methanol is nasty stuff, so you are better looking at the first one.
Straight acetone should get you close.
Hopefully you haven't already sprayed it and are waiting on these thinning instructions.  _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
NAES Samba Member
Joined: September 10, 2003 Posts: 2190 Location: AREA-52 Southern Killafornia
Posted: Mon Jul 12, 2021 7:21 pm Post subject: Re: 2X epoxy primer - cleaning gun with? |
laquer thinner has always served me well _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Tue Jul 13, 2021 3:58 am Post subject: Re: 2X epoxy primer - cleaning gun with? |
| NAES wrote: |
| lacquer thinner has always served me well |
x2 not to be confused with paint thinner. You can use reducer but that is rather expensive. Acetone is too volatile. IMO _________________ 71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2186 Location: Laurel Canyon, CA
Posted: Tue Jul 13, 2021 10:01 am Post subject: Re: 2X epoxy primer - cleaning gun with? |
I use lacquer thinner or acetone. Usually acetone because it's cheaper.
A lot of times I also have a can of pressurized carb or brake cleaner spray to give parts a final "rinse off" after they have been brushed clean. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
2Dokas Samba Member
Posted: Thu Jul 22, 2021 1:04 pm Post subject: Re: 2X epoxy primer - cleaning gun with? |
I see there is Virgin Lacquer thinner at the auto paint shops, and lacquer thinner at Home Depot.
Any difference?
thanks _________________ 87 Doka 2WD Ej22,
56 Convertible |
Posted: Thu Jul 22, 2021 3:23 pm Post subject: Re: 2X epoxy primer - cleaning gun with? |
Learn to look up the MSDS for each product.
By law they are required to provide the details of all hazardous ingredients. Sometimes proprietary information can be withheld but generally they are there.
The MSDS is name specific so you have to use that. I don't know the exact name you have but one I Googled
https://msdsdigital.com/100-virgin-lacquer-thinner-msds
Shows in Section 3
39-42% Methanol
31-33% Toluene
13-16% Acetone
9-11% Solvent 210
The reference to CAS (Chemical Abstract Service) further gives a number you can look up which gives some chemical formulae but more importantly what the common name for the item is.
For example Solvent 210 68410-97-9 is Distillates (petroleum), light distillate hydrotreating process, low-boiling
Google that and ask for synonyms and you will usually find out some common products it is used in.
Sounds complicated but in 5 minutes of research you can find out a lot of information.
I assessed thousands of MSDS as part of my job for many years and know that a lot of high priced products are just common chemicals. It is also important that you know what the hell you are breathing and absorbing through your skin. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Posted: Thu Jul 22, 2021 4:07 pm Post subject: Re: 2X epoxy primer - cleaning gun with? |
| 2Dokas wrote: |
Any difference?
thanks |
Pretty sure the virgin lacquer thinner is little higher quality or better refined and so it preferable for thinning paint. I haven't been able to get the good stuff for many years here. The laquer thinner in Cali is mostly acetone now... For cleaning a gun and supplies just get the cheaper one. It will work well. _________________ 1967 Bug ( the daily rod )
carlos_magnum Samba Member
Posted: Mon Jul 26, 2021 10:52 pm Post subject: Re: 2X epoxy primer - cleaning gun with? |
| I also use a lacquer thinner. Got it from Home Depot. |
