Grinding on rebuild
Orangebug65sunroof
Orangebug65sunroof is offline
PostPosted: Sat Jul 24, 2021 8:01 pm    Post subject: Grinding on rebuild Reply with quote
65 with 1600 recently rebuilt on the cheap. 50 50 chance it would work but looks like it’s going to need to be redone. Any advice opinions are welcome. Wherever this takes me I’d be keen on sharing the journey as I’m new to being a member but not new to the forums.
Here is the story.
Buttoned her up and installed an external oil filter. Little clearance on the belt pulley so had so shave some tin. Other than that started fine and timed. Did notice the gen light saying on and after about half hour of driving loss power but idle was fine. Limped home. Swapped out the alternator 12v but no luck light still on. Then the squealing grinding started. Thought it was the belt pulley hitting the oil pump but not the case. Sounds internal with some smoke coming out the oil breather/ carb.
So something is not right, clearly.
Next step pull engine and start over?
Pruneman99
Pruneman99 is offline
PostPosted: Sat Jul 24, 2021 9:08 pm    Post subject: Re: Grinding on rebuild Reply with quote
Pull off the alternator belt. Start the engine just for a few seconds to see if the noise stopped.
Orangebug65sunroof
PostPosted: Sun Jul 25, 2021 5:42 pm    Post subject: Re: Grinding on rebuild Reply with quote
Yes sorry I should have mentioned that I tried running the engine without the pulley and the grinding is definitely internal occurs within 1min of running. Guess is a crank bearing that is not getting oil… maybe slipped off the dowel…turns over by hand just fine.
Dang really not looking forward to pulling the engine again.
Will post a photo but should have held a poll Rolling Eyes
Orangebug65sunroof
PostPosted: Wed Jul 28, 2021 6:15 pm    Post subject: Re: Grinding on rebuild Reply with quote
Just found out I accidentally flipped the generator and oil pressure lights. Therefore, I had a low oil pressure issue from the start, which would explain the grinding Embarassed
Anyone out there ever run into low oil pressure from an external oil filter instal? There is oil going to the filter but it does not look like as much as you would expect….
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Wed Jul 28, 2021 6:31 pm    Post subject: Re: Grinding on rebuild Reply with quote
Bearings don’t slip off dowels
Dougy Dee
Dougy Dee is offline
PostPosted: Thu Jul 29, 2021 9:18 am    Post subject: Re: Grinding on rebuild Reply with quote
You say "installed an external oil filter".
Full flowed case or filter pump setup?
Orangebug65sunroof
PostPosted: Sat Jul 31, 2021 10:09 pm    Post subject: Re: Grinding on rebuild Reply with quote
Surprised no guesses.
Threw a rod because oil pump intake was blocked Embarassed
Fun getting that off and stoked about taking one step forward and two steps back Rolling Eyes
Does anyone know where I can pick up a single connecting rod and with bearings?
dustymojave
dustymojave is offline
PostPosted: Sun Aug 01, 2021 9:52 am    Post subject: Re: Grinding on rebuild Reply with quote
Bearings come as boxed sets.
Rods may be available separately, although they too are generally sold in sets. If you did damage to one rod's bearings, You may as well replace ALL of the bearings, main, rod and cam.
What was it that was blocking the oil pump intake?
And you did not answer the question above as to what sort of external oil filter.
Is it a filter-on-pump?
Is it from the top of the case stock oil cooler location?
Is it an out & back in oil pump?
Is it full flowed?
Question Question Question
Richard
SoCalBajas Member
PostPosted: Sun Aug 01, 2021 10:02 am    Post subject: Re: Grinding on rebuild Reply with quote
Plenty of good used rods out there and try to find one close to the weight of the other 3. You might even find some bearings but I think it would be easier to just buy another set. How’s the crankshaft journal look?
Concerning replacing all the bearings I’d give them a real close visual inspection looking for any kind of foreign material embedded. I’d also think about using a different oil cooler. Another wild card? You might want to consider cleaning out the oil passages in the case halves.
Pictures would help us help you.
Orangebug65sunroof
PostPosted: Sun Aug 01, 2021 1:10 pm    Post subject: Re: Grinding on rebuild Reply with quote
Sorry y'all didnt see these other replies.
It is a spin on cheaply aftermarket oil pump and filter.
Pretty sure my culprit was another aftermarket spring piece that was blocking the pickup. When I found it Embarassed
Point here is to not run and identify the obstruction if your oil pressure light come on.
Learning the hard way here.
So is there consensus about replacing all rods? Others seem fine. Just the one is fried and the journal has some melted on bearing that I'll try to sand off.
If a photo would help I can post once I get to it.
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Sun Aug 01, 2021 1:33 pm    Post subject: Re: Grinding on rebuild Reply with quote
Most here cannot read. But post a pic. And you'll get plenty of advice. Very Happy
Besides, we love to see carnage pics. Sick fucks, we are! Shocked
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Orangebug65sunroof
PostPosted: Sun Aug 01, 2021 6:34 pm    Post subject: Re: Grinding on rebuild Reply with quote
Welcome to my second shit show
[/img]
Orangebug65sunroof
PostPosted: Sun Aug 01, 2021 6:38 pm    Post subject: Re: Grinding on rebuild Reply with quote
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Sun Aug 01, 2021 6:44 pm    Post subject: Re: Grinding on rebuild Reply with quote
It made a "grinding" noise ? Shocked
Orangebug65sunroof
PostPosted: Sun Aug 01, 2021 6:53 pm    Post subject: Re: Grinding on rebuild Reply with quote
Close up of bearings from position 1. Cranked rod was 4.
I'd say I'm good Wink ,
How close does the rods have to be?
Closest # I can give is 1lbs 4.4 oz
Orangebug65sunroof
PostPosted: Sun Aug 01, 2021 6:56 pm    Post subject: Re: Grinding on rebuild Reply with quote
Bearings cleaned up nicely.
Smooth even!
Must be that 20+ years of grime.
Wifey callen...thanks again everyone get lonely up here.
Dougy Dee
PostPosted: Mon Aug 02, 2021 5:10 am    Post subject: Re: Grinding on rebuild Reply with quote
578.33 grams. give or take...
Orangebug65sunroof
PostPosted: Mon Aug 02, 2021 9:13 am    Post subject: Re: Grinding on rebuild Reply with quote
Just noticed bearing photo did not post.
dustymojave
PostPosted: Sat Aug 14, 2021 1:56 pm    Post subject: Re: Grinding on rebuild Reply with quote
Are you SURE that rod is bad? It should buff out, shouldn't it?
Lifter faces look pretty gronked too.
Looks like you're up for a complete rebuild. Rolling Eyes
Richard
SoCalBajas Member
Orangebug65sunroof
PostPosted: Tue Aug 31, 2021 7:31 pm    Post subject: Re: Grinding on rebuild Reply with quote
Update:
Picked up a rod from a local saint.
Bearings for the rods.
Buffed out the old melted bearings.
Feeling super proud putting the crank in the cleaned case and WTF
The crank doesn’t want to rotate…
Come on…the crank bearings adjacent to the gears are seized!
Guess since they are aluminum they shrunk when they heated up?
Oh and the case looks to have been thrust cut to 2mm and that bearing has quite a bit of play….
Worth going forward or cut my losses?
At this point it’s learning and brings back memories of working on small engines.
