alansvwTwinCab Samba Member
Joined: December 28, 2005 Posts: 164 Location: Sydney, Australia
Posted: Tue Aug 03, 2021 9:28 pm Post subject: front bonnet lock not holding |
Ive been trying to search site for info on how to adjust the front bonnet lock on my 61 Ghia. It is popping open if I hit a bump. The safety catch works fine but its frustrating and dangerous so id like to fix it. I know it will be an easy fix but what is it?
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Wed Aug 04, 2021 6:06 am Post subject: Re: front bonnet lock not holding |
Hi Nick, I think we both know that guy . I'll be taking the car to him once the COVID lock down finishes as he need to do a full detail an fix a few very minor issues found in final build. Thanks for advice on fixing lock. |
Braukuche Samba Member
Posted: Wed Aug 04, 2021 6:38 am Post subject: Re: front bonnet lock not holding |
Some times the cable tension needs adjusting. It controls the positioning of the latch that holds the pin down if there’s too much slack or not enough the latch won’t grab the pin. I’d start there. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Wed Aug 04, 2021 11:48 am Post subject: Re: front bonnet lock not holding |
I believe they are beetle headlights. I saw a lot of guys doing this mod in So Cal back in the 80's, at least where I lived.
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Posted: Wed Aug 04, 2021 2:30 pm Post subject: Re: front bonnet lock not holding |
rbsurfguy wrote: |
Jeff |
The only thing worse was the 90s Mercedes headlight butchery. Remember that? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Wed Aug 04, 2021 3:24 pm Post subject: Re: front bonnet lock not holding |
I don't remember that one! If you have any pics, do share.
I was never offended by the beetle lights since everyone always wanted the Ghia to look Porschy, especially in So Cal, and if done correctly it looked nice, and at least the headlights were VW.
Mercedes lights? Uhhh, no
2012 Passat-Sold
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1678 Location: Raleigh, NC
Posted: Fri Aug 06, 2021 3:13 pm Post subject: Re: front bonnet lock not holding |
Early 2000's Merc quad lights
_________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
Posted: Fri Aug 06, 2021 3:35 pm Post subject: Re: front bonnet lock not holding |
OK, yeah that's pushing it a bit!! The slanted lights not so much but not sure about the quads. I can't even get my left side high beam to work, so I can't imagine trying to wire up all those lights! I must admit though, it's not a bad looking Ghia!!!
2012 Passat-Sold
Posted: Fri Aug 06, 2021 5:17 pm Post subject: Re: front bonnet lock not holding |
Era Vulgaris wrote: |
How many of those ended up as Kia parts by the 2010? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Sun Aug 08, 2021 8:12 pm Post subject: Re: front bonnet lock not holding |
Nice clean job on the lights.
Did you get the hood to latch? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Mon Aug 09, 2021 1:17 am Post subject: Re: front bonnet lock not holding |
Yes seems to be holding. fingers crossed! |
Posted: Mon Aug 09, 2021 7:36 am Post subject: Re: front bonnet lock not holding |
alansvwTwinCab wrote: |
How did you get it to hold? This is a common issue so others might learn from your success. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Mon Aug 09, 2021 8:13 pm Post subject: Re: front bonnet lock not holding |
I adjusted the two nuts above the spring. I think it will be trial and error as not sure which way to turn but seems to hold. I know when i hit a speed hump. |
