Brentpd Samba Member
Posted: Wed Jul 21, 2021 5:47 pm Post subject: Ignition control module replacement |
I posted on here a few weeks back about an issue that I’ve been having. I’m on a rather long trip (putting a lot of miles on my recently rebuilt 1.9 liter) and the engine will randomly shut off, especially but not limited to when I’m slowing down, downshifting, or going down a hill (inexplicable, I know). I called a mechanic back home who I trust and he swears he’s had the same issue and it was caused by a bad ignition control module. It’s $150 for the part which is kinda spendy if it’s NOT the cause but if it is I’ll gladly pay that to feel safe driving down the road without losing power. Anyway I opted to buy the part and am planning to swap it out tomorrow. My question is this—it seems like a straightforward switch. Unplug wire harness, dismount old part; mount new part, plug in wires. Five minutes and it’s through, correct? I just want to make sure I’m thorough so if anyone has any input for this here greenhorn I’d really appreciate it!
Thanks |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Wed Jul 21, 2021 5:59 pm Post subject: Re: Ignition control module replacement |
It should bolt to an aluminum plate. Ideally you’d use some paste to help heat transfer from the module to the aluminum plate. Otherwise it’s straightforward. It might be easier to remove the aluminum plate and transfer the new module and reinstall the assembled assembly. Hope it fixes your problem. Having a spare module is not a bad idea even if it proves intermittent. _________________ ☮️ |
Bing! Samba Member
I can attest to the Ignition Control Module being a quick plug and play. I recently installed one to help trouble shoot a bad start issue with my 1.9 WBX. However, depending on which one you get, you may have to use self tapping screws in different locations, as not all of the heat sink holes are in the same locations on aftermarket units.
After replacing a bunch of things, it turned out to be my coil. Possibly check that before you drop the cash on something twice the price.
Cheers! |
DuncanS Samba Member
Posted: Wed Jul 21, 2021 6:01 pm Post subject: Re: Ignition control module replacement |
There was a post on this topic in the last tow or three weeks. Mightta been
HERE WE GO!! .... 1990 Tintop! Check the alt to starter motor wire. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4791 Location: Bemidji, MN
Posted: Wed Jul 21, 2021 6:50 pm Post subject: Re: Ignition control module replacement |
it's an easy swap that is plug and play.
there's an issue where the heat sink paste dries up on the ignition module and causes the ICM to overheat and go flakey. the cure, if the module isn't fried completely is to disassembly it from the aluminum heat sink, clean off the old heat sink grease, and re-apply new.
put the new module in and carry on. but don't throw the old one out... clean it and re-apply heat sink grease and keep it for a spare, preferably after giving it a good test. _________________ -dan
www.thefixitworkshop.com |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Wed Jul 21, 2021 7:46 pm Post subject: Re: Ignition control module replacement |
Brentpd wrote: |
...It’s $150 for the part... |
Last one I got was less then 15 bucks on eBay. Not OEM, possibly made in Israel. Works fine. |
Posted: Thu Jul 22, 2021 4:21 am Post subject: Re: Ignition control module replacement |
Ahwahnee wrote: |
Brentpd wrote: |
Yeah you know I found one on GoWesty at around $40 but right now I’m in the middle of nowhere Virginia and that’s what OReilly is charging.. |
