palmgreen57 Samba Member
Posted: Mon Jul 05, 2021 2:15 pm Post subject: Transmission axle boot plate difference |
Hello.
I just recently noticed these differences of diameter and height on boot plate, I have been told there was early and later design... Maybe to avoid leak?
Does someone know when it changed approximately?
Thank you
Yan
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Jul 06, 2021 10:43 am Post subject: Re: Transmission axle boot plate difference |
… looking in my 10/1957 VW parts book - shows that retainer, you referenced as part number 111 501 141, qty. 2 AND an under sized one 111 501 143 - no ch. number break mentioned - listed are 2 retainer gaskets > a 0.3 and 0.1mm... all found on page 5-3, illustration 17, numbers 4,3,2... An * appears = used on type 2 also.
Nothing is mentioned in Car of the Century, by JT GARWOOD ( I looked in 1945 through 1950)- z
… i'd say, just a running change ... _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Wed Jul 07, 2021 11:45 am Post subject: Re: Transmission axle boot plate difference |
Hello, OK it's well referenced with 2 differents parts so.
I'm curious to know why...
Nobody knows more about?
Thanks |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Wed Jul 07, 2021 11:54 am Post subject: Re: Transmission axle boot plate difference |
okay, I'm spit balling here...but is the difference possibly to indicate that one is used for early trasaxles that do not have the plastic "flower" between the transaxle and the bell of the axle tubes? _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Wed Jul 07, 2021 11:18 pm Post subject: Re: Transmission axle boot plate difference |
I didn't think about that, that could be the reason yes
The larger one came from a transmission with that plastic flower |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 986 Location: Bath, England
Posted: Mon Jul 12, 2021 3:03 pm Post subject: Re: Transmission axle boot plate difference |
Does that mean that you can use the 'plastic flower' on an earlier transmission, if you use the later, taller, cover? I ask this because I've just taken an earlier box apart, and because of swarf (from worn out bearing?), or whatever in the oil, the surface of the mag alloy casing, upon which the axle tube pivots, is badly scored, and maybe using the 'plastic flower' could make it usable again? |
Posted: Mon Jul 12, 2021 10:34 pm Post subject: Re: Transmission axle boot plate difference |
The non flower transaxle is not machined to accept the flower buffer. the flower won't fit the ID of the axle hole _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Fri Jul 23, 2021 11:07 am Post subject: Re: Transmission axle boot plate difference |
From what I'm finding as I go along with various gearboxes, is that the plastic daisey doesn't seem to have been fitted to split case boxes, including the 3 synchro, although I'm sure I have such a box (stored elsewhere, & I will compare later) with them fitted.
I've just noticed in my Scientific Publications, 'All Cars Up To January 1960' Workshop Manual, that it says that the plastic shims were introduced in September 1958.
As you say, the ID of the shaft opening is smaller on the 3 synchro, and no doubt earlier boxes, but if the case we machined out slightly to accept them, would there be problems fitting the original metal covers covers, with a need to use the later ones?
The reason I'm keen to find out, is because the original case from the oval has heavy scoring (lined grooves) in one area, and once polished out as well as possible, the use of the plastic spacer would prevent future acting of steel upon the mag alloy.
I'm sure this has all been done somewhere in the deep & distant past, and especially when trying to keep a vehicle as a matching numbers car.
Below are pictures of a 3 synchro box with new 'daisey' resting on the original ID hole.
