djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
vwlukas Samba Member
Joined: April 01, 2020 Posts: 43 Location: hood river
Posted: Tue Jul 27, 2021 10:52 am Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
My partner and I put some wood trim on the spice rack. Ill take and upload a better picture if anyone wants a better view of it.
_________________ Low Voltage Electrical Expert
ask me questions about your electrical setup!
if i was an eagle, i'd dress like a duck
crawl like a lizard and honk like a truck
- Jerome Garcia |
ProspectiveOwnergon Samba Member
Posted: Tue Jul 27, 2021 11:42 am Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
chrismsnt wrote: |
Van Diesel has two OEM factory installed tire carriers (I'm told it's the only known one left in the world but who knows?)
PLEASE PUT GOOGLY EYES ON THESE TIRES!!! |
mattfinlayson Samba Member
Joined: July 12, 2021 Posts: 1 Location: Portland, OR
Posted: Tue Jul 27, 2021 12:49 pm Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
Morrison has a self portrait on the rear window. Installed by the PO, at first I was going to remove it, but everyone who's seen it has commented on it, so maybe it's here to stay.
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Steve M. wrote: |
Recycled truck tire as an air dam.
I like it, have you done a write up on it, how did you do it? |
syncro surf Samba Member
Posted: Wed Jul 28, 2021 11:31 am Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
Quote: |
I built this badgless grill and I think it's the 1st thing I did on my doka.
I wanted it to look like a mk1 golf grill.
It's lasted since 2004.
Adjusters and the connectors are still intact and used as normal.
Nobody even notices it. I had to point it out at a VW meet.
The square frame with the round light really bugs me so it had to go. |
This is fantastic. That is how the grills should have been from the factory. I have a round headlight grill on my syncro and I am also bugged by the squares. I'd love to see more about how you did this. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Wed Jul 28, 2021 3:01 pm Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
chrismsnt wrote: |
As I look at your picture again (perhaps it's the angle), but does your carrier lock at 90 degree out? My pic where I'm washing my van, they're in the locked out position. I cannot swing them in without pushing a metal unlock mechanism. Just curious now... LOL |
No, mine does not lock and was swinging freely until I put a roll pin in to keep the tire from hitting the rear side.
The ways your lock at 90 degrees makes it too confining for my taste!
"my74ghia" had dual tires mounted on the rear back some years ago, but may have pulled one off to save weight
During the last 5-7 yrs. lots of guys were adding the big bumpers and winches and after a while the concensus was that the added weight may have been contributing to transaxle failure. At 5g's a throw to rebuild one it was worth thinking about.
So what followed was adding a cooling system to the gearbox and also some guys removing the extra weight.
Do a search on cooling the Syncro gearbox, because it does make a difference. For example I have 5.83 R&P ratios on My Syncro 16 spinning 225/75-16 tires and without the cooling system the gearbox temps have gotten up to 177 degrees on hot days. With the cooler installed temps are right now in summer 90 degrees ambient I'm seeing 135-140 degrees in my gearbox. _________________ This free advice is worth exactly what you paid for it.
Merian Samba Member
Posted: Wed Jul 28, 2021 4:39 pm Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
Lutefisk stickers _________________ .... |
truckersmike Elder Sambanite
Joined: March 16, 2001 Posts: 2025 Location: Bellingham, WA
Posted: Wed Jul 28, 2021 6:25 pm Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
djkeev wrote: |
Robw_z wrote: |
truckersmike wrote: |
Rotary powered 82 done by PO. Can't find any like it.
[img]https://www.thesamba.com/vw/gallery/pix/1945139.jpg[/] |
Wow, in my mind you win. That’s something I never expected to see. How does it drive?
-Rob |
It probably goes hmmmmmmmmm ........
