1967-1969 wiring harness question can it be fixed?
modelsinc1967
modelsinc1967 is offline
PostPosted: Fri Jul 30, 2021 12:50 pm    Post subject: 1967-1969 wiring harness question can it be fixed? Reply with quote
Good afternoon, I have a 1967 beetle body on a 1969 pan, 1971 transaxle and 12 volt starter and 12volt alternator. I just bought and put an engine in the car. I know the person before me that I bought it from was not very good at what he was doing. There are no wires to the starter solenoid and when I tried to figure out if I had all the wires to the engine could not get it to start. In fact there are no wires to the volt regulator either. I am thinking I may want to get a main wire loom so I know I have all the wires to the engine. My question however is being it has the 12 volt set up would I need to get a 1971 beetle wire loom in order to get the 12 wiring for the starter, alternator, and 12 volt voltage regulator?
I am at a lose right now. Mainly because I am so new to the vw game. I have uploaded some photos if that would help. The wires in the engine compartment have been spliced many times and I am not sure if they are all there. That was why I thought I should just get a wire loom. However I am pretty sure If I get the stock wire loom for 1967/1969 it will be for 6 volt. But if I go 1971 and higher it will be for 12 volt but will it have more wires than I would need? any help would be appreciated. Also another question I have. If I buy the main wire loom will it have the wires that go to the solenoid? Or is that something totally different?
HarrysRatBug
HarrysRatBug is offline
PostPosted: Fri Jul 30, 2021 2:48 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
Late 67/69 were 12 volt!
mukluk
mukluk is offline
PostPosted: Fri Jul 30, 2021 4:20 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
1) All USA market Beetles were 12v from the 1967 model onwards. Even if you installed a 6v wiring harness, that wouldn't be a bad thing since the wires are generally heavier gauge than those for a 12v system.
2) Your alternator is likely an internally regulated one. As such, there wouldn't be any reason to fully wire in an external regulator. Post up pictures of the alternator to help determine what kind you have.
3) It would help if you could trace the wires which aren't connected to see what, if anything, they're connected to at the other end. If that isn't possible, at least note the colour coding of the wire insulation and back up/widen the angle of your pictures so we can get a better idea of what we're looking at.
4) What wires do you have present under the car, near the starter?
modelsinc1967
PostPosted: Sat Jul 31, 2021 3:34 am    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
That is good. That does help.
modelsinc1967
PostPosted: Sat Jul 31, 2021 3:41 am    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
Under the front bonnet it is spaghetti, the ignition switch, which I can take a pic tomorrow after work, there is only 1 wire to that switch. I am guessing looking at a wire diagram there should be two wires going to that solenoid? I can add them myself just not sure which post goes from switch to each post on solenoid?
This is the alternator, I just removed the starter from the car asI was going to take it somewhere to check it out. The only wires that went to the starter when it was in the car is the black cables. 1 goes up front under the pan pass side. The other one goes thru the firewall, but here lies a problem. Whoever had the car before me spliced into the cable and there are just two heavily spliced wires (red, not factory) go into the fire wall, into the engine bay.. There were no wires running to the solenoid. The guy I bought the car from had placed the body on the pan and now I have to deal with spaghetti and not knowing if I have it all. He moved away right after I bought it.
This pic is sideways, I can take a better pic tomorrow, this shows the only two wires coming thru the passenger side firewall. Should there be more than just two?
61SNRF
61SNRF is offline
PostPosted: Sat Jul 31, 2021 6:22 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
You can ignore the fact that it has a 69 pan and 71 trans. The main thing is it's a 67 body.
That means the best replacement wire harness would be for a US 67. It will have all the proper wiring terminals for the lights, starter and ignition.
Since a US 67 has a Generator (GEN) it also has the Voltage Regulator (VR) mounted under the back seat. The one work around you'll have to do to use the Alternator (ALT) with built in VR is bypass those wires, otherwise everything else is the same.
Once you have the harness, essentially all you have to do is delete the stand alone VR under the back seat. You would have to do this on any harness except late '74.
Under the rear seat you'll have a large red wire coming from the engine side where it connects to the ALT D+ terminal. It will have a 3/8" female spade connector for the old VR D+. It will also have a large spade terminal/big red wire off the VR B+ that goes forward to the Headlight switch. You need to connect these two wires together as well as adding a third that runs across the tunnel with a 5/16" ring terminal onto B+.
Connecting the three big wires together with a good connection is your biggest challenge.
