de-inked Samba Member
Posted: Wed Aug 04, 2021 12:59 am Post subject: lumpy power when cruising |
my bug has been sat for a few months, so I took it for a 30-mile-cruise...
did the usual checks (oil, fan-belt, tyres etc) then set off...
about 5-miles-in I noticed the engine felt lumpy when at cruise speed... ie when accelerating it pulls like a train, I hit my cruise speed, back off, then as it cruises along the power delivery doesn't feel smooth... I've never had anything like it with previous vw engines so I'm asking - where to start looking to fix?
And here's a pic as I know we all love a pic!
Type 1 engine, 1776, twin webers
TIA |
flat4olsen Samba Member
Joined: February 20, 2014 Posts: 342 Location: Denmark, Europe
Posted: Wed Aug 04, 2021 2:18 am Post subject: Re: lumpy power when cruising |
Blocked idle jet. When cruising you at low rpm and load, you fuel is delivered by the idle jet. When accelerating, your carbs are fed primarely by the main jets, so you won´t feel the blocked idle jet _________________ Type 1 1968, Lotosweiss. 2109 oxyboxer engine
Early Bay 1970, Montana Red. Under construction
Posted: Wed Aug 04, 2021 3:33 am Post subject: Re: lumpy power when cruising |
Thank you - will give them a look |
oprn Samba Member
Joined: November 13, 2016 Posts: 12735 Location: Western Canada
Posted: Wed Aug 04, 2021 5:40 am Post subject: Re: lumpy power when cruising |
Those air cleaner elements let in a lot of dirt, get some pre-filters on there and save yourself a lot of carb/jet cleaning and protect your piston rings.
Oh, and I would start with the right carb. You could well be dumping sludge from the engine crankcase down that one with your breather. No car manufacturer to my knowledge does that. Just the VW aftermarket people, all others vent the crankcase BEFORE the air filter or AFTER the carb to prevent messing up the carb. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Wed Aug 04, 2021 6:53 am Post subject: Re: lumpy power when cruising |
oprn wrote: |
Oh, and I would start with the right carb. You could well be dumping sludge from the engine crankcase down that one with your breather. No car manufacturer to my knowledge does that. Just the VW aftermarket people, all others vent the crankcase BEFORE the air filter or AFTER the carb to prevent messing up the carb. |
IIRC, the late-model (1303) plastic air filter has the breather dumping into the lower half, so downstream from the filter, and upstream of the carb. I don't remember about oil bath, can't find the full image in my head... |
Posted: Wed Aug 04, 2021 8:08 am Post subject: Re: lumpy power when cruising |
oprn wrote: |
I did think the location of the breather a bit odd when I got the car (but has been running fine til recently so I figured dont mend what aint broken...!)
Thank you |
Posted: Wed Aug 04, 2021 8:09 am Post subject: Re: lumpy power when cruising |
FreeBug wrote: |
Thanks - might go and investigate new filters etc |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1215 Location: IRELAND
Posted: Wed Aug 04, 2021 10:00 am Post subject: Re: lumpy power when cruising |
Carbs sync'd properly? |
oprn Samba Member
Posted: Wed Aug 04, 2021 11:20 am Post subject: Re: lumpy power when cruising |
FreeBug wrote: |
oprn wrote: |
Chances are that those cars had a proper PVC system and what you were looking at may have been the inlet to the PCV loop and there was a PVC valve on the intake somewhere that the fumes exited from. I am speculating here as the newest VW I ever owned was a '73 and it was so owner modified as to not have anything of the original systems in tact.
All the older cars with the oil bath air cleaner used a draught tube to my recollection. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Wed Aug 04, 2021 12:58 pm Post subject: Re: lumpy power when cruising |
does it feel like 2 cyls dropping out at light cruise?
If so, then it's likely just a sync issue.
Carbs being out of sync will show up during light cruise.
The way to check: Engine off... grab the throttle cable and just pull on it so the carbs just barely open above idle (like a light cruise). Do both carbs open the same amount? Look at the idle speed screws and make sure both left and right carbs have lifted off the screw the same amount.
If not, adjust a pushrod to make it so they both open at exactly the same time.
That's the biggest single reason why dual carbs run like crap.
Sync is most important to good running. |
Posted: Thu Aug 05, 2021 12:18 am Post subject: Re: lumpy power when cruising |
thanks baz76 and Ohio Tom
will check sync/balance as well |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Thu Aug 05, 2021 11:30 am Post subject: Re: lumpy power when cruising |
The other thing, with it being Weber carburettors is that when you go to cruise, your fuel demand drops, the float chamber fuel metering valve leaks and the fuel level rises one side..
you end up with one side going very rich with drips of fuel down the throat of the carb _________________ Ancient vehicles and vessels
Willin Samba Member
Joined: October 10, 2019 Posts: 109 Location: Bozeman Mt
Posted: Sun Apr 30, 2023 9:34 am Post subject: Re: lumpy power when cruising |
The title to this was exactly what I was experiencing!
And one barrel was not responding to the idle mixture screw.
Pulled the carb,( several times) blew out the idle passages. Wide open. Then I ( finally)checked the carb top. Blew one way thru the idle bleed, then the other way. A blob of something came out! I think it was a blob of sealant, which I had glued the gasket to the top with. The blob was kind of floating around in that space.
Buttoned it back up. Runs great again!
Just thought I'd share. |
