Rocky Jennings Motor value
Page: Previous  1, 2, 3
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Wed Aug 04, 2021 2:56 pm    Post subject: Re: Rocky Jennings Motor value Reply with quote
What the farking fresh hell is going on here? We’re talking about MY opinion here. You can take my opinion to the bank. What’s wrong with you people?
Damn.
djkeev
djkeev is offline
PostPosted: Wed Aug 04, 2021 3:31 pm    Post subject: Re: Rocky Jennings Motor value Reply with quote
Damn.
f
What is going on here is you outright condemn a motor as not being what the owner claims it is based upon some dyno testing he posted.
BUT
you offer absolutely no valid information to support your condemnation!
For example........
What I know about Dyno's would fit on the head of a pin if printed in large letters.
I keep my mouth shut.
If you don't know what you are talking about, just don't start talking.
Dave
Ghia
Vanagon
Beetle
?Waldo?
?Waldo? is offline
PostPosted: Wed Aug 04, 2021 3:42 pm    Post subject: Re: Rocky Jennings Motor value Reply with quote
The following is just some factual statements that might or might not have any meaning.
The OP states that their engine is an RJE 2.3L WBX.
GoWesty states that their 2.3L WBX will produce peak 114 hp and 157 ft-lbs torque.
Typical drivetrain losses are 15%.
114 x 0.85 = 97
157 x 0.85 = 133.5
OP's posted peak hp is 85.5 and peak torque is 104.
djkeev
djkeev is offline
PostPosted: Wed Aug 04, 2021 3:55 pm    Post subject: Re: Rocky Jennings Motor value Reply with quote
114 x 0.85 = 97
157 x 0.85 = 133.5
Thank you sir!
Dave
Ghia
Vanagon
Beetle
Zeitgeist 13
PostPosted: Wed Aug 04, 2021 4:11 pm    Post subject: Re: Rocky Jennings Motor value Reply with quote
The RJE 2.3 I have experience with had port work on the head and a higher lift cam. I observed this engine being built by my friend who is a former VW/Porsche tech with a kit supplied by Rocky. As I mentioned before, I’ve driven both this van and another friend’s brand new 2.5 offbrand swap, and they felt roughly the same in power output. There’s no way the OP’s Dyno graph corresponds to a solid running RJE 2.3
Casey--
'01 Weekender --> full camper
y u rune klassik?
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Wed Aug 04, 2021 4:15 pm    Post subject: Re: Rocky Jennings Motor value Reply with quote
Well, there ya go. This engine might not have all those things mentioned. This is only the engine at hand, not the one your bud did.
As before, this engine will be 'on the market' for a while, and with all the data provided, will likely fetch less than half what the seller would want.
Just go easy on this feller, Z, its a waste of your brain cells.
-bobby
djkeev
djkeev is offline
PostPosted: Wed Aug 04, 2021 6:30 pm    Post subject: Re: Rocky Jennings Motor value Reply with quote
Why didn’t you just mention this information at square one instead of replying with the defense crap you initially did?
Dave
Ghia
Vanagon
Beetle
Zeitgeist 13
PostPosted: Wed Aug 04, 2021 7:56 pm    Post subject: Re: Rocky Jennings Motor value Reply with quote
I mentioned it in the tenth post of this entire thread. Plus, by now you should recognize that I rarely make a forceful assertion that isn’t done tongue and cheek.
Casey--
y u rune klassik?
Abscate
Abscate is offline
PostPosted: Wed Aug 04, 2021 11:30 pm    Post subject: Re: Rocky Jennings Motor value Reply with quote
16CVs wrote:
I'd like to know more about what blewed up my Manitou's Transmission?
Stacy
Probably a bad Port Manitou. Try a Fonseca brand.
.ssS!
SurfaceRust
SurfaceRust is offline
PostPosted: Thu Aug 05, 2021 7:25 am    Post subject: Re: Rocky Jennings Motor value Reply with quote
114 x 0.85 = 97
157 x 0.85 = 133.5
For what its worth the GW motor numbers likely have their EFI system included. They claim that adds approx. 10hp and some torque as well. Without this you could guess the GW motor would make 87 whp which is very close to what the RJE dyno says
Page 3 of 3