Lastly splice the two smaller warning light wires together, that is the green one from engine side which connects to ALT/VR DF to terminal 61 Blue one that goes forward to warning light in Speedo.
With these exceptions you can wire it just as a 67 wire diagrams shows...
https://www.thesamba.com/vw/archives/info/wiring/bug67.jpg
For the turn signals and Hazard lights to work properly you'll need a 9-pin relay...
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211953227BWW
-Bruce
An ounce of prevention is worth a pound of cure.
modelsinc1967
PostPosted: Wed Aug 04, 2021 2:49 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
Thank you for the reply.
This makes sense, and to report I have headlights and taillights, yeah. That is the most progress I have made in two weeks. Still nothing from starter. Will keep at it.
61SNRF
61SNRF is offline
PostPosted: Fri Aug 06, 2021 6:46 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
Good news!
In the mean time The Samba is an awesome resource for you to learn about your new car.
From the title bar on top of the home screen, click on Gallery and from the drop down menu select Search.
Use words like "Starter wiring", Ignition switch wiring, engine wiring etc and you can find examples that might help you out.
From the Technical tab, click on Wiring Diagrams, Type 1, 1967 USA and you'll find several versions.
In the drop down also check out the many resources such as Owner's manuals, literature, accessories etc.
In this forum for sure check out the Stickys/FAQ's for lots of common topics.
Another thing you can do is go to the Wolfsburg West home page to view a virtual Beetle parts catalog that has very helpful drawings and year specific tips for your review.
Best of luck above all have fun👍
-Bruce
ashman40
ashman40 is offline
PostPosted: Fri Aug 06, 2021 9:24 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
You mentioned taking the starter out of the transmission to have it tested?? The ACVW manual transmission starter pinion gear is supported on one end by a bearing inside the starter; on the other end it is supported by a bushing in the transmission. To test the starter outside the transmission you will need a jig to support the exposed end of the pinion gear in place of the transmission bushing. Most FLAPS will probably not be equipped for this type of testing. Autostick transmissions did not use a transmission bushing. The starter came with two internal bearings. Don't be surprised if the place you took your starter to cannot properly test it.
Found a pic from Rob & Dave's site that may help you with your starter wiring:
There are only two connections you need to make at the starter solenoid. The stud marked "Battery connection" is where the positive battery cable is connected. The other end of this cable goes to the positive post on the battery. The battery cable passes thru a hole in the floor pan just rear of the battery.
The red wire labeled "Ignition wire connection" is circuit #50 and comes from the ignition switch. When the key is turned to the START position, this wire has 12v+. This wire comes from the front trunk area; runs inside the main harness along floor pan at the left heater channel. The wire pops out from the harness near the VR under the left rear seat. Normally, there will be a junction below the left rear seat just before the wire exits along the center tunnel. Look for the single steel brake line running along the left side of the center tunnel. Where that steel lines passes thru the pan/firewall you should find another hole where this starter solenoid wire passes thru. Here is a pic from the gallery showing the red #50 wires disconnected from each other and the 2-way junction that normally connects the wires together. You can see the red wire runs thru a (black) sleeve as it passed thru the hole in the pan, just below the brake line.
Optional: Often found on buggy wiring... the B+ output (threaded stud) of the alternator is meant to be connected to a junction between the battery positive terminal and the main #30 wire running to the front of the car. This junction is normally below the left rear seat.
An easy workaround is to run the B+ wire from the alternator to the stud on the starter solenoid where the battery cable connects. This is a shorter run and easier to route the wire. The black wire in you pic which appears to be down near the starter... it wasn't clear if this wire came from the alternator or somewhere else. It appears to have a large ring terminal meant to be connected at the battery cable stud on the starter solenoid?
Honestly, the wire connects in your pics don't look all that bad. Many are cleanly/neatly linked with heat shrink tubing. Sure there are many splices and the wires are not the correct colors. But the splices look to be okay quality and I don't see a bunch of electrical tape and wire nuts (common hacks). The "rat's nest" mess of wires in the trunk is actually the OE VW wires. They were never neat.
You might want to consider just cleaning up the wires you already have. If necessary, replace any questionable or bad segments.
Even the #50 starter wire can be run new from end to end. It would just run you the cost of the wire (using the correct wire gauge) and some time/effort.
I would also suggest you consider adding a Hard Start Relay (HSR) below the rear seat. It will extend the life of your ignition switch. If you run an all new #50 wire and use an HSR the wire from the ignition switch to the relay does not need to be as thick. The relay only requires a small wire (16AWG is fine). This could save you $$ as thicker wire is more expensive per foot. You will still need the proper wire gauge between the relay and the starter solenoid, but that wire length will only be about a meter.
