obus Samba Member
Joined: March 08, 2001 Posts: 11040 Location: just off Garden State Parkway Exit 81
obus Samba Member
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Sat Jul 31, 2021 8:36 pm Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
Remarkable how good they look after all this time!
I mean this is the same year the Soviet Union shot down Gary Power’s U2 for goodness sake! _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
obus Samba Member
Trylon Samba Member
Posted: Sun Aug 01, 2021 3:24 am Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
obus wrote: |
Trylon wrote: |
I mean this is the same year the Soviet Union shot down Gary Power’s U2 for goodness sake! |
Im very happy there arent any rips or tears.
I didn't pop out into this world until just shy of 9 years after this car was made. |
BTW: I had some success cleaning my previous interior using a Mr. Clean Magic Eraser. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
obus Samba Member
Rome Samba Member
Joined: June 02, 2004 Posts: 9602 Location: Pearl River, NY
Posted: Sun Aug 01, 2021 5:58 am Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
Quote: |
The dark spot on the drivers side near the armrest is probably dirt/oils from the drivers hand/arm over the years. Passengers side was just a run down from where i didn't let the Simple Green dry enough. I will look for purple power and see what that does |
I sure would not want any residue from PO's perspiration on my interior pieces. Before you start with PP, try the SG again, but let it sit wet on the surface for at least a minute before scrubbing with the Eraser. Also use a soft bristle brush such as a hand-cleaning brush on the vinyl right after the Eraser while the vinyl is still moist with the SG so that the bristles reach into the tiny pores of the vinyl. Should help to let the part be outside in the sun for an hour so that the surface heats up a bit when you spray the SG on.
I've also used the "old" formulation of PP years ago on metal or hard plastic, and it worked really well. I'd be very cautious on the upholstery's soft vinyl. Aggressive to skin so wear solvent-resistant gloves. |
obus Samba Member
Posted: Sun Aug 01, 2021 10:44 am Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
Rome wrote: |
Thanks Rome. I certainly will try this technique when i give it a go again!!! _________________ July 1959 Mango Standard Bus aka Obus L346 L347 https://www.thesamba.com/vw/forum/viewtopic.php?t=256592&highlight=
66 21 window bus built 8/31/65 https://www.thesamba.com/vw/forum/viewtopic.php?t=777273 |
Marcdeb Samba Member
Posted: Sun Aug 01, 2021 12:45 pm Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
I used to use tooth brushes to clean sensitive parts or hard to reach areas but sometimes I need something a bit more abrasive. A few years ago I thought I would try a "Denture" Brush. This is now one of the most effective and usefully tools I use when cleaning my cars. Along with Simple Green. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
obus Samba Member
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
obus Samba Member
The aussie Trimmer Samba Member
Joined: July 05, 2006 Posts: 385 Location: Western Australia
Posted: Mon Aug 02, 2021 3:46 pm Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
You guys should get Swipe for cleaning the upholstery or everything else around the house and garage; its the best thing since sliced bread and you control the the strength of the mix. Made in the US sold around the world. _________________ Cheers,
Kev.
Drive with your lights on (Be aware be seen) help others GIVE Blood |
obus Samba Member
obus Samba Member
Braukuche Samba Member
Posted: Thu Sep 02, 2021 3:07 pm Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
obus wrote: |
Had about 30 minutes this a.m. to mess around with the Ghia and i am wondering what headlight ring would be correct for my May of 1960?
And the correct answer is…
Both.
The scruffy one on top is the bulb holder and mount. Notice the little wedge shaped indent on the top? The chrome cover ring snaps into that and screws in 180 degrees from the top.
You need a big Hella logo ring with the corresponding wedge shaped notch. It’s the same one used on lowlights _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1973 Ghia convertible |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3907 Location: In Molinya Orbit
obus Samba Member
obus Samba Member
Posted: Fri Oct 08, 2021 7:16 pm Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
Sorry to hear that, hopefully you got the shots. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
