GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Sun Aug 01, 2021 12:12 am Post subject: Stop leak for a leaking power steering pump? |
Has anyone had any success using stop leak for a leaky power steering pump? I know I need to replace it but I’m hoping to buy a little time…
Thanks!
Pete _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
Posted: Sun Aug 01, 2021 2:20 am Post subject: Re: Stop leak for a leaking power steering pump? |
It's worth a try. The steering gear on my '91 was leaking a dozen years ago, and after adding fluid with a stop leak added it is dry today. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Sun Aug 01, 2021 5:17 am Post subject: Re: Stop leak for a leaking power steering pump? |
It will stop a seep, it won’t stop a drip or flow. _________________ .ssS! |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4790 Location: Bemidji, MN
Posted: Sun Aug 01, 2021 5:53 am Post subject: Re: Stop leak for a leaking power steering pump? |
i've had ONE success with stop leak in my life... one. old Mercedes PS pump, flinging oil from the shaft seal. tried ATP AT-205 and i'll be durned if it didn't slow, then stop. been fine for over a year now.
that same stuff, AT-205, did zilch on a crankshaft seal on a neighbor's car.
worth a try. _________________ -dan
www.thefixitworkshop.com |
kamzcab86 Samba Moderator
Posted: Sun Aug 01, 2021 1:01 pm Post subject: Re: Stop leak for a leaking power steering pump? |
It turns out it is actually the switch that’s leaking (although the pump has been weeping for a long time now). I threw some Lucas in to see if it’ll slow it down enough until I can find a replacement… _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
