Grassshopper Samba Member
Posted: Thu Aug 05, 2021 2:22 pm Post subject: Bus Relocation |
Hey! I have a 67 SO-42, it is located in the Gaylord/ Grayling area and I am now in the process of securing a trailer.
Issues
1. It has been in the same spot since 93
2. I am trying to get a Uhaul car trailer
3. I need to move it to Caseville
What do I need?
1. I know I need 4 tires and rims
2. Someone with a winch
3. Someone knowledgeable on where to winch from
We are shooting for mid August or early September, any one who can help would be appreciated with advice or tires and Rims I can buy. |
boulderz Samba Member
Posted: Thu Aug 05, 2021 2:55 pm Post subject: Re: Bus Relocation |
Does it roll? Likely that it doesn't (brakes will be frozen to the drum) but maybe if it was inside it will. If not, you have two options: 1. Drag it kicking and screaming on your trailer with the winch, or 2. Pull the drums and remove the brake components so it rolls. This will take some specialized tools like a puller. After your first one you'll get faster..
As for the winch, you can use a come-along which you can buy at Tractor Supply or Home Depot. Hook it to the trailer and hand winch the bus up. Hook the other end around the front beam. If the come-along isn't long enough, extend it with a heavy ratchet strap.
If you rent a uhaul trailer, it should have winch straps which go over the tires. They work well. Otherwise 2 heavy duty ratchet straps, one on each end over a stout part of the bus undercarriage (beam, etc.).
Take pictures, drink beer! |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 363 Location: Mississippi
Posted: Thu Aug 05, 2021 4:23 pm Post subject: Re: Bus Relocation |
Whatever you do, I highly recommend you use a trailer and if they don't have a trailer for the love of humanity do not settle for one of their tow dollys. The ones that tell you that you can't back up with a vehicle on the dolly, cause they aint joking. Take a can of WD-40 to spray on the trailer in front of/under the tires if the wheels are locked up. |
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 767 Location: New England
Posted: Thu Aug 05, 2021 5:08 pm Post subject: Re: Bus Relocation |
If you can, get the version of the uhaul trailer with the solid ramps. The expanded metal ramps will make it difficult to drag a locked wheel up onto the deck. I winched my bus, with two stuck drums, on a uhaul trailer in about 10 minutes with a come-along and a bottle of dish soap. Of course this was after 45 minutes of fighting to pull the left rear drum. |
widehatch Samba Member
Joined: May 27, 2007 Posts: 775 Location: Memphis, TN aka The Armpit of the South
Posted: Fri Aug 06, 2021 5:31 am Post subject: Re: Bus Relocation |
be prepared to pull the brake drums and remove the brake shoes. _________________ Missouri Micros |
buspeople Samba Member
Posted: Fri Aug 06, 2021 6:23 am Post subject: Re: Bus Relocation |
I’m located in hillsdale..I don’t have any extra rims but I’m replacing a set of tires today. You’re more than welcome to the old set |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Aug 06, 2021 7:30 am Post subject: Re: Bus Relocation |
As for a set of roller wheels/tires... Don't try too hard trying to secure bus rims in the ideal size. Call your beetle-owning buddies and get a set of rollers off a bug. $5-10 a piece around Boise
Run a 10' strap around the front beam- not just at one anchor point. And certainly do not just slap a hook on something.
The brakes may not be seized. Optimism...
Don't back the trailer to the front of the bus if it's not on decent ground. Push the bus to a good place to do the trailer loading if you can. _________________
EverettB wrote: |
FU#5 |
aa390392 Samba Member
Posted: Fri Aug 06, 2021 9:51 am Post subject: Re: Bus Relocation |
Take pics...we like pictures..and progress report.
Best of luck. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Clara Samba Member
Posted: Fri Aug 06, 2021 6:10 pm Post subject: Re: Bus Relocation |
hitest wrote: |
Don't back the trailer to the front of the bus if it's not on decent ground. Push the bus to a good place to do the trailer loading if you can. |
x2
don't pull on the bumper or the bumper gets bent.
