satterley_sr Samba Member
Joined: March 31, 2005 Posts: 650 Location: Belleville,MI
Posted: Tue Aug 03, 2021 4:15 pm Post subject: Rear Tires |
I had a set of 195/65R-15's so I used them on my buggy. Now I'm thinking some larger rear tires would improve the rake. Without buying new wheels, would a 215/7r-15 rear tire improve the look?
_________________ DDC racing |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Aug 03, 2021 6:11 pm Post subject: Re: Rear Tires |
Yes go bigger...
I'm running 255/50R15 on rear but I'm probbly pushing 100hp at the wheels...
NJ John Samba Member
Joined: September 21, 2007 Posts: 2223 Location: HdG, MD & NJ
Posted: Tue Aug 03, 2021 6:27 pm Post subject: Re: Rear Tires |
It will improve the rake. The skinny rim will limit your choices. But, that tire should help. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
jspbtown Samba Member
Posted: Thu Aug 05, 2021 6:53 am Post subject: Re: Rear Tires |
TireRack.com has all the specs you need to help determine size.
You will need to know your rim width as that will limit the width of the tire you can mount. A taller sidewall will help with the ride and give you more rake. You can measure the current diameter you have and compare it to the specs of the new tires you are considering. |
EVfun Samba Member
Posted: Thu Aug 05, 2021 5:18 pm Post subject: Re: Rear Tires |
jspbtown wrote: |
Right on! I just used that site to find that the largest 70 series tire size for a 5.5 inch wide wheel is a P215/70R15 tire. That tire is just shy of 27 inches tall (26.9 inches tall) so it should fill up the fender a lot better than the 25 inch tall tire you are currently running.
A taller option (and remember that this is changing your gearing too) would be a P215/75R15 tire. It is about 27.7 inches tall. _________________
Wildthings wrote: |
mark tucker Samba Member
Posted: Mon Aug 09, 2021 7:49 pm Post subject: Re: Rear Tires |
I ran 15"x33" for a few years then 16x31 due to better price. both on 12"wide wheel then in the rainey season when the wife was driving it I put on 235 70 15 on 8" wheel .wally worls has the best prices on tires Ive found. I like the solar tires, there cheep, there round and great tread pattern as well as quiet. anf good tracksion&handling.and they are not china, there korean!!sumuito or something like that, 3rd bigest tire companty in the world and made in lots of places. they even make skineys for the front that work great!!! |
Posted: Mon Aug 09, 2021 7:51 pm Post subject: Re: Rear Tires |
mark tucker wrote: |
order on line and pick up at store. Ive had tomany junk mitchlens&goodears&firedstoners. sofar the solar tires are 100% better than those name brands. |
