Jonasand Samba Member
Joined: September 07, 2016 Posts: 239 Location: Sweden
Posted: Mon Jul 26, 2021 2:48 pm Post subject: Bent vacuum hoses do they have part numbers? |
I need to replace these bent hoses in the picture below, they are attached to the S-boot. Three of them.
They are bent in a particular way, can I replace them with a generic vacuum hose or are there pre-bent hoses with individual part numbers that I can get?
If so does anyone have a links or part numbers? _________________ 79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jul 26, 2021 3:23 pm Post subject: Re: Bent vacuum hoses do they have part numbers? |
Thanks busdaddy, however I’m in sweden so shipping would take too long. Also they were very expensive at 300 dollars, even if great quality, its still just some hoses!
Is the exact shape of the bends on these hoses needed for proper function, or can they be replaced by same length and diameter generic vacuum hose? _________________ 79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters |
Cap10323 Samba Member
Posted: Mon Jul 26, 2021 9:33 pm Post subject: Re: Bent vacuum hoses do they have part numbers? |
Unfortunately these are long NLA and very expensive to buy the hand wrapped silicone replacements.
What you can do is to go to your local auto parts store, and see if they will let you rummage through the various heater hoses in the back room. I was able to get one that was very close to the one that looks like a letter J, and it cost about $6 USD.
When the smaller one needs to be replaced, I'll be doing the same thing. _________________ -Ian
'77 Westfalia - 2.0 F.I |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1731 Location: Portland
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Mon Jul 26, 2021 11:47 pm Post subject: Re: Bent vacuum hoses do they have part numbers? |
What’s the ID on each piece? Can you take pictures with a scale in the picture?
Volvo has a lot of evap hose in close shapes to these. _________________ .ssS! |
AshC Samba Member
Joined: January 07, 2021 Posts: 59 Location: N. Essex, UK
Posted: Tue Jul 27, 2021 3:08 am Post subject: Re: Bent vacuum hoses do they have part numbers? |
I used someone else's tip from here and used some good quality hose and a "spring former" at the tight bend for the decel hose e.g.
https://www.carbuilder.com/uk/former-for-24mm-od-heater-hose
For the S-boot to breather valve I used a 90deg elbow and two pieces of hose.
These were temporary fixes that became permanent, although for the 'elbow' setup on the breather I'd rather find a hose with a 90deg bend and do that one better. _________________ - 79 CA FI Bay Window Bus
- 92 Mk1 Golf Cabriolet |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Tue Jul 27, 2021 5:30 am Post subject: Re: Bent vacuum hoses do they have part numbers? |
if 300 hurts, you are in big trouble. |
Posted: Tue Jul 27, 2021 5:52 am Post subject: Re: Bent vacuum hoses do they have part numbers? |
Abscate wrote: |
Volvo has a lot of evap hose in close shapes to these. |
If you by ID mean part numbers, I'm sorry I cant find part numbers for these
Type 4 2.0 L FI
Hydraulic lifters |
Takamotti Samba Member
Posted: Tue Jul 27, 2021 6:04 am Post subject: Re: Bent vacuum hoses do they have part numbers? |
How about converting it to european style breathing system and getting rid of those? EU version has just one hose, and that you can get from Biltema or where ever... 300 for breather hoses is absolutely ridiculous
EDIT: ok now that I look at your latest pictures aren´t some of those EGR hoses? well, it´s not also mandatory to have all that in an old car in europe.
Posted: Tue Jul 27, 2021 6:10 am Post subject: Re: Bent vacuum hoses do they have part numbers? |
Good advice, thanks everyone, now I know what to look for!
Unfortunately, amazon and other links to resellers in the US are a no go as the delivery time is too long. (I'm in Sweden). But thanks anyway for the links. Good for getting an idea of what to look for. That bendable coil thing looks fantastic! Not sure if I can source them here in Sweden, but I'll look into it.
