Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Fri Jul 30, 2021 7:32 am Post subject: Re: Filter pumps |
Cusser wrote: |
The right side of the top cooling fin has to be trimmed flush so the pulley tin clears it.
Same in early 1980s with my Maxi2 from Claude's Buggies; when the casting was changed to CB Performance, same issue with that top fin.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76945 Location: Sneaking up behind you
Posted: Fri Jul 30, 2021 5:02 pm Post subject: Re: Filter pumps |
Well, after all that, the pump doesn't clear the A1 sidewinder header.
So going to change the pump to a remote filter. _________________ Glenn
Member #1009
#BlueSquare |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Fri Jul 30, 2021 7:18 pm Post subject: Re: Filter pumps |
Glenn:
CSP’s In-Out pump is pretty dang nice if he has the budget. |
Glenn Mr. 010
Posted: Fri Jul 30, 2021 7:23 pm Post subject: Re: Filter pumps |
txoval wrote: |
Glenn:
Got the CB... had a credit on the books so it cost almost nothing.
I'm gonna compare the 2 pumps and if i'm lucky, the holes line up and I just need to swap the covers. I think both are Schadek pumps. _________________ Glenn
Member #1009
#BlueSquare |
modok Samba Member
Posted: Fri Jul 30, 2021 8:28 pm Post subject: Re: Filter pumps |
The wider the gears, the more the thing sticks out.
CB oil pumps are not the same as shadec, there are at least three differences, see if you can spot them. |
Cusser Samba Member
Glenn Mr. 010
Posted: Fri Jul 30, 2021 9:30 pm Post subject: Re: Filter pumps |
modok wrote: |
Says Schadek in the pump.
Member #1009
#BlueSquare |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Fri Jul 30, 2021 9:56 pm Post subject: Re: Filter pumps |
It was a sign not to use the filter pump after all
On the other hand, there is no shame in going to town with a flap disc
...That's the point of buying cheap parts _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
modok Samba Member
Posted: Fri Jul 30, 2021 10:41 pm Post subject: Re: Filter pumps |
It's not the same part. It cannot be the same casting because all the holes are machined. The holes in "normal shadec" pumps are part of the casting, so it's not the same casting, not the same gears, not the same shafts, but yes it's made by the same company.
Is vw made by audi or is audi made by vw????
If the pope shits in the woods is it still holy shit or just regular? Jeez.
no big deal, it may fit, I don't know, I haven't bought any empi oil pump. I bet you didn't either. Gotta love customer supplied parts. |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sat Jul 31, 2021 12:10 am Post subject: Re: Filter pumps |
mark tucker wrote: |
mine fit well....but Im smarter than a oil pump and know how to make things fit properly with out throwing a fit. |
Why throw a fit, when you can throw tools/parts? |
Posted: Sat Jul 31, 2021 12:14 am Post subject: Re: Filter pumps |
And I'm not smarter than an oil pump: I don't work better when I'm under pressure. |
