pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Wed Aug 04, 2021 7:35 am Post subject: Got much needed urgent help! Santa Fe, NM area |
We’re on our return way after a cross country trip. Just short of our stop for the night in Santa Fe, New México, a yuge SNAP! The clutch pedal went to the floor and didn’t come back!
That was yesterday. I just went under the bus hoping it was the cable for which I have a replacement. Found out the worst of my fears… the throw out bearing fork broke! I am now clutchless!
Normally I pretty much do nearly everything I have to do for my vehicles but I’m at a big loss here. Putting it out there in hopes of finding someone within the reasonable area that can help out! _________________ Some people are so busy being clever they don't have time enough to be wise.
aa390392 Samba Member
Posted: Wed Aug 04, 2021 8:46 am Post subject: Re: Begging for urgent help! |
Hope getting the help you need. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
burnite2 Samba Member
Joined: September 08, 2010 Posts: 29 Location: Albuquerque, NM
Posted: Wed Aug 04, 2021 8:57 am Post subject: Re: Begging for urgent help! Santa Fe, NM area |
If you can make to Kirtland Air Force base in Albuquerque you can use the garage and welder but I can’t get away from work to come help.
pyrOman Fire Master
Posted: Wed Aug 04, 2021 9:17 am Post subject: Re: Begging for urgent help! Santa Fe, NM area |
Things are happening.. looking at first choice within the hour, second choice this afternoon! Thanks all! _________________ Some people are so busy being clever they don't have time enough to be wise. |
pyrOman Fire Master
Posted: Wed Aug 04, 2021 5:14 pm Post subject: Re: Begging for urgent help! Santa Fe, NM area |
Prognosis is a busted throw out bearing and pressure plate. Should be back on the road tomorrow! _________________ Some people are so busy being clever they don't have time enough to be wise. |
volksaddict Samba Member
Posted: Wed Aug 04, 2021 6:57 pm Post subject: Re: Begging for urgent help! Santa Fe, NM area |
Dont you know how to drive your bus without a clutch? Open road should be no problem. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Wed Aug 04, 2021 7:06 pm Post subject: Re: Begging for urgent help! Santa Fe, NM area |
volksaddict wrote: |
busted clutch cable is not a big deal, i would drive that anywhere, but with a broken clutchplate, different story! _________________ regards
Uli
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Wed Aug 04, 2021 8:25 pm Post subject: Re: Begging for urgent help! Santa Fe, NM area |
From NM where he is to So Cal has some huge elevation changes. Probably the biggest in the US. I can't believe people are like "yeah man just drive it" fucking posers |
Braukuche Samba Member
Posted: Wed Aug 04, 2021 8:45 pm Post subject: Re: Begging for urgent help! Santa Fe, NM area |
Erik G wrote: |
That grade up from Ocotillo can destroy a clutch plate in its prime. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Lind Samba Member
Joined: November 06, 2000 Posts: 9913 Location: idaho
Posted: Thu Aug 05, 2021 5:22 am Post subject: Re: Begging for urgent help! Santa Fe, NM area |
Erik G wrote: |
Yeah, driving without a clutch is for flat ground when zombies are chasing you. Sure, it can be done, but it is hard on starters and syncros. _________________ .
Wanted:
pyrOman Fire Master
Posted: Thu Aug 05, 2021 7:14 am Post subject: Re: Begging for urgent help! Santa Fe, NM area |
I am 63 now and learned to drive in a 67 deluxe bus. I’ve also learned to break transaxles in half and drive in reverse all the way home. You name it and likely I’ve been through it at least twice!
Even though I considered towing it, it could not be the same as finishing the trip on its own! _________________ Some people are so busy being clever they don't have time enough to be wise. |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3096 Location: Alberta
Posted: Thu Aug 05, 2021 4:07 pm Post subject: Re: Begging for urgent help! Santa Fe, NM area |
pyrOman wrote: |
Even though I considered towing it, it could not be the same as finishing the trip on its own! |
Full marks brother - for both statements. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5506 Location: 1st Coast
Posted: Thu Aug 05, 2021 5:14 pm Post subject: Re: Begging for urgent help! Santa Fe, NM area |
Keep us posted when you can pyrOman. You got this.
Riff Raff wrote: |
pyrOman wrote: |
Full marks brother - for both statements. |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
pyrOman Fire Master
Posted: Fri Aug 06, 2021 1:14 am Post subject: Re: Got much needed urgent help! Santa Fe, NM area |
So, it turns out that the throw out bearing disintegrated.
A couple of you, as well as some friends (yeah, believe it or leave it, I do have friends!) referred me to Fast Foreign Auto Service where Jim took care of the Dormy with a quickness!
The “set back” was a few bucks and a half a day of travel. But I did get going and finally reach Phoenix just after midnight.
Again, thank you all for the quick help, concern and prayers! _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Fri Aug 06, 2021 2:21 am Post subject: Re: Got much needed urgent help! Santa Fe, NM area |
That is great news pyrOman. Thanks for keeping us all in the loop.
Have a fun road trip.
pyrOman wrote: |
Again, thank you all for the quick help, concern and prayers! |
Maui Roadsters
Lind wrote: |
Pau Samba Member
Joined: April 09, 2002 Posts: 341 Location: Euskal Herria
Posted: Fri Aug 06, 2021 4:26 am Post subject: Re: Got much needed urgent help! Santa Fe, NM area |
Nice to hear you will finish your roadtrip by driving. Thank you for sharing your pictures. _________________ Freedom for the Catalan Countries
Si ens destrossen les contrades alçarem les barricades !!*!! |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Fri Aug 06, 2021 12:39 pm Post subject: Re: Got much needed urgent help! Santa Fe, NM area |
Yep! It's so nice to hear that you are rolling once again under your own power. Unless you hurled it across the shop parking lot, hopefully you'll post a shot of the destroyed throw out bearing. Thanks for posting up so many fun photos of your journey in your Splitty! Safe travels...
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
pyrOman Fire Master
Posted: Sat Aug 07, 2021 7:06 am Post subject: Re: Got much needed urgent help! Santa Fe, NM area |
We’ve taken hundreds of pictures, mostly for the “through the split windshield” thread. This whole trip has been mostly for visiting family and friends. My doing all of the driving has kept me from posting pictures. The last leg will be tomorrow. I will be posting pictures later. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Daddybus Samba Member
Posted: Sat Aug 07, 2021 3:26 pm Post subject: Re: Got much needed urgent help! Santa Fe, NM area |
A 63 year old man shouldda been able to pull the motor and make repairs...63 is the new 40. |
melville Samba Member
Joined: August 09, 2006 Posts: 1245 Location: Just Outside the Redwood Curtain
Posted: Sat Aug 07, 2021 7:51 pm Post subject: Re: Got much needed urgent help! Santa Fe, NM area |
Glad you're rolling again, Ivan! _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
