octavioadrian Samba Member
Posted: Wed Jun 13, 2018 5:28 am Post subject: Re: Driver side door switch for dome light |
Bruce wrote: |
That's a 2 pole switch. It won't work if you want to retain the key buzzer. |
It is a 4 pole. I purchased one and it worked fine. |
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Thu Jun 14, 2018 5:11 am Post subject: Re: Driver side door switch for dome light |
octavioadrian wrote: |
Bruce wrote: |
They call it a four pole, but the picture clearly shows a two pole with 1-into-2 adapters on the connectors, meaning that those four connections are electrically connected as pairs. In short, they are misrepresenting their product, but I am glad you were able to make it work to your satisfaction. _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
AlmostHeavenWV_VW Samba Member
Posted: Tue Oct 30, 2018 6:48 pm Post subject: Re: Driver side door switch for dome light |
Just bumping to give an FYI
This may be of no interest to anyone else, but my driver's side switch is on the fritz again, so I started looking at what was available.
Found this, ordered it to test it out. Functions slightly different than the stock switch. This switch provides direct grounding through the switch body and mounting screw(similar to the passenger side switch) rather than ground wires like the stock set up.
I believe it should work. I'm not sure if my buzzer is functional, as it has never worked, but this item could be an option for those looking to preserve the buzzer functionality too.
https://www.jbugs.com/product/113947561H.html
_________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31271 Location: Hot Arizona
Posted: Wed Oct 31, 2018 7:36 am Post subject: Re: Driver side door switch for dome light |
AlmostHeavenWV_VW wrote: |
When I resurrected my 1970 1.5 years ago, I noticed that my driver side switch only operated on one circuit, so I taped off the buzzer wires and chose the dome light. I didn't find the listed switch available then, but I'd be quite interested to see how this works out for you. Keep us posted. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Nov 05, 2018 4:20 pm Post subject: Re: Driver side door switch for dome light |
UPDATE:
It fits and it works. Only steps needed for use of this switch:
Install the 'full size' push on terminals onto the wires for the light and buzzer
Shove the stock ground wires back into the door pillar (no longer needed as this new switch grounds through the mounting screw.)
Install switch.
Works great.
A+ _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Cusser Samba Member
vamram Samba Member
Posted: Mon Nov 05, 2018 4:41 pm Post subject: Re: Driver side door switch for dome light |
Did you also connect the key buzzer? Or just the dome light? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Mon Nov 05, 2018 7:24 pm Post subject: Re: Driver side door switch for dome light |
vamram wrote: |
Did you also connect the key buzzer? Or just the dome light? |
My buzzer is non-functional, but I tried it out with my extra ground wire I had over there. Fits with two wires hooked up just fine.
If my buzzer was functional, I'd have hooked it up too. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
mondshine Samba Member
Joined: October 27, 2006 Posts: 2765 Location: The World's Motor Capital
Posted: Mon Nov 05, 2018 9:06 pm Post subject: Re: Driver side door switch for dome light |
If you can't find a working driver's side (double pole) switch, and insist on having a working "key buzzer", you could use a passenger side (single pole) switch to trigger a double pole relay, which would isolate the two loads.
Here's a sketch of a double pole, single throw relay:
The thing is, a DPST relay is hard to find, but a double pole double throw relay is common, and would do the job as well.
This "Dayton 1EJH2" relay is $12.10 from Grainger, $18.66 from Amazon.
https://www.grainger.com/product/DAYTON-12VDC-1EJH2
https://www.amazon.com/Dayton-1EJH2-Relay-Power-12...BVRDH10VC8
Plan B
Use two standard Bosch relays.
Plan C
Make another hole and use two passenger door switches.
Good luck, Mondshine |
jtpatrick Samba Member
Joined: October 14, 2009 Posts: 21 Location: Oak Harbor, WA
Posted: Fri Jul 16, 2021 7:01 pm Post subject: Re: Driver side door switch for dome light |
I'm rewiring the door buzzer. Does it matter which wire is on which terminal? Does anyone have an image of theirs? |
Posted: Fri Jul 16, 2021 8:37 pm Post subject: Re: Driver side door switch for dome light |
jtpatrick wrote: |
On the driver's side? Just as long as both ground wires are together, doesn't matter.