Post a pic of your ignition switch wires looking up from below the steering column. There should be at least 4 or 5 wires soldered to the electrical part of the ignition switch. If the wires have been cut, you may need to install a new ignition switch, or at least splice in new wires. Successfully re-soldering wires to the stock ignition switch is rather difficult as the wires are thick.
AshMan40
modelsinc1967
PostPosted: Sun Aug 15, 2021 12:55 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
Thank you for your reply, I took as many photos I thought would help with the switches under the hood.
one thing I do not have wires coming out of the main wire loom under the back seat for a voltage regulator, so that I am guessing is either it was in the engine bay or not on the 1967?
61SNRF
61SNRF is offline
PostPosted: Sun Aug 15, 2021 7:22 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
So yeah, you have something of a mish mash VW that might even challenge the more experienced!
Your last question. All 1967-73.5 Beetles made for USA market will have the VR under the back seat.
If not...
...it is an Other market basic 1200 or 1300 (body in your case) car...
....or its not a 67 body at all as you've been told. At this point beginning to wonder...
I thought you had decided on a replacement harness?
One thing no matter what, that is not a stock speedometer in your latest photos so there will have to be some wiring mods done to accommodate that.
The new pictures also show your ignition switch wiring is all wrong, the wire gauge size, the terminal sizes and crimps are all undersized or sub-standard. The big red wire shown laying loose looks like the main 12v wire coming from the rear, if correct it should be connected to terminal 30 of either on the headlight switch or ignition switch.
My $0.02...
Can it all be fixed?
Yes, but one would need a good basic understanding and working knowledge of automobile primary wiring and electronics.
Without those essentials you will face an uphill challenge trying to fix it all back to working.
-Bruce
ashman40
ashman40 is offline
PostPosted: Mon Aug 16, 2021 5:47 am    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
modelsinc1967 wrote:
In the above two pics I can see the headlight switch only has two (2) #30 red wires. There should be 3 there.
One red wire comes from the main harness and provides constant 12v from the battery. I can see it there.
One red wire runs from the headlight switch to the fuse box. I can see it there.
One red wire runs from the headlight switch to the ignition switch #30 terminal. I do not see this wire??
At the bottom of the 1st pic I can see your E-Flasher switch. This is a '67-only switch and works with the 7 or 9-prong Flasher Relay... which I don't see in your pic? These relays can be pricey.
In the above pic you can see the ignition switch. There should be three (3) colored wires connected to the different terminal #s:
    #30 red wire (2.0mm^2 / 12AWG) - 12v constant INPUT from headlight switch
    #15 (sometimes numbered #54 on older switches) black wire (1.5mm^2 / 14AWG) - OUTPUT to fuse box
    #50 red/black wire (4.0mm^2 / 10AWG) - OUTPUT to starter solenoid
Clearly your wires have been replaced with other colors. As mentioned above the wires used here appear to be insufficient gauge. I have put the proper wire gauge in parenthesis above for your reference.
Can you identify where each of the wires current connected to your ignition switch go to? In the wire view pic I can see the wires running off the bottom of the pic but don't see where they go. The blue wire connected to the #15 terminal of the ignition switch appears to run to the speedometer??
In your wide view pic I can see a disconnected heavy gauge red wire. This would appear to be the #50 wire. This wire should be connected to the #50 terminal of the ignition switch where your green wire w/ blue crimp on terminal is. The other end of the #50 wire should be under the left rear seat. To test if that is the same wire, ground one end and test the other end of the suspected wire for ground. If you confirm it is grounded, disconnect the grounded end and test again and the ground should be gone. This confirms you have the ends of the same wire. The #50 wire should junction at the rear seat with another red wire that exits at the rear of the center tunnel next to the steel brake line. This wire runs to the starter solenoid #50 terminal. From your earlier description you don't have this wire.
Your very 1st pic is of a disconnected external voltage regulator for an alternator. Your engine pic shows an internally regulated alternator. This means you should not have any visible voltage regulator. Remove the disconnected VR as it is doing nothing and cannot be used with your internally regulated alternator.
When upgrading to an alternator two wiring changes are made to the pre-74 Beetles:
    Instead of the power wires from the battery/generator/main coming together at the VR under the left rear seat... the three heavy gauge red wires are joined together. VW did this with a large white 4-way junction. Under your rear seat, look for three heavy gauge red wires connected together. Be careful as there is a 4th heavy gauge red wire used for the #50 wire of the ignition switch. This wire should NOT be joined with the others.
