Better Brake Shoes for Off Road
thefladge
thefladge is offline
PostPosted: Sun Aug 01, 2021 5:31 pm    Post subject: Better Brake Shoes for Off Road Reply with quote
First off, I'm not interested in converting to disc brakes.
I'm looking for a supplier of top of the line brake shoes.
Years ago, some company was selling premium brakes shoes with a semi-metalic material that were better than stock shoes.
I can't find that company anymore.
I have 1965 type one front brakes on my Baja.
Anyone have any ideas?
1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Sun Aug 01, 2021 7:17 pm    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
There were brake shoes that were used for off road racing going that were known as Woven brake shoes. They were very aggressive and worn out many drums. You may still be able find them. Check with places like KarTek and McKenzie’s may still have them.
I hope you have good supply of brake drums to replace the ones you will wear out.
Semi metallic brake shoes will also wear out drums prematurely when used in dirt and sand.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
oprn
oprn is offline
PostPosted: Sun Aug 01, 2021 7:27 pm    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
If you are running taller tires you will be loosing mechanical advantage. Type 3 brakes on the back with tall rubber might bring back some lost brake power there. Think about larger wheel cylinders, smaller master cylinder, longer brake peddle lever or a combination of all three.
We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age)
Vanapplebomb
Vanapplebomb is offline
PostPosted: Mon Aug 02, 2021 6:14 am    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
I run 33” tires in the back, and I can lock them up.
I modified my rear backing plates (IRS) for Super Beetle front wheel cylinders, which are 23.6mm. Basically you have to slot the bolt hole for the cylinder a couple mm. A rat tail file makes quick work of this. The steel used for the backing plates is really soft and files like butter. Then I made a thin (16 gauge if I recall) spacer for the wheel cylinder to center it with the shoes. Pretty easy mod, and stops great.
1800 Type 4 Berrien 295
thefladge
PostPosted: Mon Aug 02, 2021 6:20 am    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
My rear brakes are fine. I have a Bus gear reduction transaxle with early Bus rear brakes. The rear wheel cylinders are 22mm.
I'm just looking for the best front brake shoes.
74 Thing
74 Thing is offline
PostPosted: Mon Aug 02, 2021 11:15 am    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
I used larger bore front brake cylinders in the rear too. Made a huge difference in stopping as well!
oprn
oprn is offline
PostPosted: Tue Aug 03, 2021 5:00 am    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
Ok so then is it a brake front/rear imbalance you are trying to correct? A more aggressive brake shoe may be the ticket but I don't know who makes them.
I have Bus rear brakes on my sand rail and have just added stock Beetle front brakes. Yes the balance is off and the rears lock up easily before the front. I bought an adjustable proportioning valve and am about to install it today or tomorrow and will see if that solves the problem.
thefladge
PostPosted: Tue Aug 03, 2021 12:31 pm    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
I'm just looking for the best brake shoes available.
I've bought sets in the past that were terrible.
74 Thing
74 Thing is offline
PostPosted: Tue Aug 03, 2021 3:16 pm    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
How about aircooled.net super stopper brake shoes?
I do recommend larger rear brake cylinders too to help out the braking bias with those large rear tires.
https://vwparts.aircooled.net/SearchResults.asp?Search=super+stopper&x=0&y=0
mr_bill
mr_bill is offline
PostPosted: Tue Aug 03, 2021 6:19 pm    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
check @ McKENZIES, for their "severe-duty" brake shoes.......I have a set of fronts from a 1972, complete with drums
see ya' on the trail........
"Mr Bill"
Dos Perros Motorsports
Orange, CA
1972 Class 11x/Stock Bug
'60's era "vintage" Tunnell-Buggy
"...no one here....get's out ALIVE...."
Motor = electric
Engine = internal combustion
www.facebook.com/groups/DosPerrosMotorsports
www.alrchapter132.org
www.DAV.org
thefladge
PostPosted: Wed Aug 04, 2021 9:42 am    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
I think those Super Stopper shoes are what I'm looking for. Semi-metalic. Thanks for the tip.
The brake shoes I DON'T recommend are A.C. Industries shoes from So Cal Imports. I had a set on my car several years ago and the material broke loose from one of the shoes while I was driving to work. Fortunately there were no other cars near me at the time or it would have been a disaster.
earthquake
earthquake is offline
PostPosted: Wed Aug 04, 2021 11:56 am    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
Check these out...
https://www.porterfield-brakes.com/Products/?YearS...ufacturers
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
dustymojave
dustymojave is offline
PostPosted: Sat Aug 14, 2021 3:20 pm    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
Funny...I used to know Andy Porterfield back in the 60s and 70s when he raced Corvettes and Camaros in SCCA racing. I last encountered him in the 1980s when I was on the crew of a Trans Am car. Now to encounter someone on a VW offroad site referring to his products is a little weird.
Richard
SoCalBajas Member
earthquake
PostPosted: Sat Aug 21, 2021 10:42 am    Post subject: Re: Better Brake Shoes for Off Road Reply with quote
Why? I was a 15 year veteran of the SCCA, mostly Auto Cross, I was 1 of the Auto Cross tech inspector for about 14 of them, it was easier then working the corners, tech all the cars and sit back and watch between runs. I had a great time until it got to expensive to run and my best friend passed away, we ran the same car and when he passed it was no longer fun. I tried running my Datsun 510 but just could not get back into it.
Casey
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
