jlinares Samba Member
Joined: June 30, 2018 Posts: 71 Location: Distrito Capital de Bogotá
Posted: Tue Jul 20, 2021 7:02 pm Post subject: Speedometer reading inacurate, below the real speed. |
Today I replaced the speedometer cable and decided to finally fix the speedometer, a long while ago the needle got stuck. I disassembled it, cleaned and lubricated with vaseline every piece of it, including the tiny head of the needle (don't know if that was a bad thing). Now the speedometer moves freely, but reads a speed below the actual one, about 20 km/h under what I'm really travelling at. What may cause that? |
Posted: Tue Jul 20, 2021 7:19 pm Post subject: Re: Speedometer reading inacurate, below the real speed. |
My car is a 1966 beetle. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9759 Location: Oregon
Posted: Tue Jul 20, 2021 7:40 pm Post subject: Re: Speedometer reading inacurate, below the real speed. |
Tire size has a huge affect on what you are reading on the speedometer.
What size front tires are you running?
I'm not sure it helps ya. But just run with the traffic and you should be good to go.
Police around here. Don't really pull you over. Unless you're way over the speed limit. Well maybe 10MPH/Km over might get you a ticket. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Jul 20, 2021 7:49 pm Post subject: Re: Speedometer reading inacurate, below the real speed. |
Tires are 5.60 x 15 |
Posted: Tue Jul 20, 2021 7:50 pm Post subject: Re: Speedometer reading inacurate, below the real speed. |
67rustavenger wrote: |
Police around here. Don't really pull you over. Unless you're way over the speed limit. Well maybe 10MPH/Km over might get you a ticket. |
I don't care about the police, I just want my thing to work good, I know it can't be exact, but can be way better. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Tue Jul 20, 2021 8:00 pm Post subject: Re: Speedometer reading inacurate, below the real speed. |
I have found the speedometers on both of my VWs is fairly accurate up to around 45-50 and then progressively get less accurate. At around 65/70 they are off by as much as 8mph or more. I just use a Speedo app on my phone if I want an accurate speed.
I’m not a Speedo restoration expert but not sure vasoline is the best choice. Maybe I’m wrong but seems really thick for such an application. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
finster Samba Member
Joined: May 26, 2012 Posts: 7935 Location: north o' the border
Posted: Wed Jul 21, 2021 2:04 am Post subject: Re: Speedometer reading inacurate, below the real speed. |
if you had the needle off the shaft were you aware that there is a preload spring? you might not have noticed the shaft turn slightly and therefore the needle is on the wrong splines.
also agree with sharp64, my first thought was vaseline is too 'sticky'. see this thread
https://www.thesamba.com/vw/forum/viewtopic.php?t=327535& _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
