Slyfoxx Samba Member
Posted: Mon Jul 26, 2021 10:24 am Post subject: Custom bay window idea |
I'm trying to work out an entirely new walk through custom bay window idea and I could use some feedback. I want to put a glass front end on a bay window I'm thinking maybe a 37 chevy and extend the beam to fit. I will need to square off the lower rear front door corners as the wheels are far forward so no front wheel wells. I can fab the foot wells easy enough.
Does anyone know if bug door rear bottom corners and door frames would work?
I'm going to extend the trans out behind the bus and make a pu bed to house the trans and a 1.9 turbo diesel with a 11 or 12 mm 1.6 injector pump.
Radiator will be in the grill opening of the 37 Chevy front end run through muffler pipes with rubber hose ends.
The rear engine cover is covered with the front of the bed but I want to keep the opening rear hatch.
No rear wheel wells either. I can weld in sheet metal to cover the wheel well opening so the quarters run smooth to the rear. I can remove the inner wheel house and make a flat floor all the way to the interior rear wall. Most of the flooring is there just above the engine house.
I want a walk through to make top hinged swing up side doors. I'm going to make drop in plywood floors to match the door size with tent material walls and windows. I'm thinking the same for rear hatch for airflow through out. I'm thinking Safari windows for the front. I would like all the windows to pop out but I don't know if that is something that can be done. I can make magnetic screens for the windows.
I'm thinking a front to rear frame under the pan may be a good idea. |
Joined: August 31, 2013 Posts: 12816 Location: North Carolina
Posted: Mon Jul 26, 2021 10:31 am Post subject: Re: Custom bay window idea |
You mean like Ian Roussel’s “cartoon car” VW pickup? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Joined: January 01, 2007 Posts: 16803 Location: sticksville, ct.
Posted: Mon Jul 26, 2021 10:53 am Post subject: Re: Custom bay window idea |
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1765 Location: Newmarket, ON
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Mon Jul 26, 2021 1:21 pm Post subject: Re: Custom bay window idea |
Globespotter wrote: |
My feedback is - I need to see this creation. Photos will be required. I want to see your imagination transformed into this build. |
I am intrigued _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 776 Location: Milwaukee
Posted: Mon Jul 26, 2021 2:04 pm Post subject: Re: Custom bay window idea |
You had me at "plywood". _________________ 70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4532 Location: Arizona Highways
Posted: Mon Jul 26, 2021 6:52 pm Post subject: Re: Custom bay window idea |
this sounds like a really great idea.....the parts that i comprehend, at least.
don't let these guys shoot you down.
do you
got any drawings/renderings so we can all bask in your ultimate vision?
go _________________ 71 Ghia A/S - 88 Van A/T - 13 JSW TDI 6M/T |
Cap10323 Samba Member
Posted: Mon Jul 26, 2021 8:31 pm Post subject: Re: Custom bay window idea |
I'll have some of what he's having _________________ -Ian
'77 Westfalia - 2.0 F.I |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22416 Location: Escondido CA
Posted: Mon Jul 26, 2021 9:28 pm Post subject: Re: Custom bay window idea |
borninabus wrote: |
do you
go |
Um yeah, I see the future of this thread before it happens......
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
