Wing mirror replacement glass
ewtww
ewtww is offline
PostPosted: Mon Jul 26, 2021 7:29 am    Post subject: Wing mirror replacement glass Reply with quote
Hi has anyone changed mirror glass on their type 3s any tips to remove glass and refit only I want to change the length of the arm so I can see out of passenger side! Thanks in advance
https://1freesexchat.com / https://livesexcams.top / https://livesexchat.cam
Erik G
Erik G is offline
PostPosted: Mon Jul 26, 2021 9:48 am    Post subject: Re: Wing mirror replacement glass Reply with quote
I heated mine up in boiling water and had to carefully with a jewlery tool pry around the edges. not fun, was a cat eye T34 mirror my landlord broke (the base) with a motorcycle... you have to heat it to release the glue. Take your time and be patient. you'll likely need some deep creep or kroil for the rusty springs and stuff