If the bus is stuck in the mud, you can break your comealong on it.
put the strap on the big tube right above that greasy chunk of wood, not on any of the little tubes
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sat Aug 07, 2021 2:25 am Post subject: Re: Bus Relocation |
As these folks have suggested, see if you can get the wheels to turn, dragging locked up wheels is a pain, they do sell/rent ? a winch that you can attach to a trailer hitch, or a come-a-long works well, as for tires, as suggested, try to borrow some rims from others that have a Bus or Bug, or pull the rims from the Bus & find a tire shop that will sell you used crap tires, $5- $10 each max, you may need to hit more than 1 tire shop, just explain what your doing with them, and don't pay to have them balanced. I've pulled many long sitting Buses, each one is an adventure and different.
Another crazy way to get it on a trailer, if the wheels turn:
Block the wheels on the trailer and wrap a chain around the front beam & tow it up on the trailer, I've done this a few times, but it is a bit skeetchy....
You can also find a Tow company that will pull the Bus & drop it on your trailer, but you will need to figure out how to get it off the trailer. _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Aug 09, 2021 9:10 am Post subject: Re: Bus Relocation |
Grassshopper wrote: |
Issues
What do I need?
Get ahold of Bob Ellis from the Mid Mitt VW club. He can help you. I dont remember his username on Samba. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Tue Aug 10, 2021 9:15 pm Post subject: Re: Bus Relocation |
If the brakes are stuck to the drums. Remove one lug bolt per in the areas each shoes reside in. Use a long thin punch thru the lug bolt holes in each drum to hammer on the spines of the brake shoes. They will pop loose quickly that way. No need for a drum puller to get them rolling. _________________ In Stereo, Where Available! |
Posted: Fri Feb 03, 2023 6:25 am Post subject: Re: Bus Relocation |
Update:
The bus is getting relocated around March or April. I plan to get a U-Haul trailer and use come alongs, Ratchet straps, and WD-40. The rims are decent on it but I may need tires. Also, free lunch to each of one of you who feel like helping lol. Otherwise I might manage with some elbow grease.
I tried looking up Bob Ellis on FB and the Mid Mitt VW club on FB as well with no luck, if anyone can point me in the correct direction please let me know. |
Posted: Sun Apr 02, 2023 5:24 pm Post subject: Re: Bus Relocation |
We moved the bus! Getting it off the trailer was way harder than getting it on. The interior is decent and has the ORIGINAL CURTINS in good condition!! Almost everything is with the bus and I
mtnbus Samba Member
Posted: Sun Apr 02, 2023 6:30 pm Post subject: Re: Bus Relocation |
nice work!
more photos when you can.... |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Mon Apr 03, 2023 2:53 am Post subject: Re: Bus Relocation |
Wow, good for you as you saved the bumpers on the extrication by following all the great advice. She has great patina and will buff out nicely. Please be gentle when opening it up as it appears original and your documentation will help everyone as well as yourself. It’s only original once.
Looking forward to interior images and mechanicals. I was told here to never toss anything original VW to my Westy Poptop and that was great advice.
Split Bus Projects/Builds and Preservations
https://www.thesamba.com/vw/forum/viewtopic.php?t=627245
Congratulations she is beautiful
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Stocknazi Samba Member
Posted: Mon Apr 03, 2023 6:32 am Post subject: Re: Bus Relocation |
That looks like a very nice Westy. Should clean up real nice.
How's the interior? _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Mon Apr 03, 2023 12:08 pm Post subject: Re: Bus Relocation |
StockNazi wrote: |
How's the interior? |
Not bad. It is musty and I plan to remove it to refresh it. All the interior is there. He packed it full of stuff and when it had a roof leak at one point, the stuff on top of the interior got ruined but the interior itself seems fine. I am cleaning it out later this year when I am back in state for vacation. The pop up canvas is long gone though. |
Posted: Mon Apr 03, 2023 12:25 pm Post subject: Re: Bus Relocation |
Working on getting the cover up, then I am going to use a come along and pull it in.
