Ochie Samba Member
Posted: Mon Jul 26, 2021 9:39 am Post subject: Carburetor suggestions |
So I was hoping for some advise. I have a 40HP motor rebuilt with big bore to 1385, stock cam and rockers. I'm putting on Vanguard intakes for a dual carb setup. I have one (1) 28 PCI Carb, One (1) 28 PCIT-1 Carb and zero 32 PCIB carbs. What's the best carbs for the application of just Street Driver?
Cost wise the PCIT-1 would be least, followed by the PCI. Buying two 32 PCIB from Wolfsburg West is within budget and I like the idea of not having to rebuild right away.
So what's the advise on which carbs to go with and what's advise on jet sizes for any of the above?
Thanks
Ochie |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7215 Location: Videbaek Denmark
Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Mon Jul 26, 2021 12:41 pm Post subject: Re: Carburetor suggestions |
28 pcit-1 is not a good carb for dual carbs set up ...28 pci are better and also you can change the venturi in them not so much the 28 pcit since the venturi is casted into the carb you will hardly see those 28 pcit as dual carbs ....32 will be a better choice they also sell 34 pbic now days just search solex 34 pbic in Google they will pop up ...but if your not looking for the most power ..than go with dual solex 28 pci ... |
Ochie Samba Member
Posted: Tue Jul 27, 2021 3:05 pm Post subject: Re: Carburetor suggestions |
Thanks for the advice. I was leaning toward the PICT just for cost reasons.
I think now I'm going to go with the 32 PBIC's as they are a resonable price and I won't have to mess around with rebuilding or worn throttle shafts. Hopefully they come jetted correctly for my application. Should be close anyway. |
Posted: Tue Jul 27, 2021 3:29 pm Post subject: Re: Carburetor suggestions |
I think those ww 32 pbic carbs have throttle shaft problems ...you can confirm with joe ruiz aka Mr okrasa if you send the new carbs to him he fixes the shafts just heads up about those 32s .....you can search joe ruiz "mr okrasa " adds and find out ...... |
