Jetsrforkids Samba Member
Joined: July 11, 2020 Posts: 21 Location: Houston, TX
Posted: Sat Jul 24, 2021 7:30 am Post subject: While the gas tank is out, what to else to do? |
I’ll be taking out the gas tank from my 1964 Beetle to switch to a dual circuit master cylinder and replace the brake lines. While the tank is out, what else should I check or replace? I’m pretty sure the tank has never been removed. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sat Jul 24, 2021 9:05 am Post subject: Re: While the gas tank is out, what to else to do? |
Fuel lines for one.
Maybe get the shop vac out and clean up all the gravel and road debris off the frame head area.
Since your doing the MC. Now would be a good time to change the brake line hoses. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
wayne1230cars Samba Member
Posted: Sat Jul 24, 2021 1:18 pm Post subject: Re: While the gas tank is out, what to else to do? |
The steering coupler is a whole lot easier to access and change if necessary with the tank removed. I did mine on my ‘60 a few years ago. It was substantially deteriorated. Could have been original. Worth checking. _________________ 1960 beetle
1970 beetle convertible |
Posted: Sat Jul 24, 2021 9:25 pm Post subject: Re: While the gas tank is out, what to else to do? |
Steering rod coupler, I didn’t even know there was one. I’ll add it to my shopping list. As for tie rod ends, how do I know if they are bad? |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Sat Jul 24, 2021 10:27 pm Post subject: Re: While the gas tank is out, what to else to do? |
When you grab the tie rod and twist, the linkage should feel stiff. If it feels loose, replace. Measure them very carefully, end to end prior to removal, to minimize your alignment adjustments after replacement. Also consider just replacing the steering damper while you’re in there.
Here’s what you’ll see (basically) when you pull the tank:
_________________ Plate of shrimp |
Stockholm VW Samba Member
Posted: Sun Jul 25, 2021 4:06 pm Post subject: Re: While the gas tank is out, what to else to do? |
panicman wrote: |
What are you doing with the funnel? _________________ 1966 Volkswagen Sedan 1300 (now 1641), 6 volt, L456 Ruby Red, Platinum leatherette. |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2008 Location: Texas
Posted: Mon Jul 26, 2021 6:52 am Post subject: Re: While the gas tank is out, what to else to do? |
I'd also drain the fuel tank & rinse it out with fuel of possible debris/sediment. Also, replace the fuel filter screen at the bottom of the tank - they tend to deteriorate in time. Along with that is replacing the rubber washer at the bottom as well.
From the gallery:
_________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
