69 road race Ghia rebuild
overboost
overboost is offline
PostPosted: Sat Aug 14, 2021 4:35 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
Nothing beats the sound of the 48 IDA for sure. That groan leading into WOT is nothing short of a sirens song.
The older I get... The faster I was...
Rome
Rome is offline
PostPosted: Sat Aug 14, 2021 9:18 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
Very impressive fabrication and assembly work!
Will you add small, short "J" hooks to the rear shocks' bottom mounting studs to hold those handbrake cables steady so that they don't droop or whip when driving over bumps?
Ian Godfrey
Ian Godfrey is offline
PostPosted: Sat Aug 14, 2021 2:51 pm    Post subject: Re: 69 road race Ghia rebuild Reply with quote
Rome, yep, I haven't finished them yet, but I was waiting until I get the axles in so I can see how high I can lift them up. I'm thinking of making brackets that with a hole so I can use the lower shock bolt as an anchor.
Ian Godfrey
PostPosted: Sun Aug 15, 2021 2:35 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
So, on to the gear box. It's a Berg 5 in a Zig Zag '76 case, with a Quaife torque sensing diff. This kind of diff is very good on acceleration but doesn't work like a ZF clutch style diff while braking. I have a ZF which I would prefer to use but I worry about its strength. Quaifes are guaranteed not to break and have Bus output splines and use Bus 100mm CV's. We'll see how it all works when I drop the clutch. I don't build gearbox's, Dave Butler in Brisbane built mine and took quite a few Kilos out with drilling. Inside is a work of art Very Happy But I did take care of lightening the nose cone and the clutch cable guide, as well as drilling the clutch shaft.
Anyway, the alloy mounts I made
mid mount
the gear box
And the finished mid mount with RevShift BMW urethane mounts with alloy spacer.
Ian Godfrey
PostPosted: Sun Aug 15, 2021 2:40 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
I like original gear shift couplers much better than the aftermarket ones with red urethane. I have had them just crumble with old age Mad
And now some gearshift porn, a CAE 5 speed shifter. To fit it you need to weld a plate to the top of the tunnel and 'hack' the opening in the tunnel so you can get 5th and reverse, and make some custom parts but...... it's all worth it
lastly I finished up the clutch cable. I was putting it together and noticed I had no holes drilled in the adjuster so being the 'sick puppy' I am I stopped to drill a couple of holes! Embarassed
finished up with a seal on the end of the bowden tube
overboost
PostPosted: Sun Aug 15, 2021 4:55 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
This thread is straight up car porn. Love it!
TRS63
TRS63 is offline
PostPosted: Sun Aug 15, 2021 7:08 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
That thread is amazing, thanks!
Antoine
Antoine
My 62 ragtop daily driver:
My 52 Standard Zwitter :
Ian Godfrey
PostPosted: Mon Aug 16, 2021 12:54 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
Thank you for the comments Smile
Next job was axles/drive shafts, I'm not sure what they get called in the US.
I've used Vanagon axles as they are the right length and way stronger than type 1. I had them drilled out for lightness.
I've also used type 2, 100mm lightened, race prepped CV's with Stage 8 lock bolts. These are a fiddle, you torque them up, fit the plate, then put on the circlip, and loose a couple of circlips when they fly into space. Rolling Eyes
but the bolts do not come loose and thats what matters, dragging an axle when one end comes off is no fun
the inner
the outer
top view
and finished both sides
now I'll finish of the hand brake cables.... well soon anyway Wink
slayer61
slayer61 is offline
PostPosted: Mon Aug 16, 2021 6:56 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
What an inspiration. Thanks Ian!
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
halbug
halbug is offline
PostPosted: Tue Aug 17, 2021 12:30 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
Very much agree!
Ian, do you expect the Ghia to become lighter that stock when done, or are you hoping to offset the additional weight of the go fast goddies?
Cheers Lars
Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
My Berg5: https://www.thesamba.com/vw/forum/viewtopic.php?t=730276&start=0
Ian Godfrey
PostPosted: Tue Aug 17, 2021 1:09 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
Halbug, I HOPE it will be lighter. A stock '69 coupe is 870Kg i believe,
I'm working towards 800 Kg, so far all my lighter parts offset the heavier parts (5 speed/roll cage), my spread sheet has about a 20 kg saving so far.
