tycham Samba Member
Posted: Sun Aug 01, 2021 12:19 pm Post subject: Front beam assembly |
I just took my front beam of my Thing to rebuild. The driver side shock mount needs replacing. Is it available
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Sun Aug 01, 2021 3:49 pm Post subject: Re: Front beam assembly |
You’re better off finding a beam.
FWIW, if you’re not concerned with it being exact, a Beetle beam is the same except for the reinforcements on the towers. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
tycham Samba Member
Posted: Sun Aug 01, 2021 4:13 pm Post subject: Re: Front beam assembly |
Meaning the Beetle will bolt directly on. Which years and models |
Posted: Sun Aug 01, 2021 7:17 pm Post subject: Re: Front beam assembly |
Any ball joint beam (‘66 on) will work and is a direct bolt on. These should be fairly easy to source due to the narrowed beam trend.
You will need to transfer your spring packs, trailing arms, & spindles. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
tycham Samba Member
Posted: Sun Aug 01, 2021 8:07 pm Post subject: Re: Front beam assembly |
Thank you |
