arizonabuckeye Samba Member
Posted: Thu Mar 16, 2017 6:29 pm Post subject: Roller rocker question |
Finally worked my way through my project and got to adjusting the valves. Got one and two good (zero clearance on my roller rockers) and started on 3. Was tightest so far so tight I couldn't twist the pushrods at all. Backed out the adjuster a bit and got it to twist but no in/out play. Then I pushed on the bottom of the rocker only to have the pushrod deflect and come off the adjuster - had to tighten it back down to get it to stop deflecting off the adjuster. Is that a bad deal? What's the next step? |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Thu Mar 16, 2017 6:34 pm Post subject: Re: Roller rocker question |
Do the ends of your pushrods have enough clearance for when the rockers fully open and close? |
Posted: Thu Mar 16, 2017 6:38 pm Post subject: Re: Roller rocker question |
How would I check? |
Posted: Thu Mar 16, 2017 6:57 pm Post subject: Re: Roller rocker question |
could the adjuster foot be worn out? Is that a pull the valve train to replace sort of an issue?
How do they look? |
mark tucker Samba Member
Posted: Fri Mar 17, 2017 6:51 pm Post subject: Re: Roller rocker question |
they look fine, look for marks on the pushrods where they were contacting the pushrod tube. something may of bent a tube, Ive even seen the cooling tin come loose and cause issues. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sat Jul 24, 2021 7:36 pm Post subject: Re: Roller rocker question |
so who makes roller rockers besides pauter these days in the 1.25/1.3 ratio?
are there any rockers from the v8 crowd that fit push rod to stem alignment that could work with a custom size rocker shaft diameter?
thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Sat Jul 24, 2021 9:44 pm Post subject: Re: Roller rocker question |
Nope _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Sun Jul 25, 2021 9:29 am Post subject: Re: Roller rocker question |
jessel,t&d will ig you have the $ for them to do so.probably others too. some of the v8 race rockers are very close. heck just get some aluminum and whittle some out. |
Posted: Mon Jul 26, 2021 7:24 pm Post subject: Re: Roller rocker question |
well dang. thanks tho.
i saw a set of sig erson old school rollers in the classifieds a few months back. the arms looked to be forged steel. adjuster at the rod end obviously. hope to see another set pop up. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Mon Jul 26, 2021 7:28 pm Post subject: Re: Roller rocker question |
mark tucker wrote: |
i briefly thought of making my own once i wrap up the cnc, but if i did being me id have to take it a notch further and add a hydraulic mechanism or something in there too. actually, maybe thats not a bad idea. light solid lifters with no valve adjustments. better have good psi at the rockers tho for them to expand fast. hoover mods to the rescue? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
slalombuggy Samba Member
Posted: Mon Jul 26, 2021 7:58 pm Post subject: Re: Roller rocker question |
Chickensoup wrote: |
i briefly thought of making my own once i wrap up the cnc, but if i did being me id have to take it a notch further and add a hydraulic mechanism or something in there too. actually, maybe thats not a bad idea. light solid lifters with no valve adjustments. better have good psi at the rockers tho for them to expand fast. hoover mods to the rescue? |
Most guys who run Pauter rockers drill a hole in the rocker end of the pushrod to spray oil onto the springs as not enough travels through the rocker to the valve side. That would bleed off too much pressure for a hydraulic adjuster at the head end. |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Tue Jul 27, 2021 7:03 am Post subject: Re: Roller rocker question |
sounds to me like the pushrod is rubbing against a pushrod tube.
It will make adjustments seem funny like that.
Remove the rockers and inspect the pushrods for rubbing or they may be bent. Look for that too.
Hands down. Pauter are among the best you can buy.
I have very few issues setting them up normally. |
