Reinigm Samba Member
Joined: March 26, 2018 Posts: 6 Location: Westminster, CA
Posted: Sat Jul 24, 2021 10:57 am Post subject: Driver door lock mechanism stuck 1973 Bus |
My driver door is stuck closed and I can't open it. Therefore, I can't get to the outside edge of the door to free up the lock mechanism. The inside latch rod seems to be nice and loose and slides ok. The outside door latch doesn't do anything. Does anyone out there know a way to access the mechanism from inside the door to free up the latch? Any suggestions would be helpful. Thanks |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jul 24, 2021 12:16 pm Post subject: Re: Driver door lock mechanism stuck 1973 Bus |
Is this a brand new problem?, or has the bus been sitting for years? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Sat Jul 24, 2021 5:59 pm Post subject: Re: Driver door lock mechanism stuck 1973 Bus |
is the button up or down? Or does it have the locks with the two parts on the inside like this:
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Jul 27, 2021 12:53 pm Post subject: Re: Driver door lock mechanism stuck 1973 Bus |
New problem. My daughter and her boyfriend decided to try and fix all the locks on the bus. All were successful except this one. This one ended up jammed when they were finished. It has the lock with two parts like in the picture. That part of the problem works fine. Including the locking bar that goes back to the lock mechanism. That slides and pulls the connector rod fine. It's in the door mechanism on the end of the door that is jammed. Could the spring coil break maybe? |
Posted: Tue Jul 27, 2021 1:04 pm Post subject: Re: Driver door lock mechanism stuck 1973 Bus |
Try removing the lever from inside the door and manually pulling the rod forward hard, the rod may need adjustment. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Tue Jul 27, 2021 1:10 pm Post subject: Re: Driver door lock mechanism stuck 1973 Bus |
is the door tight tight or does it have some play like it partially opens? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
