skemems Samba Member
Joined: February 23, 2017 Posts: 207 Location: Portland
Posted: Mon Jul 19, 2021 10:55 am Post subject: Poptop color / antenna |
I am in the process of re-spraying my westy. The original color is Flash Silver metallic. My question to you, should I spray the top the same color? or keep it the original white?
Does anyone know the paint code to the white top? I know some have used marine paint etc. I prefer to use automotive paint with clear.
Also, I was debating on shaving the antenna, rear wiper, rear badge holes for a cleaner look. Has anyone done this? What are your thoughts? What other items have you removed? I dont ever use the the radio and I dont think I would miss my rear wiper.
charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Honuak Samba Member
Posted: Mon Jul 19, 2021 1:33 pm Post subject: Re: Poptop color / antenna |
I deleted the antenna and use a plug in/in dash antenna with mixed results. The powerful radio stations work fine but weaker signals are spotty. Losing a water ingress directly above the fuse panel was worth more to me than listening to smaller radio stations.
I also deleted the rear wiper, emblem holes and all the utility cutouts in the drivers side (Westy). I did all of the as a total redo/respray. The idea was to eliminate water ingress. My fridge is DC only and I fill the water tank from the inside.
I had the same questions regarding the top and painted it white FWIW. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Mon Jul 19, 2021 2:22 pm Post subject: Re: Poptop color / antenna |
Honuak wrote: |
I deleted the antenna... |
But it is so handy for hanging a trash bag. |
jimf909 Samba Member
Posted: Mon Jul 19, 2021 2:29 pm Post subject: Re: Poptop color / antenna |
Honuak wrote: |
All good ideas. I might miss the rear wiper occasionally but probably not really, esp. if I ever get around to installing the rear cam "mirror". _________________ - Jim
Abscate wrote: |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Mon Jul 19, 2021 3:46 pm Post subject: Re: Poptop color / antenna |
These are just my opinions, but that's what you asked for...
- Antenna. Yeah, I would be REAL tempted to fill that if I was doing a paint job on my van. There's just too many other options for tunes.
- Roof. I love the look of Westies with color-matched tops and flash silver is probably reflective enough to not cause issues with sun/heat. If I ever painted my pop top I would probably keep the red color on the sides but paint the horizontal surface white like school busses and UPS trucks do nowadays.
- Rear wiper. I'm definitely a weirdo on this one. There's just something about using a rear wiper on my van and hatchbacks that brings me joy. Especially if it's wiping a nice smooth arc through the dust that collected there while off-roading. Also, it's one of just a few things that screams "Vanagon GL" I would never give that up. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
pdm777 Samba Member
Joined: August 06, 2012 Posts: 348 Location: Clovis, CA
Posted: Mon Jul 19, 2021 4:00 pm Post subject: Re: Poptop color / antenna |
Bordeaux Red top here.
I painted the top white,
and it resulted in about 40 degree
cooler. Left the sides red,
and you really can't tell the top
is white unless the top is popped.
_________________ 1990 Westy Full Camper |
SCM Samba Member
Posted: Mon Jul 19, 2021 4:05 pm Post subject: Re: Poptop color / antenna |
pdm777 wrote: |
That much!? Wow, this might have jumped WAY up on my list of things to eventually do sometime when I'm bored and have $ burning holes in my pockets. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
pdm777 Samba Member
Posted: Mon Jul 19, 2021 4:19 pm Post subject: Re: Poptop color / antenna |
Yes.
And, it is an inexpensive task.
Paint prep is essential here,
I sanded then wiped with solvent
prior to rattle can painting.
Still holding up fine after 4 years.
ALSO, adding a cargo box and kayak to shade
the top has helped keep solar gain manageable.
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Mon Jul 19, 2021 5:00 pm Post subject: Re: Poptop color / antenna |
The Westy tops for the US market flash silver vans were Nutriabeige, most the rest of world were White (L90D is as good as any). Tops are usually painted using single stage slightly flattened. Try not to remove the molded texture (IMO).
Are you planning to use the original bumper color or color coding? Buth look good when coupled with the raised portion painted black. Again IMO. _________________ Schau in das Buch |
Posted: Mon Jul 19, 2021 5:07 pm Post subject: Re: Poptop color / antenna |
dgbeatty wrote: |
Are you planning to use the original bumper color or color coding? Buth look good when coupled with the raised portion painted black. Again IMO. |
I did not know it was a Nutriabeige, is there a color code for this?
Yes, I want to keep the original top texture as much as possible.
Have not decided on bumpers yet. It came with chrome ones. Its an 87, I think they were originally chrome. |
Posted: Mon Jul 19, 2021 5:24 pm Post subject: Re: Poptop color / antenna |
Google "vw nutriabeige color code" L575. _________________ Schau in das Buch |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Mon Jul 19, 2021 6:32 pm Post subject: Re: Poptop color / antenna |
I'm definitely a fan of the color matched top. Mine was painted with color/clear coat and I didn't lose any of the texture. Has stayed shiny for more than 10 years.
_________________ 89 Westy 2.1 Auto |
