KKiley Samba Member
Joined: March 08, 2016 Posts: 662 Location: Aruba, Jamica, nope, Kokomo
Posted: Wed Jul 28, 2021 8:28 pm Post subject: 78 Super engine upgrade |
After truly enjoying my FI 78 Super for the 2 years, looks like it's going to be time to drop the engine and check out a clutch or bearing noise in the rear. I haven't needed the wrenches out in a while, which is a great thing. But this noise in the rear is getting my attention.
Since I an not in CA anymore and don't have to deal with CARB , I think it's time for an upgrade. I just need more performance out of this engine and this would be the time to do it. The fuel injection is the bomb.
I am thinking a 1776 upgrade and/or a cam would liven things up. I am a huge fan of cams, they make life so fun. If doing the cc upgrade would be good, that is easier. But not afraid to split the cases to get more fun.
If I do this, it's probably done for the summer. But I always have the Harley, lol.
I have seen Jimbo's videos and I want more umph, lol _________________ 1978 Super Beetle convertible
Click to view image |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Thu Jul 29, 2021 1:31 am Post subject: Re: 78 Super engine upgrade |
Even if you just put in 90.5 cylinders, you're still going to have to split the case.
I don't know much about the FI system, but I assume it has enough margin to be able to run, but I imagine cam changes must be made with caution.
I think the CB2280 was developed for just this purpose. |
Posted: Thu Jul 29, 2021 1:34 am Post subject: Re: 78 Super engine upgrade |
And you should take this to the performance engine forum, you'll get more (and better) info and opinions, and advice. |
KKiley Samba Member
Posted: Thu Jul 29, 2021 8:44 am Post subject: Re: 78 Super engine upgrade |
After thinking about this overnight, I think I and going to leave a good motor alone and just address the clutch issue.
But I think I might send the distributor our for a rebuild, as I don't think it's giving full advance. If I set it to where I am at 28*+ at throttle, my idle is way too high.
If I set it where the idle is lower, the performance feels lacking.
I think my time and labor would be better spent addressing those issues.
Fixing the odometer would be nice too. If I could just get my stubby fingers to get it removed from the dash, haha _________________ 1978 Super Beetle convertible
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Thu Jul 29, 2021 9:01 am Post subject: Re: 78 Super engine upgrade |
Sounds like a vacuum leak to me! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
KKiley Samba Member
Posted: Thu Jul 29, 2021 9:37 am Post subject: Re: 78 Super engine upgrade |
That was my 1st thought Jim, but I went over it with spray and idle never changed on any spot. And it will come down after it gets good and warm.
If i turn the timing down, it idles fine, just the performance is lacking.
I think I'll pull the distributor 1st and give it a deep clean and lubrication.
I have no idea what this grinding noise is, but it makes noise at slow speeds in and out of 1st gear.
Time for the floor jacks and motorcycle lift to get it dropped. _________________ 1978 Super Beetle convertible
Posted: Fri Jul 30, 2021 12:25 am Post subject: Re: 78 Super engine upgrade |
Pinch the AAR hose. Maybe it is staying open to long.
Or the decel valve is leaking, or the vacuum can at the distributor, or……
Pinch or plug everything! _________________ Jimbo
TDCTDI wrote: |
tommu Samba Member
Posted: Fri Jul 30, 2021 9:30 am Post subject: Re: 78 Super engine upgrade |
Smoke test is the only way I check for vacuum leaks now. You can DIY or, depending where you are now, find one for a good price on Ebay.
But - are you saying that once you time to 28 degrees at 3000rpm (hoses off) you can't bring the idle down with the screw on the throttle body? _________________ |
