Type 3 Squareback
Page: Previous  1, 2, 3, 4, 5
1971 viv
1971 viv is offline
PostPosted: Sat Feb 06, 2021 1:05 pm    Post subject: Re: Type 3 Squareback Reply with quote
After getting the flywheel gland nut off, I can’t seem to get the actual flywheel free. Any tips, or should I just try to pry it off?
vintagecarleds
vintagecarleds is offline
PostPosted: Sat Feb 06, 2021 2:35 pm    Post subject: Re: Type 3 Squareback Reply with quote
Use two flat head screwdrivers on the 9 and 3 oclock positions behind the flywheel, pry one side at a time back and forth. It will walk it off.
www.vintagecarleds.com
[email protected]
713-853-9644
1971 viv
1971 viv is offline
PostPosted: Sun Feb 07, 2021 10:22 am    Post subject: Re: Type 3 Squareback Reply with quote
Sweet. Thanks for the help
1971 viv
1971 viv is offline
PostPosted: Mon Aug 02, 2021 5:20 pm    Post subject: Re: Type 3 Squareback Reply with quote
Here’s an interior question:
I’m looking for a stock steering wheel, and I found both a white one and a black one. My car is a 71 sapphire blue with platinum interior. Would the white one or the black one be correct for this color combo?
Bobnotch
Bobnotch is offline
PostPosted: Mon Aug 02, 2021 5:50 pm    Post subject: Re: Type 3 Squareback Reply with quote
Black. Keep in mind that 71 steering wheel and column assembly are all by themselves (1 year only).
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
1971 viv
1971 viv is offline
PostPosted: Tue Aug 03, 2021 10:30 am    Post subject: Re: Type 3 Squareback Reply with quote
Ok, thanks for the reply. Is there a way to identify a 71 steering wheel from other models years?
Bobnotch
Bobnotch is offline
PostPosted: Tue Aug 03, 2021 3:04 pm    Post subject: Re: Type 3 Squareback Reply with quote
Look for a brass ring screwed to the back of the steering wheel. It should be held on by 3 screws.
Tram wrote:
Tram wrote:
1971 viv
1971 viv is offline
PostPosted: Wed Aug 04, 2021 10:40 am    Post subject: Re: Type 3 Squareback Reply with quote
All right, good to know. Ill keep my eye out for that. Thanks Bobnotch
1971 viv
1971 viv is offline
PostPosted: Wed Aug 04, 2021 2:42 pm    Post subject: Re: Type 3 Squareback Reply with quote
On a different note, I believe that my thermostat has failed. This is what it looks like when cold.
If it is failed, is there a way to fix/ repair/ rebuild it? Or do I have to find a new one? Do all models ( type 1 , type 3, etc.) have the same style or are type 3s specific?
Thanks in advance
W1K1
W1K1 is offline
PostPosted: Wed Aug 04, 2021 3:46 pm    Post subject: Re: Type 3 Squareback Reply with quote
it should be marked with the opening temp
https://www.awesomepowdercoat.com/vw-thermostats
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
_Pascal_
_Pascal_ is offline
PostPosted: Thu Aug 05, 2021 12:52 am    Post subject: Re: Type 3 Squareback Reply with quote
mine looks like that too when cold but it still opens up when I shortly hit it with a heat gun. Since it still opens up, I used mine like that, but now I realise the flaps might not close 100% when cold. I don't think that's a huge issue though...
1971 viv
1971 viv is offline
PostPosted: Thu Aug 05, 2021 10:06 am    Post subject: Re: Type 3 Squareback Reply with quote
Yes, I ran the heat gun over it, and it did open up a little, but it still is hitting the top of the bracket when cold. Would it be fine to buy a used one, or would i be better off getting a new one from Awesome Powdercoats? How often do they fail?
Page 5 of 5
