Wide 5 smoothies and Am-Eagle 5 spokes on EMPI disc brakes....
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
RandyV
RandyV is offline
PostPosted: Wed Aug 04, 2021 7:13 pm    Post subject: Wide 5 smoothies and Am-Eagle 5 spokes on EMPI disc brakes.... Reply with quote
So a few questions....(I did search but after several pages gonna just ask)....
#1.) Safe to assume I can just bolt up stock smoothies to my wide 5 empi disc brakes using stock lug bolts? (This would be temporary)
#2.) Recommendation for studs & nuts for A.E. 5 spokes?? (Going to run smoothies for a few weeks, then install studs and go to 5 spokes later
#3.) Recommendation for acorn (or ??) lug nuts for the smoothies once studs are installed??
Any other tips/suggestions for setting up either wheel type in this setup?? (Do/Don't loctite the studs into the discs/drums......never use an impact on them etc. etc.)
Thanks in advance!
74 Thing
74 Thing is offline
PostPosted: Thu Aug 05, 2021 11:09 am    Post subject: Re: Wide 5 smoothies and Am-Eagle 5 spokes on EMPI disc brakes.... Reply with quote
For the studs get these and loctite them in:
https://www.ebay.com/itm/265205712585?ViewItem=&item=265205712585&vxp=mtr
For lug nuts the McGard nuts and washers are hard to beat they don't rust and the washers are nice and thick
https://www.summitracing.com/parts/mcg-61002
Don't buy the cheap made in China stuff or you will regret it when the stud stretches or the lug nut and washers rust.
RandyV
RandyV is offline
PostPosted: Thu Aug 05, 2021 6:16 pm    Post subject: Re: Wide 5 smoothies and Am-Eagle 5 spokes on EMPI disc brakes.... Reply with quote
Awesome!! Those both look great!! Thank you!!
Now I just gotta find the studs in stock since the ebay ad looks like they're out. Wink I'll check lug nut guys themselves and maybe can get everything from them.??
EDIT: Man....lug nut guys not showing ANY studs currently! (And a hard search shows my only option may just be empi sets) Confused
King_vw61
King_vw61 is offline
PostPosted: Sun Aug 08, 2021 7:01 pm    Post subject: Re: Wide 5 smoothies and Am-Eagle 5 spokes on EMPI disc brakes.... Reply with quote
Kartek should have them
https://www.kartek.com/parts/kartek-off-road-12mm-...ength.html
Say Hi to Mike for me.. Wink
1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
