ghiafreek Samba Member
Joined: December 19, 2002 Posts: 937 Location: San Antonio, Tx
Posted: Sun Jul 18, 2021 12:27 pm Post subject: Unknown speedo wire |
I have a '65 squareback. Where does the green/white wire go. Its coming directly out of center of speedo with male spade connector.
thanks. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Mon Jul 19, 2021 3:39 pm Post subject: Re: Unknown speedo wire |
Yeah there is no wire to the speedo except for the one to the bulb for nighttime illumination. The speedometer/odometer is 100% mechanical. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22429 Location: Kimball, Mi
Posted: Thu Jul 22, 2021 11:58 am Post subject: Re: Unknown speedo wire |
Erik G wrote: |
shouldn't have one. got pics? did maybe someone add a ground wire? |
That would be my guess as well, especially if the speedo unit wasn't seated in place (you wouldn't have a ground). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Aug 01, 2021 10:22 am Post subject: Re: Unknown speedo wire |
It’s been a while. Hot here in SA.
Grn/wt wire center of speedo.
Erik G Samba Member
Posted: Sun Aug 01, 2021 11:51 am Post subject: Re: Unknown speedo wire |
ghiafreek wrote: |
yeah - hot AF in Houston. that's a previous owner addition. looks like a previous owner has messed with it a bunch _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Sun Aug 01, 2021 12:18 pm Post subject: Re: Unknown speedo wire |
Erik G wrote: |
ghiafreek wrote: |
yeah - hot AF in Houston. that's a previous owner addition. looks like a previous owner has messed with it a bunch |
So, go ahead and connect to fuse box? if not, where do you recommend?
thanks. |
Posted: Sun Aug 01, 2021 6:27 pm Post subject: Re: Unknown speedo wire |
My dude. You said speedo but the pic you have posted is not of the speedo, it is of the fuel gauge/warning light cluster.
So, let us speak precisely, yeah? Cuz the speedo = the speedometer which is a different thing.
So, from the pic you have posted, the green/white wire looks to have been installed where a black wire should be. The black wire would be the power supply to that cluster, connecting to the fuse box as per the wiring diagram (see wiring diagram to learn which fuse it's supposed to connect to). Why the wire was replaced with green/white, who knows. _________________ 1965 Volkswagen 1500 Variant S
Posted: Mon Aug 02, 2021 4:48 am Post subject: Re: Unknown speedo wire |
sjbartnik wrote: |
So, from the pic you have posted, the green/white wire looks to have been installed where a black wire should be. The black wire would be the power supply to that cluster, connecting to the fuse box as per the wiring diagram (see wiring diagram to learn which fuse it's supposed to connect to). Why the wire was replaced with green/white, who knows. |
Damn! I know it. Been doing this long enough you’d think a ridiculous mistake like that would not happen. Telling you… this heat is stifles the brain.
Thank you |
Posted: Mon Aug 02, 2021 4:34 pm Post subject: Re: Unknown speedo wire |
sjbartnik wrote: |
It's possible that the PO was color blind, and just worked with 1 wire at a time. I've ran into that before. A friend of mine repaired a section of the rear harness with red wire (all he had), and being color blind, just worked 1 wire at a time and made it work. Sometimes you have to work with what you have. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 879 Location: Lanark County, Ontario, Canada
Posted: Wed Aug 11, 2021 1:14 pm Post subject: Re: Unknown speedo wire |
Hang on a sec.......I pulled off the warning light cluster connector from a Nov '62 Notch, and it has 2 factory wires that exit from that hole:
Black = 15 = ignition controlled power to the fuel gauge & gen & oil pressure & 2 turn signal warning lights.
Green with white tracer = input to the twin turn signal warning lights.
There are variations over the years, so it may be best to pull the connector and inspect the wiring on the inside. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
