9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Mon Aug 02, 2021 12:38 pm Post subject: Help to ID 12V 30amp breaker |
Hi everyone.
Been daily driving my 87 wbx’r and over the last few days there’s a circuit breaker under my passenger seat began cycling.
According to the Pollak site it’s a thermally tripped breaker.
Can anyone tell me what it is supplying power to? Or a general idea?
I will replace the unit but am concerned it may be cycling due to an overload.
Here’s two pictures of the item and location.
Thank everyone I appreciate the collective knowledge of the group.
Owen
_________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
4Gears4Tires Samba Member
Posted: Mon Aug 02, 2021 12:55 pm Post subject: Re: Help to ID 12V30amp breaker |
9.5isCanadian wrote: |
Can anyone tell me what it is supplying power to? Or a general idea? |
No and no. You have to trace the wire and see for yourself. It's not original/stock.
It's a pretty thick wire. Do you have any heavy duty accessories like a serious stereo? _________________ '87 Syncro
Posted: Mon Aug 02, 2021 1:15 pm Post subject: Re: Help to ID 12V30amp breaker |
4Gears4Tires wrote: |
It's a pretty thick wire. Do you have any heavy duty accessories like a serious stereo? |
Ha I wish. No stereo at all, yet…
I couldn’t find it in the Bentley so I suspected it was not oem.
I’m just going to leave it off and see what doesn’t work, if anything.
Thanks for the confirmation.
Owen _________________ 9 1/2 - missing a few pieces.
2018 BMW R Nine T
2012 Golf tdi |
Posted: Mon Aug 02, 2021 3:55 pm Post subject: Re: Help to ID 12V30amp breaker |
If you don't have a stereo at all, it may have been the power wire for an amp. I would try to find out what it is connected to or if it's just hanging loose somewhere.
Not hard to remove the piece of wire from the terminal clamp to the breaker luckily. _________________ '87 Syncro
Posted: Mon Aug 02, 2021 5:53 pm Post subject: Re: Help to ID 12V30amp breaker |
So turns out this wire was charging my house battery. I have the diesel centre heat tunnel and the wire was run under it. Where is crossed into the under seat cavity it had cut the wire insulation.
Intermittent short was tripping the breaker / fuse.
Thanks for the assistance everyone.
2018 BMW R Nine T
2012 Golf tdi |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4791 Location: Bemidji, MN
Posted: Mon Aug 02, 2021 6:17 pm Post subject: Re: Help to ID 12V30amp breaker |
A thermal reset breaker will keep whacking the short until something breaks or starts on fire. _________________ -dan
www.thefixitworkshop.com |
