wide 5 BRMs with adapters ( 4x130 to 5x205)
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
bearwin
bearwin is offline
PostPosted: Thu Dec 17, 2020 4:37 am    Post subject: wide 5 BRMs with adapters ( 4x130 to 5x205) Reply with quote
hello guys, i just want to inquire if my 68 std bug (4 lugs) can run the wide 5 BRMs using the 4 lug to wide 5 lug wheel adapters, my concern is, will the bolts on the 4x130 part clear the back side of brms? adapter bolts won't hit the rim?
thank you
DerrickfromNC1
DerrickfromNC1 is offline
PostPosted: Thu Dec 17, 2020 9:55 am    Post subject: Re: wide 5 BRMs with adapters ( 4x130 to 5x205) Reply with quote
I have the 4 bolt to wide 5 adapters with 17” BRMs....no interference problems.
However you may have a problem with your tires contacting your fenders since those adapters will push your wheel/tires out about 1/2”.
Pacblue63
Pacblue63 is offline
PostPosted: Sun Jan 17, 2021 2:38 am    Post subject: Re: wide 5 BRMs with adapters ( 4x130 to 5x205) Reply with quote
Did u use steel 4lug to 5x205 adapters
Also what lugnuts did u use to bolt up adapter on 4Lug holes
Thanks
DerrickfromNC1
PostPosted: Sun Jan 17, 2021 5:04 pm    Post subject: Re: wide 5 BRMs with adapters ( 4x130 to 5x205) Reply with quote
Yes 4 to 5 lug adapter. Used the 14mm screw in studs to bolt adapter to disc/drum. Used 12mm screw in studs for wheel to adapter. All items from CBPerf.
Pacblue63
PostPosted: Mon Jan 18, 2021 11:35 am    Post subject: Re: wide 5 BRMs with adapters ( 4x130 to 5x205) Reply with quote
Did u use spacer for front to clear caliper
Will use 17x7 empi raider wheels on vw bug
Thank you
DerrickfromNC1
PostPosted: Tue Jan 19, 2021 3:33 pm    Post subject: Re: wide 5 BRMs with adapters ( 4x130 to 5x205) Reply with quote
Used a 3/8” spacer to gain clearance between the spacer and caliper.
Pacblue63
PostPosted: Tue Jan 19, 2021 7:26 pm    Post subject: Re: wide 5 BRMs with adapters ( 4x130 to 5x205) Reply with quote
Nice same setup planning to use
Thanks for reply
Pacblue63
PostPosted: Mon Jul 19, 2021 4:41 pm    Post subject: Re: wide 5 BRMs with adapters ( 4x130 to 5x205) Reply with quote
Have a pic of rear setup?adapters bolted
DerrickfromNC1
PostPosted: Tue Jul 20, 2021 11:11 am    Post subject: Re: wide 5 BRMs with adapters ( 4x130 to 5x205) Reply with quote
Basically same setup as front except on drums minus the 3/8” spacer under the adapter.
Pacblue63
PostPosted: Tue Jul 20, 2021 11:23 pm    Post subject: Re: wide 5 BRMs with adapters ( 4x130 to 5x205) Reply with quote
Kool thank u
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
