carlos_uk Samba Member
Posted: Sun Mar 30, 2014 4:28 am Post subject: Spindles shims? |
Hi guys,
Just had my spindles dropped but I don't know how many shims I need to put where now? Can someone please tell me?
Thanks carl. |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Sun Mar 30, 2014 4:56 am Post subject: |
There are 8 shims to each link pin. 32 total. Where they go and how many depend on the offset of your torsion arms. You need to measure that, then use a chart in the Bentley manual for shim placement. If you don't have a Bentley, the process is described here:
http://www.1800vw.bizhosting.com/linkpinshims.htm
Use the chart that says 8 shims. If your measurement falls outside this range, you may have a bent torsion arm. _________________ Tim |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1218 Location: Eerie PA
Posted: Sun Mar 30, 2014 8:08 am Post subject: |
Go to Widefive.net and he has all the instructions on his website on how to instal. It's good people like Aaron who share this info that makes the VW community awesome! Plus you don't need all 8 as long as you have the proper amount on the inside and at least two on the outside you're good. If you need additional shims he has those available for not much coin. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
Posted: Sun Mar 30, 2014 1:24 pm Post subject: |
pondoras box wrote: |
Go to Widefive.net and he has all the instructions on his website on how to instal. It's good people like Aaron who share this info that makes the VW community awesome! Plus you don't need all 8 as long as you have the proper amount on the inside and at least two on the outside you're good. If you need additional shims he has those available for not much coin. |
Amazing many thanks |
buspeople Samba Member
Posted: Sat Jul 24, 2021 10:33 am Post subject: Re: Spindles shims? |
I’m seeing 2 different tables in the Muir book. One table says earlier busses have 10 shims and later splits have 8. is it essential to use 10 on the earlier splits? I used 8 on mine and would rather not tear it all apart over 2 shims |
WideFive SBS Hit Squad
Joined: August 20, 2002 Posts: 1147 Location: Litchfield, Ohio
