front bonnet lock not holding
alansvwTwinCab
alansvwTwinCab is offline
PostPosted: Tue Aug 03, 2021 9:28 pm    Post subject: front bonnet lock not holding Reply with quote
Ive been trying to search site for info on how to adjust the front bonnet lock on my 61 Ghia. It is popping open if I hit a bump. The safety catch works fine but its frustrating and dangerous so id like to fix it. I know it will be an easy fix but what is it?
sputnick60
sputnick60 is offline
PostPosted: Wed Aug 04, 2021 2:41 am    Post subject: Re: front bonnet lock not holding Reply with quote
Hey Alan, there's a panel guy in Helensburg that knows how to fix those. Cool
Nicholas
PS, You probably need to slightly lengthen the Pin in the lid. Use a screwdriver in the head of the pin and spanner to control the locking nut. Use a thin spanner. Something thin like a cone spanner that can slip in under the spring.
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
alansvwTwinCab
PostPosted: Wed Aug 04, 2021 6:06 am    Post subject: Re: front bonnet lock not holding Reply with quote
Hi Nick, I think we both know that guy Very Happy . I'll be taking the car to him once the COVID lock down finishes as he need to do a full detail an fix a few very minor issues found in final build. Thanks for advice on fixing lock.
Braukuche
Braukuche is offline
PostPosted: Wed Aug 04, 2021 6:38 am    Post subject: Re: front bonnet lock not holding Reply with quote
Some times the cable tension needs adjusting. It controls the positioning of the latch that holds the pin down if there’s too much slack or not enough the latch won’t grab the pin. I’d start there.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
67 Florida Deluxe
Samba Purist
67 Florida Deluxe is offline
PostPosted: Wed Aug 04, 2021 9:16 am    Post subject: Re: front bonnet lock not holding Reply with quote
I've not seen that headlight mod before. I kinda dig it Cool
-Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Wed Aug 04, 2021 11:48 am    Post subject: Re: front bonnet lock not holding Reply with quote
I believe they are beetle headlights. I saw a lot of guys doing this mod in So Cal back in the 80's, at least where I lived.
Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
Braukuche
PostPosted: Wed Aug 04, 2021 2:30 pm    Post subject: Re: front bonnet lock not holding Reply with quote
Jeff
The only thing worse was the 90s Mercedes headlight butchery. Remember that?
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
rbsurfguy
PostPosted: Wed Aug 04, 2021 3:24 pm    Post subject: Re: front bonnet lock not holding Reply with quote
I don't remember that one! If you have any pics, do share.
I was never offended by the beetle lights since everyone always wanted the Ghia to look Porschy, especially in So Cal, and if done correctly it looked nice, and at least the headlights were VW.
Mercedes lights? Uhhh, no
Jeff
2012 Passat-Sold
Era Vulgaris
Era Vulgaris is offline
PostPosted: Fri Aug 06, 2021 3:13 pm    Post subject: Re: front bonnet lock not holding Reply with quote
Early 2000's Merc quad lights
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
rbsurfguy
PostPosted: Fri Aug 06, 2021 3:35 pm    Post subject: Re: front bonnet lock not holding Reply with quote
OK, yeah that's pushing it a bit!! The slanted lights not so much but not sure about the quads. I can't even get my left side high beam to work, so I can't imagine trying to wire up all those lights! I must admit though, it's not a bad looking Ghia!!!
Jeff
2012 Passat-Sold
Braukuche
PostPosted: Fri Aug 06, 2021 5:17 pm    Post subject: Re: front bonnet lock not holding Reply with quote
How many of those ended up as Kia parts by the 2010?
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
alansvwTwinCab
PostPosted: Sun Aug 08, 2021 8:00 pm    Post subject: Re: front bonnet lock not holding Reply with quote
The headlights are for a 356 Porsche. It took a lot of work and lead fill to get the right look.
https://www.thesamba.com/vw/gallery/pix/1543738.jpg
https://www.thesamba.com/vw/gallery/pix/1543737.jpg
Braukuche
PostPosted: Sun Aug 08, 2021 8:12 pm    Post subject: Re: front bonnet lock not holding Reply with quote
Nice clean job on the lights.
Did you get the hood to latch?
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
alansvwTwinCab
PostPosted: Mon Aug 09, 2021 1:17 am    Post subject: Re: front bonnet lock not holding Reply with quote
Yes seems to be holding. fingers crossed!
Braukuche
PostPosted: Mon Aug 09, 2021 7:36 am    Post subject: Re: front bonnet lock not holding Reply with quote
How did you get it to hold? This is a common issue so others might learn from your success.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
alansvwTwinCab
PostPosted: Mon Aug 09, 2021 8:13 pm    Post subject: Re: front bonnet lock not holding Reply with quote
I adjusted the two nuts above the spring. I think it will be trial and error as not sure which way to turn but seems to hold. I know when i hit a speed hump.
