John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Fri Jul 30, 2021 4:05 am Post subject: Re: '59 Karmann Ghia fever |
Registered for the Sunday car show:
Still awaiting parade news.
Now all we need is a car! _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
Trylon Samba Member
Posted: Fri Jul 30, 2021 1:59 pm Post subject: Re: '59 Karmann Ghia fever |
Spent hours today and got less done then we hoped.
Looked at “popping” in the hardware in the back (various hooks, engine lid cable, etc.). Each a no go for a variety of reasons to the point we said— ok, good enough for the show.
One question that keeps coming up is how to find existent screw holes that lie underneath some new finish piece. Have yet to come up with a good answer.
Tried to see how to fit the wind lace and again it is anything but clear. Here’s our best guess:
But, for now good enough for the show!
So we decided to simply “good enough for the show” pressure fit the side rear panels:
And dash cover (with grill)
There are some pretty convincing hole marks on the underside of the dash pad but we were simply not confident enough to poke them so the grab handle off look is “good enough for the show!”
Then disaster hit:
I was so proud when I found that styrofoam boxes I had could keep the wall mat in the correct shape I didn’t think it through enough to realize that they would stick together.
It does not come off except with acetone which takes the color off as well.
If I recall correctly, these mats are painted with some sort of flexible vinyl paint. Hopefully Luis will get back to us regarding the color code we need to match and we will repaint them.
All this seems just as stressful as any other work I have done on our car. Perhaps more so as this stuff shows and we are under a deadline.
It’s tough to build a car! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
moogie32 Samba Member
Joined: April 06, 2005 Posts: 663 Location: Connecticut
Posted: Fri Jul 30, 2021 2:36 pm Post subject: Re: '59 Karmann Ghia fever |
That windlace looks correctly installed to me. I only have experience with what Karmann was doing in August of 62 to go by but windlace and some carpet was tacked in place with little upholstery nails and where they were applied was randomly done. Areas where screws were inserted on the same pieces seem to be more consistent but I have still found variability, at least with the used pieces I have installed. If that area is hidden it's not a problem - I can't remember windlace having obvious tacks which weren't covered by something else. If you were hoping to somehow use the same holes in you sheet metal for new pieces I don't know how you could mark it from the back - it's usually pretty hard to get to the backs of those areas. Good luck - I remember a lot of angst during the installation of those pieces. _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
Doch leider musst du von uns gehn
Trylon Samba Member
Posted: Fri Jul 30, 2021 2:38 pm Post subject: Re: '59 Karmann Ghia fever |
moogie32 wrote: |
That windlace looks correctly installed to me. I only have experience with what Karmann was doing in August of 62 to go by but windlace and some carpet was tacked in place with little upholstery nails and where they were applied was randomly done. Areas where screws were inserted on the same pieces seem to be more consistent but I have still found variability, at least with the used pieces I have installed. In most cases I found myself making new holes since what would be obvious was on the outside of the trim. Carpets had more of a fudge factor. Good luck - I remember a lot of angst during the installation of those pieces. |
Thank you for the confirmation Moogie! Still going to wait on their actual installation but good to know you think we might be on the right track. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
mooopers Samba Member
Posted: Fri Jul 30, 2021 2:47 pm Post subject: Re: '59 Karmann Ghia fever |
That doesnt look right for a coupe. Its suppose to go all the way to the top, at least on a 1960 it does. Maybe different for a low light. Also there is a bracket at the bottom to hold it in (two screws for that). Then its all nailed in.
Like I said maybe its different for a lowlight but I believe is all the way to the top.
Goes behind on a 1960 to the top
Bracket
_________________ 1958 Beetle
1960 Ghia Coupe
1965 Volvo Amazon 131
1969 T2 Deluxe |
The aussie Trimmer Samba Member
Joined: July 05, 2006 Posts: 385 Location: Western Australia
Posted: Fri Jul 30, 2021 3:50 pm Post subject: Re: '59 Karmann Ghia fever |
that's upside down Mate.
Trylon wrote: |
Then disaster hit:
It’s tough to build a car! |
_________________ Cheers,
Kev.
Drive with your lights on (Be aware be seen) help others GIVE Blood |
Trylon Samba Member
Posted: Fri Jul 30, 2021 3:57 pm Post subject: Re: '59 Karmann Ghia fever |
mooopers wrote: |
Goes behind on a 1960 to the top |
Thanks so much for the photos!
We do have the brackets but there is no such chrome piece at the top:
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Fri Jul 30, 2021 4:02 pm Post subject: Re: '59 Karmann Ghia fever |
The aussie Trimmer wrote: |
Thanks for chiming in Kev!
Does it somehow go behind the chrome piece on the door jamb?
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
grailoc Samba Member
Joined: March 25, 2004 Posts: 1441 Location: FRANCE and now QUEBEC city
Trylon Samba Member
Posted: Fri Jul 30, 2021 7:23 pm Post subject: Re: '59 Karmann Ghia fever |
Oh, I’ve copied and studied these photos for years!
Thanks for your support and congrats on that original gem! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Fri Jul 30, 2021 7:55 pm Post subject: Re: '59 Karmann Ghia fever |
Oh shoot - that windlace was upside down! _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
Posted: Fri Jul 30, 2021 7:56 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Thank you for the confirmation Moogie! Still going to wait on their actual installation but good to know you think we might be on the right track. |
Color me embarrassed - that's what I get for not looking more carefully at your pictures! _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
Doch leider musst du von uns gehn |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3915 Location: In Molinya Orbit
obus Samba Member
Joined: March 08, 2001 Posts: 11065 Location: just off Garden State Parkway Exit 81
Trylon Samba Member
Posted: Sat Jul 31, 2021 1:22 pm Post subject: Re: '59 Karmann Ghia fever |
Thanks, saw that. For some reason most pictures seem to be of cabriolets. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Sat Jul 31, 2021 1:34 pm Post subject: Re: '59 Karmann Ghia fever |
obus wrote: |
is your carpet considered oatmeal or charcoal or ? |
Oh boy, guess I am going to have to start knowing the answer to a lot of stuff I never thought about before.
So our car was Cardinal Red, and I believe that the Brilliant Red it is now is supposed to have the same color interior (as per Kev).
The 57 Cardinal Red says the carpet is “grey”:
That said, the other colors listed seem to be different than what we have!
Still think “grey” describes it quite nicely. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Sat Jul 31, 2021 1:39 pm Post subject: Re: '59 Karmann Ghia fever |
Door card installation tomorrow!
Set up and dry fit:
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
obus Samba Member
Trylon Samba Member
Posted: Sat Jul 31, 2021 1:47 pm Post subject: Re: '59 Karmann Ghia fever |
obus wrote: |
yes yours looks legit grey. carpet looks great in yours. You are scaring me and i may have the old time upholstery/carpet guy not far from here do mine when the time comes. |
It only took four tries— and we punted on the wind lacing.
What’s to be frightened of?
We have decided to do what we think we can and then let a professional take over. For instance, the holes for the rear seat in the parcel shelf clearly do not match the holes in the steel. Pretty sure we would have a mess after we try to poke around so we will leave that to Dwayne (if I can coax him to take it on again) at some later date.
I do know that I am finding it very satisfying to do as much as we can and not simply farm the whole job out. But I guess it all depends on your goals. Pretty sure our car is never going to pass a concourse inspection… _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
