Ins and Outs of Installing a 356 Engine in a 1962 Sedan
Larmo63
Larmo63 is offline
PostPosted: Mon Jul 26, 2021 9:48 pm    Post subject: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
I know there is body work involved, what are the pros/cons?
Lawrence
‘61 Mango Green Single Cab
'62 Pearl White Ragtop sedan
'66 Ruby Red Cabriolet
'86 Porsche 911 Carrera
slalombuggy
slalombuggy is offline
PostPosted: Tue Jul 27, 2021 5:09 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Con - you can build a 200hp type 1 for the cost of a 356 engine and have a big chunk of change left over.
Pro - nothing.
greek_tony
greek_tony is offline
PostPosted: Tue Jul 27, 2021 5:44 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Pros - Period correct vintage power
Cons - Sit down first and check out the price of parts for a rebuild if its ever needed Shocked
1963 Karmann Ghia - Sold
May 53 Ragtop - Resto started
October 65 Fastback - Almost there.
John Moxon Premium Member
John Moxon is offline
PostPosted: Tue Jul 27, 2021 6:50 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Pro - nothing.
Ah but if we all thought that, there would be no need for a "Vintage Speed" forum Brad. We're not looking for the best solution, Laughing
John.
Braukuche
Braukuche is offline
PostPosted: Tue Jul 27, 2021 7:22 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
John Moxon wrote:
Pro - nothing.
Yeah complaining about the price of speed doesn’t belong in this forum, save it for the high performance engine forum.
AFAIK there is no need to cut anywhere but I will defer to someone who’s done it. I have the same plan for a 62 Ghia so I’m curious too. I do know it will require getting creative with the tins and linkage.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
slalombuggy
PostPosted: Tue Jul 27, 2021 8:41 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Not complaining about price. Just want the OP to know the price of P parts is rather elevated. Personally I'd hotrod a 40 horse . With modern parts you could have more hp and still look period correct. No need to spend 10K more for a tilted generator stand base and similar performance.
I've helped build a couple of pretty quick 1200s and one really fast 36hp for land speed racing that used a Pre-A case, offset ground Porsche crank with Chevy journals, h-beam rods, 1500 pistons and Okrasa heads. You haven't lived vintage performance till you've hand carved and profiled the fins on 4 cast iron cylinders to fit the 36hp stud pattern.
Chickensoup
Chickensoup is offline
PostPosted: Tue Jul 27, 2021 9:19 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
its a cool idea, and IMO the porsche engines look decently sexy, but... not practical if your looking for speed.
if vintage speed is life to you then go ahead. But be ready to lay down some big bucks.
-'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge"
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jul 27, 2021 9:28 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
It's been done.
Go BIG or go home.
Glenn
Member #1009
#BlueSquare
D. Haviland
D. Haviland is offline
PostPosted: Tue Jul 27, 2021 9:38 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Glenn wrote:
It's been done.
Go BIG or go home.
Go big or go home?!! how about go huge!!!
Chickensoup
PostPosted: Tue Jul 27, 2021 9:42 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Glenn wrote:
It's been done.
Go BIG or go home.
hmmm... sounds more like go broke and go home to your tent lol.
i think 4 cams are going for 30k-50k?
'66 RIP
'69 RIP
D. Haviland
PostPosted: Tue Jul 27, 2021 11:04 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Or more
Mr. 010
Glenn is offline
PostPosted: Tue Jul 27, 2021 11:58 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Try $220,000
https://bringatrailer.com/listing/1955-porsche-4-cam-carerra/
Glenn
Member #1009
#BlueSquare
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Tue Jul 27, 2021 12:21 pm    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Pros...if thats your dream do it
Cons ...haters
5500
5500 is offline
PostPosted: Tue Jul 27, 2021 1:02 pm    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
My 57 had a 356 normal in it when I bought it. Fit in the engine bay without trimming either VW sheetmetal or stock engine tin and bolted up to the split case transaxle. I don't think the valve covers would come off without dropping the engine though. Carb linkage was stock Porsche (shroud mounted vertical action) on the engine with the addition/modification of a bellcrank (not sure of source) to mate the VW cable. I sold the engine back to the seller (including exchange for a running 36hp motor). By the time I finish my correct date coded vintage speed 1397 (with 32 NDIXs and a sebring style exhaust) I will have spent about as much as it would have cost to keep the 356 engine and refresh the top end plus carb rebuild. Its about what you want so go for it!
5500
5500 is offline
PostPosted: Tue Jul 27, 2021 1:06 pm    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Glenn wrote:
It's been done.
Go BIG or go home.
Glenn, I get wood every time I see this posted Very Happy Very Happy Very Happy
Braukuche
PostPosted: Tue Jul 27, 2021 3:42 pm    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
I hear you, Porsche parts are nutty expensive, and if you have to factor in buying a core then it’s really going to be pricey. Though you can cut some costs if you are using a B crank with modified 36 hp bearings and if you are using AApistons and cylinders vs Mahle or Bireals etc.
If you have the core then it’s not going to be any more expensive than doing a 36hp Okrasa conversion. Ask me how I know…assuming of course you can build your own engine.
As for HP gain a S spec 356 engine will get around 75 hp a Super 90 of course 90 and a SC a bit over 100hp which is near impossible in a streetable 36hp based engine.
Again none of this makes any sense, a much cheaper 1600 based engine can do all that easily for less but that’s not the point of vintage speed.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
slalombuggy
PostPosted: Thu Jul 29, 2021 7:42 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Glenn wrote:
Try $220,000
Reserve wasn't met at 220. The last one I heard of that changed hands was in the $250K range and was dyno tuned by a friend of mine.
RolandD
RolandD is offline
PostPosted: Thu Jul 29, 2021 7:36 pm    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
With 3D printing of lost wax , it would be quite feasible, and economically rewording, to do short repro runs of those parts. A tombstone on a horizontal CNC could finish then with ease.
Crazy Roland
frenchroast
frenchroast is offline
PostPosted: Thu Jul 29, 2021 7:53 pm    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Here's a nice one. Not sure if that's euro's, dm's, or usd's. Shocked https://www.thesamba.com/vw/classifieds/detail.php?id=2487587
FarmerBill
FarmerBill is offline
PostPosted: Fri Jul 30, 2021 6:28 am    Post subject: Re: Ins and Outs of Installing a 356 Engine in a 1962 Sedan Reply with quote
Capricorn Automotive made a reproduction of the 4-cam about 10 years ago for the low, low price of about $150,000. They probably still do but it probably costs more now.