Here's some pics I took while working on my interior lights:
This is likely the one you need
1600DP AK case
Solex 34PICT3 Carb
The_Old_Guyyy Samba Member
Posted: Mon Jul 26, 2021 1:14 am Post subject: Re: Driver side door switch for dome light |
The dome light and the wiring were removed from my 71 super beetle before I got it. I received 2 new switches from jbugs that only have one pole on each. Will this suffice and can anyone tell me how to properly wire it all knowing it only has one on each side. I am aware that the ignition buzzer won't work, it is something I will just have to go without. Thanks in advance for the help! |
Cusser Samba Member
Posted: Mon Jul 26, 2021 7:25 am Post subject: Re: Driver side door switch for dome light |
The_Old_Guyyy wrote: |
The driver side switch with 2 pairs of terminals is no longer available new. So use the new one with 2 terminals and just do without the ignition buzzer switch; that's what I did on mine as only one circuit on my original switch still worked. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Jul 26, 2021 8:26 am Post subject: Re: Driver side door switch for dome light |
If your buzzer is functional, you can use this switch from Jbugs. It has two poles to attach your light and buzzer to. The switch grounds through the mounting screw, so just identify the wires to the light and buzzer, then tuck the extra ground wires from the old switch back into the hole.
See below from me a couple years ago on this thread:
UPDATE:
Install switch.
Works great.
A+ |
1600DP AK case
Solex 34PICT3 Carb
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15975 Location: North Florida, USA
Posted: Mon Jul 26, 2021 9:47 am Post subject: Re: Driver side door switch for dome light |
Using the single pole door switched means that you have a circuit that is grounded when either door is open. This is fine for turning the dome light ON when either door opens.
Run a single brown wire starting from the right side door switch over to the left side switch.
From the left side switch, run a single brown wire up to the dome light where is connects to the terminal controlled by the switch in the dome light.
At the left switch you will have two brown wires. You can either use a terminal piggy back connector (turns a single male terminal into two males) to connect both brown wires to your single switch terminal; or you can splice both wires into a single female terminal which plugs into the left door switch. Wired this way either door switch will ground the circuit. When the dome light is connected to this brown wire circuit it will turn ON when the circuit is grounded.
If you want to get your door buzzer working...
Look at the DPDT relay described by mondshine above (just checked and they still sell it for $17).
Instead of running the brown wire from the left door switch to the dome light, it runs to the "0" terminal of the relay. Using a red wire, wire the "1" relay terminal to a fused constant 12v source (the dome light fuse will work as this is a low current draw relay). Wired this way the relay will energize anytime either of the doors are opened.
The six remaining terminals on the relay are two separate circuits of 3-terminals each (inner-center-outer). From the diagram on the relay it looks like the center terminal is connected to the outer terminal when the relay is energized. We will use these two in each circuit. The inner most two terminals will not be used. The center terminal (the one between the inner and outer one) in each group of 3 is the common INPUT terminal for the three terminal circuit. For one set of 3 terminals, wire a brown ground wire to the center terminal. Ground it at any good ground point behind the dash. Wire the outer edge terminal to the dome light. When the relay is energized the relay will ground the dome light wire to turn the dome light ON.
Identify the SU circuit wire coming from the ignition switch. The SU wire is grounded anytime the key is in the ignition. It is usually a grey or grey/black wire coming out of the ignition switch. Test the ignition wires until you find it. Wire the SU wire to the center terminal of the other circuit. Wire the outer terminal to your door buzzer relay. The other wire of the door buzzer relay is powered by the same dome light fuse which has constant 12v. When the relay is energized (either door open) AND there is a key in the ignition the door buzzer will be grounded and BUZZ. When the key is removed the buzzer is disabled.
What I have described above is slightly different than the diagram mondshine posted above. In his diagram the door buzzer will buzz anytime the door is opened, even if the key has been removed. The way I have described the buzzer only sounds when the key is in the ignition AND either door is opened.
Be sure to tuck the relay such that none of the wires or terminals grounds to the chassis. Mount it up out of the way if you can. Otherwise consider wrapping all exposed connection in some insulation (heat shrink tubing). _________________ AshMan40
