Help to ID 12V 30amp breaker
9.5isCanadian
9.5isCanadian is offline
PostPosted: Mon Aug 02, 2021 12:38 pm    Post subject: Help to ID 12V 30amp breaker Reply with quote
Hi everyone.
Been daily driving my 87 wbx’r and over the last few days there’s a circuit breaker under my passenger seat began cycling.
According to the Pollak site it’s a thermally tripped breaker.
Can anyone tell me what it is supplying power to? Or a general idea?
I will replace the unit but am concerned it may be cycling due to an overload.
Here’s two pictures of the item and location.
Thank everyone I appreciate the collective knowledge of the group.
Owen
9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Aug 02, 2021 12:55 pm    Post subject: Re: Help to ID 12V30amp breaker Reply with quote
No and no. You have to trace the wire and see for yourself. It's not original/stock.
It's a pretty thick wire. Do you have any heavy duty accessories like a serious stereo?
'87 Syncro
Ferric Oxyhydroxide Superleggera Edition
9.5isCanadian
PostPosted: Mon Aug 02, 2021 1:15 pm    Post subject: Re: Help to ID 12V30amp breaker Reply with quote
Ha I wish. No stereo at all, yet…
I couldn’t find it in the Bentley so I suspected it was not oem.
I’m just going to leave it off and see what doesn’t work, if anything.
Thanks for the confirmation.
Owen
2018 BMW R Nine T
2012 Golf tdi
4Gears4Tires
PostPosted: Mon Aug 02, 2021 3:55 pm    Post subject: Re: Help to ID 12V30amp breaker Reply with quote
If you don't have a stereo at all, it may have been the power wire for an amp. I would try to find out what it is connected to or if it's just hanging loose somewhere.
Not hard to remove the piece of wire from the terminal clamp to the breaker luckily.
'87 Syncro
9.5isCanadian
PostPosted: Mon Aug 02, 2021 5:53 pm    Post subject: Re: Help to ID 12V30amp breaker Reply with quote
So turns out this wire was charging my house battery. I have the diesel centre heat tunnel and the wire was run under it. Where is crossed into the under seat cavity it had cut the wire insulation.
Intermittent short was tripping the breaker / fuse.
Thanks for the assistance everyone.
Owen
2018 BMW R Nine T
2012 Golf tdi
DanHoug
DanHoug is offline
PostPosted: Mon Aug 02, 2021 6:17 pm    Post subject: Re: Help to ID 12V30amp breaker Reply with quote
A thermal reset breaker will keep whacking the short until something breaks or starts on fire.
-dan
www.thefixitworkshop.com