Dave |
It does go hmmmmmmmm, kind of like a swarm of bees. As far as power goes, it pushes the van pretty well, especially around 3-4k. Just drove it up a very steep and long hill in town and it maintained 30mph at 3k in third. Can't imagine the OG diesel doing that. _________________ 59 DD panel. Former Romano's TV delivery bus
67 Westy SO-42 pop-t |
0cean Samba Member
Joined: February 29, 2012 Posts: 1149 Location: California
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3099 Location: ABQ NM USA.... Except when not
Posted: Wed Jul 28, 2021 8:23 pm Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
0cean wrote: |
A 35 gallon gas tank and all leather interior. Glamping at its finest.
where/how did you mount that thing...and how did you pipe/connect it? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Thu Jul 29, 2021 3:01 am Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
You never know when you are 10 hours from nearest fuel _________________ .ssS! |
Posted: Thu Jul 29, 2021 6:06 am Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
djkeev wrote: |
Abscate wrote: |
You never know when you are 10 hours from nearest fuel |
Fuel range anxiety
I have it, but not 35 gallons bad. 20 gallons would be a relaxing quantity for me.
Dave |
I've driven all across the US, western Canada and Alaska on a stock 40l tank in my split Westy and never ran out of gas before hitting the next station. To be sure, I carried a 20l spare on the roof rack but I only used it once in nowhere Alaska because the gas price was over $5/gallon. _________________ 59 DD panel. Former Romano's TV delivery bus
chrismsnt Samba Member
Joined: March 06, 2018 Posts: 247 Location: Cumming, GA
Posted: Thu Jul 29, 2021 6:12 am Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
I've driven all across the US, western Canada and Alaska on a stock 40l tank in my split Westy and never ran out of gas before hitting the next station. To be sure, I carried a 20l spare on the roof rack but I only used it once in nowhere Alaska because the gas price was over $5/gallon. |
...but have you driven off road into the bush country where roads don't exist? _________________ Chris
1989 T3 Vanagon 16" Syncro
1967 Squareback
https://vwvandiesel.com
Instagram @VW_VanDiesel |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Thu Jul 29, 2021 7:01 am Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
At 18k/year, the stock vanagon gas tank has me at the gas station twice a week. On the other hand, when I fill the Yukon's 32 gallon tank I really feel the sting. $150 and the damn thing still isn't full
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Posted: Thu Jul 29, 2021 8:29 am Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
chrismsnt wrote: |
...but have you driven off road into the bush country where roads don't exist? |
Definitely! All over the desert and high mountains of AZ and 5 SST'S. Just a 20l can is all I've ever needed. Recently, i was going to install a bay tank in my split but i abandoned the idea because the benefit wasn't there. Plus, having a spare can on the roof rack looks tuff _________________ 59 DD panel. Former Romano's TV delivery bus
0cean Samba Member
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Thu Jul 29, 2021 11:28 am Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
A PO of my bus put this wing ding in to prevent accidental opening of the top. Have not seen it in any other pictures of pop tops. When I get the gumption to fix the rust on that handle, I will get some good shots of how he built it.
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2331 Location: Southeast Kentucky
Posted: Thu Jul 29, 2021 12:12 pm Post subject: Re: What is Distintive About Your Vanagon That No One Else Has? |
Zeitgeist 13 wrote: |
It's probably easier to describe what my van still has in common with other vans out there, than its distinctive features. Nearly every mod is custom, rather than a bolt on off the shelf vendor product. I highly doubt there are many other Bluestars out there setup similar to mine...which is probably a good thing for them, since mine looks like shit right now. Seventeen years of sitting outside has taken a toll on the ol brick. |
Zeitgeist, back in the mid-first Decade of this century, I purchased an 84 Tin-top (as you know) that also looked like crap as well. I got it for less than $700.00. It's purpose was to be used on long road trips to Alaska after I retired ....and we did make two! The Alaska Highway is brutal as well as the many back and side roads we've traveled. Unfortunately, our dream to do far more long road trips has not come to pass... maybe one more! And, yes, it still looks like crap, but it is capable of making a long road trip (2022 is on the radar).
Something unique about my Tin-top 84.
The pic below is of a Dakota Digital Interface used to "tune" the speed signal from a VW Jetta VSS mounted on the Vanagon Ticker Box. The speed signal from the Interface goes to the Jetta Cluster which is mounted in place of the Vanagon Cluster. The Interface is behind and below the Cluster. The results are extremely good.. about 99.999% accurate! And, of course, the signal keeps the ALH TDI engine on Cruise very steady.
_________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