I'll try Volvo and if they cant help me some other shops around here. _________________ 79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters |
AshC Samba Member
Posted: Tue Jul 27, 2021 7:21 am Post subject: Re: Bent vacuum hoses do they have part numbers? |
Below is a picture using the hose former (as mentioned I borrowed this solution from another samba member). Not perfect, but it works.
The supplier I linked in the earlier post is in the UK and I assume ships to EU. I have no affiliation to them, but they are very quick usually. Happy to dig out what size and hose I used.
cmonSTART Samba Member
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Tue Jul 27, 2021 9:06 am Post subject: Re: Bent vacuum hoses do they have part numbers? |
Some soft copper or aluminum pipe, a bender and straight sections of hose to connect it to the devices will be fine.
A place that makes hydrulic hoses can fab up the bent sections and then you just need to add the connector hoses. |
germansupplyscott Samba Member
Posted: Tue Jul 27, 2021 9:10 am Post subject: Re: Bent vacuum hoses do they have part numbers? |
Abscate wrote: |
The oil breather hose (L-shaped) is 022 129 973C. It's 22mm ID.
The decel valve hose (C-shaped) is 022 201 919. It's 18mm ID.
My company sells an 18mm cloth covered hose which works well to replace the C-shaped hose, you need to use a longer straight piece than the curved part (460mm long). I have tried for years to find a good replacement for the L-shaped breather hose, unsuccessfully.
The molded hoses made by GeeBee and sold here are very good. _________________ SL |
Posted: Tue Jul 27, 2021 3:49 pm Post subject: Re: Bent vacuum hoses do they have part numbers? |
Takamotti wrote: |
Very interesting...
so you are saying I could eliminate some of the hoses? Are they not part of the L-tronic FI system on the 79 bus? What hoses could I remove?
If that can be done without ill effect that would be a good solution... _________________ 79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Tue Jul 27, 2021 6:39 pm Post subject: Re: Bent vacuum hoses do they have part numbers? |
Couple interesting ideas here.
When I installed FI in my '73, none of the formed hoses I had were any good. So I made up a mish-mash with some copper pipe (though when I tried formable copper tubing, it was very difficult for me to get a good shape made and I abandoned that idea), clear vinyl tubing, rubber hose, and angled connectors. It works, I guess, but it looks like kind of a mess.
I kept telling myself I'd spring for the silicone set, but like someone else said, the "temporary" setup seems to have become permanent. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Tue Jul 27, 2021 11:57 pm Post subject: Re: Bent vacuum hoses do they have part numbers? |
On the Volvo P80 line , 1992-2000, later years 1998-2000 there is anZl shaped and Long U shaped hose in the evap system thst is 18 mm ID that might work well here. Pics and part numbers to follow _________________ .ssS! |
Posted: Wed Jul 28, 2021 1:34 pm Post subject: Re: Bent vacuum hoses do they have part numbers? |
Abscate wrote: |
On the Volvo P80 line , 1992-2000, later years 1998-2000 there is anZl shaped and Long U shaped hose in the evap system thst is 18 mm ID that might work well here. Pics and part numbers to follow |
Thanks, that would be helpful...
Also got a tip from a friend that the company Hydroscand in Sweden delivers fuel hoses to Volvo and from their website I can see that they seem to have products for pneumatics and hydraulics. So I will try to ask them if they can help me.
I have to be sure of all lengths and diameters of different vacuum/fuel hoses in my bus. So then I can buy everything from them. They have ethanol resistant hoses, so thats good, not sure of the ones you can get from vw stores.
Is there a complete list of hoses with diameters for the 79 FI bus?
Ratwell lists the 78 bus, but its not clear to me what the differences are to my 79?
Or should I just measure all hoses with my caliper? Seems it would be best to have all the part numbers and diameters. _________________ 79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Wed Jul 28, 2021 11:25 pm Post subject: Re: Bent vacuum hoses do they have part numbers? |
Unless your ‘79 has an automatic transmission and the weird electronic decel valve, all the hoses are the same as a ‘78.
The GeeBee hoses cost three times as much but last ten times as long. You do the math…
www.airschooled.com |
