VW Addict Samba Salesman
Posted: Thu Aug 05, 2021 10:49 am Post subject: Worst case of corrosion I ever seen on a VW Engine |
Was out picking the other day at an old man's yard with quite a few cars a hundred miles or so from home and stumbled upon this... never have I seen a car corrode so badly! Eeek!
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Thu Aug 05, 2021 1:58 pm Post subject: Re: Worst case of corrosion I ever seen on a VW Engine |
Whoa! it's returning to the earth. The circle of life.. _________________ 1972 Standard Beetle
1969 Baja Beetle
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Thu Aug 05, 2021 2:01 pm Post subject: Re: Worst case of corrosion I ever seen on a VW Engine |
That will buff out. _________________ Glenn
Member #1009
#BlueSquare |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Thu Aug 05, 2021 3:55 pm Post subject: Re: Worst case of corrosion I ever seen on a VW Engine |
Yeah, too much moisture'll do that - there is a 36 horse, at a salvage, near me, that looks like that - too bad - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
EVfun Samba Member
Posted: Thu Aug 05, 2021 4:44 pm Post subject: Re: Worst case of corrosion I ever seen on a VW Engine |
Glenn wrote: |
That will buff out. |
Nah, it's a mechanical part... JB Weld can fix that!
On a more serial note, I would be curious what is inside that case. I think it could be disassembled with a large flat blade screwdriver at this point. _________________
Wildthings wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Thu Aug 05, 2021 6:04 pm Post subject: Re: Worst case of corrosion I ever seen on a VW Engine |
EVfun wrote: |
Glenn wrote: |
On a more serial note, I would be curious what is inside that case. I think it could be disassembled with a large flat blade screwdriver at this point. |
Beat me to that thought!
No need for a screwdriver. Just pick it up and it will disintegrate before your eyes. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
consvws Samba Member
Joined: April 07, 2009 Posts: 950 Location: Roseburg, OR
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24131 Location: Southeast USA
Posted: Fri Aug 06, 2021 7:18 pm Post subject: Re: Worst case of corrosion I ever seen on a VW Engine |
People complain about oil leaks, but an oily mess would have saved it.
Cup half full, though. It looks like some great salvage parts, heads, etc. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