    The solid blue #61 wire from the GEN lamp in the speedometer ran to the #61 terminal on the VR in cars with a generator. This wire needs to be extended to reach the alternator in the engine compartment where it connects to the alternator's D+ terminal. Most will repurpose the green DF wire that ran between the generator and the VR under the rear seat for this extension. Join the blue and green wires below the rear seat and connect the engine end of the green wire to the D+ terminal at the alternator. Alternatively, you could use the brown D- (ground wire) that also ran between the generator and the VR, but brown wires are ALWAYS ground wires so you don't want to create confusion.
    This D+ wire (which appears to be missing in your pic of your alternator) is critical as it provide an initial current to charge the field coil in the alternator. This field coil charge causes the alternator to start charging. Without this charge the alternator will never start charging.
AshMan40
johnnyvw164
johnnyvw164 is offline
PostPosted: Mon Aug 16, 2021 6:38 am    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
Quote; One thing no matter what, that is not a stock speedometer in your latest photos so there will have to be some wiring mods done to accommodate that.
Yeah, that looks like a 912 or 914 tach/speedo combo. I ran one on a super beetle I had long ago, and have a 914 combo to put into my current Beetle.
To the OP...if you don't have a VOM (volt/ohm meter), get one, as well as a good diagram for a 76. You're going to need to just start tracing out all the wires and see what's what. Think of this as a good education in vehicle electrical systems
ashman40
ashman40 is offline
PostPosted: Mon Aug 16, 2021 9:09 am    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
johnnyvw164 wrote:
To the OP...if you don't have a VOM (volt/ohm meter), get one, as well as a good diagram for a 76(?).
This should be clarified by the OP. From the ignition switch and fuse box pics I was going by the assumption they should be using a US-spec '67 wiring diagram like this:
A '71 wiring harness would work have extra wires for things like a brake warning switch which the OP's dash is missing.
Again, not suggesting the OP replace their harness as I've seen nothing so far that requires a new harness, but if they were planning to replace the entire harness I would suggest using a US-spec '67 harness. It would better match the fuse box and switches. The OP would need to make a small accommodation since the PO replaced the generator with an alternator, but this is an easy/common mod (described above).
AshMan40
modelsinc1967
PostPosted: Wed Sep 15, 2021 7:33 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
Gentlemen, I want to thank all of you that helped me. I finally got it to start up, and found out as well my starter was not very good either. Also did not need the wiring harness, kinda glad I did not spend the money. Whoo hooo.. Thanks again I really appreciate it. It feels good to finally figure out what I was doing wrong. Could not have done it without all your inputs......
ashman40
ashman40 is offline
PostPosted: Wed Sep 15, 2021 8:57 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
If you would, please detail what you did to fix your problem(s). This helps the next person who comes across your original post above and is interested in the fix because they have the same (or similar) problem.
This site works so well because folks post solutions to the problems listed. Lots of good suggestions above, but we don't know which one solved your issues.
AshMan40
modelsinc1967
PostPosted: Wed Jan 12, 2022 2:04 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
My jubilation was quickly shattered. I was able just to get the starter to work, but only 1 headlight after that. So I am basically back to square one. started another thread. That thread is https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
I did get a new wire loom but found out the guy that I bought the car from did not know what year the body is. He told me '67, well it was more like a '66 and now I have to try to adapt the loom to work from a 10- fuse fuse block, to an 8 fuse fuse block.
HarrysRatBug
PostPosted: Wed Jan 12, 2022 3:26 pm    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
Or put a different fusebox in!
ashman40
ashman40 is offline
PostPosted: Mon Jan 17, 2022 8:09 am    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
This is a good point. From the ‘67 wiring diagram above you can see there was a 10-fuse fuse box. You pic shows an 8-fuse. That is strange?!
If the opening will only fit an 8-fuse then the body may be from something older than a ‘67? I am only familiar with US-spec Beetles. Maybe VW used an 8-fuse fuse box outside the US?
AshMan40
Michael Ambrozik
Michael Ambrozik is offline
PostPosted: Mon Jan 17, 2022 11:54 am    Post subject: Re: 1967-1969 wiring harness question can it be fixed? Reply with quote
Is it maybe a 66' body as they ran 8 fuse boxes. Can we get a picture of the outside of the body.
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Beetle - 1958-1967 All times are Mountain Standard Time/Pacific Daylight Savings Time
