bcolins Samba Member
Joined: December 04, 2020 Posts: 729 Location: Austin, TX
Posted: Fri Jul 23, 2021 4:27 pm Post subject: Looking for tutorial on five cylinder head remove and replace |
I have only been able to find TDI cylinder head remove and replace tutorials and /or videos. Anyone know of a tutorial for the in-line five cylinder gas engine cylinder head R and R?
Brian In Austin
subdewd Samba Member
Posted: Fri Jul 23, 2021 5:02 pm Post subject: Re: Looking for tutorial on five cylinder head remove and replace |
Can't imagine any different. Remove air box. Disconnect fuel lines. Disconnect wiring. Pull wires from under intake man.
Line up tdc. Remove distributer. Loosen timing belt and slide off cam sprocket. Disconnect downpipe. Remove valve cover. Loosen then remove head bolts. Lift off head. Install reverse as removed |
Posted: Tue Nov 30, 2021 10:00 pm Post subject: Re: Looking for tutorial on five cylinder head remove and replace |
Anyone found a tutorial? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Wed Dec 01, 2021 12:56 am Post subject: Re: Looking for tutorial on five cylinder head remove and replace |
I would get thee the Haynes UK TDi manual for you car. Translate the. Number plate system to get the right Year and correct generation
I think this is it?
https://haynes.com/en-us/volkswagen/transporter-t4...gIxCfD_BwE _________________ .ssS! |
Posted: Wed Dec 01, 2021 7:56 am Post subject: Re: Looking for tutorial on five cylinder head remove and replace |
its a gas 5 cylinder,....see my original post |
Zeitgeist 13 Samba Member
Posted: Wed Dec 01, 2021 10:05 am Post subject: Re: Looking for tutorial on five cylinder head remove and replace |
The gas and diesel five cylinders are virtually the same long blocks, so the procedures for head removal are similar enough to serve as a guide. The SOHC Audi fives from the '80s and '90s are also the same, so there should be lots of info out there to help you along. Post pics here and we can help you along. This is a relatively easy job, but attention to detail is key _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
