Gothard Samba Member
Joined: October 27, 2010 Posts: 7 Location: Swiss Alps
Posted: Tue Jul 27, 2021 3:23 am Post subject: '59 engine rebuild, need new cam - question |
I am in the dismantling phase of my '59 1200 engine, #3359594, and the camshaft is badly worn.
Getting info from the local resellers in Europe is like pulling teeth.
Does anyone have an equivalent reference to replace the camshaft? The shaft has number 111 109 101, and the pulley has number 111 109 111 and is group +2.
Any insight welcome. I understand I might have to move the sprocket wheel over to the new shaft? |
Dan22 Samba Member
Joined: August 30, 2019 Posts: 464 Location: Battle Ground, WA
Posted: Tue Jul 27, 2021 8:26 am Post subject: Re: '59 engine rebuild, need new cam - question |
I found a NOS cam in the classified and had to swap the gear over. I suggest keep checking this site for ads at least. May have to ship from the US or other country. An air hammer worked good for setting the rivets, in my case.
WW has unground blanks you can take it to a cam grinder to replicate stock profile too. _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Tue Jul 27, 2021 9:04 am Post subject: Re: '59 engine rebuild, need new cam - question |
NOS is gonna be your best bet. there are german cams and brazilian 36hp cams.
IF you buy a made in brazil cam, make sure to chamfer the edges. they are known to be really rough around the edges of the cam lobes.
WW also makes a performance cam which could work well if you change some other factors. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Danwvw Samba Member
Posted: Thu Aug 05, 2021 1:57 pm Post subject: Re: '59 engine rebuild, need new cam - question |
Maybe go to classified Search and type in 36 cam or just 36 and browse the adds, I am rebuilding my 36 horse too. It’s a 1960 Beetle. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Sat Sep 24, 2022 2:27 am Post subject: Re: '59 engine rebuild, need new cam - question |
Back at it, and please bear with me, it is my first beetle rebuild:
I got a new camshaft, not NOS. It has 3 threaded holes (M to attach to the original sprocket that align with the sprocket holes, that are smaller (7mm?), AND 3 locating pins. So:
-Do I remove the locating pins and rely on the 3 M8 bolts to hold the cam on the sprocket, or machine drill the sprocket for the pins?
-Can I drill the sprocket rivet holes to 8mm to attach the cam?
- I marked the sprocket when I removed the worn cam, but the sprocket only. I *think* I marked the sprocket aligned with the first cam lobe, but can't remember, it was a while ago... Any method to align the cam correctly on the sprocket? |
my59 Samba Member
Joined: August 13, 2003 Posts: 3790 Location: connecting the dots
Posted: Sat Sep 24, 2022 9:23 am Post subject: Re: '59 engine rebuild, need new cam - question |
I just uploaded photos from my 1958 shop manual, that show the section about the cam that should help.
_________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
tcoop1100 Samba Member
Joined: August 12, 2004 Posts: 194 Location: Hilo, Moku O Keawe, Moana Pakipika
Posted: Sat Sep 24, 2022 6:55 pm Post subject: Re: '59 engine rebuild, need new cam - question |
The gear backlash spec for the cam shown in that manual is wrong- it should be 0.000 to 0.002", not 0.020" _________________ Aloha,
Tim
January '57 Sedan with April '64 40hp big bore |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Sun Sep 25, 2022 9:31 am Post subject: Re: '59 engine rebuild, need new cam - question |
Gothard wrote: |
I don't recall seeing a VW camshaft with locating pins before, they normally just use rivets or bolts and washers to attach and align the cam gear.
Yes, you can drill the cam gear rivet holes out so as to use the 8mm bolts to attach the gear to your cam. You will probably need to face the gear around the bolt holes or shave the bolt heads to allow clearance between the oil pump housing and the cam gear bolts as well. See the following: https://www.thesamba.com/vw/forum/viewtopic.php?p=9354522&highlight=#9354522
The oil pump drive slot in the end of the cam should line up with the cam gear alignment mark when you attach the gear.
_________________ 1960 Ragtop w/Semaphores "Inga" |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 878 Location: Lanark County, Ontario, Canada
Posted: Sun Sep 25, 2022 2:09 pm Post subject: Re: '59 engine rebuild, need new cam - question |
If the cam hub has 3 threaded holes and 3 pins, it is probably from an early Porsche. Are the cam lobes also wider than on the old VW cam? The hub might also be marked "369". _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