I am leaving the body and pan all steel, no holes, but there will be good savings with no sound deadening, radio etc, light weight seats and fiberglass bumpers with aluminium brackets. I will try to make polycarbonate rear quarter windows as well. A fiberglass engine lid would be nice but nobody seems to make one at the moment.
I've also taken weight out of the engine with Nickie cylinders.JP pistons, Carrillo rods, super light pulley, no heat exchangers and aluminium tail pipe/muffler from the collector back. Dry sump tank will be behind the seat bringing that weight nearer the centre of the car
I've focused getting weight out of the back as much as possible.
I think 800Kg is possible, plus me...... I see a diet in my future Rolling Eyes
just for interest a '73 911 RS is 975 Kg, and I want to catch them Question
Ian Godfrey
PostPosted: Thu Aug 19, 2021 2:50 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
on to some last small jobs:
the hand brake need to be shortened because of the large shifter base, so I 'cut and shut' it, taking 2 inches out and drilled a few holes in it and the pivot. I;m waiting on some parts to finish the cables.
I tidied up the front sway bar with better high misalignment rod ends from QA1.
the ones that came with the front end went into a bind situation as the suspension compressed. the new one give 55 degrees of movement
fitted
Ian Godfrey
PostPosted: Thu Aug 19, 2021 3:02 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
The rear hard lines needed clips because of their length. I found these aluminium ones for the 3/16" (4.75mm) line
I drilled and tapped some M5 holes in the arms:
these little details make me very happy Laughing
I designed and had machined and anodised some centre caps, the car won't go any faster, the beauty is that this is a hobby
and last is a nice view of the pan with unfinished hand brake brackets...... nearly done.
7 years of thinking and a year of work Shocked
halbug
halbug is offline
PostPosted: Thu Aug 19, 2021 3:56 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
Ian, I really like your dedication to detail!
I love your handbrake and may copy it. Not because of lightweighting, simply because it is looking so cool Cool
And it will match the handles I made for seat adjustment...
Nice built!!! Let's get it racing! Twisted Evil
slayer61
slayer61 is offline
PostPosted: Thu Aug 19, 2021 6:43 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
Excuse me while I wipe the drool off of my keyboard.... Drool
Very nice.
Ian Godfrey
PostPosted: Sat Sep 04, 2021 8:48 pm    Post subject: Re: 69 road race Ghia rebuild Reply with quote
Time for a big of an update.....
I've been trying to sort out my steering, some stops in the rack so the tyres won't hit the inner body, ordered a new starter, and worked on the fuel tank.
my old set up was a Holley red and matching 'dead head' regulator. Noisy and lots of plumbing so I've gone for a more modern 'in tank' solution.
https://aeromotiveinc.com/product/phantom-200-stealth-fuel-system/
It was not to difficult to fit, it has a compressible gasket that accommodates the uneven top of the tank, as well as the pump, filter and baffle all in the tank.
fortunately the fuel gauge float goes sideways
and got to use a spanner I hardly ever use Wink
I took the this plug out so I could shine a light inside and see what I was doing.
Of interest I coated the inside of this tank over 10 years ago with a POR 15 tank kit and it still looks perfect, no rust.
[/url]
halbug
halbug is offline
PostPosted: Mon Sep 06, 2021 4:35 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
Hi Ian, very nice Twisted Evil
I was tempted for a moment and looked at your link... but I will stick to my "totally stealth" plans Laughing
Thank you for sharing
Cheers Lars
Braukuche
Braukuche is offline
PostPosted: Mon Sep 06, 2021 6:56 am    Post subject: Re: 69 road race Ghia rebuild Reply with quote
Thread never ceases to amaze.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
Ian Godfrey
PostPosted: Sun Sep 19, 2021 9:02 pm    Post subject: Re: 69 road race Ghia rebuild Reply with quote
I've been waiting on a few parts to arrive, first was modern rear bump stops.
I only have 90mm of rear travel metal to metal and 60mm before the bump stop so I got 2 different heights of foam bump stops and threaded the arm so I could just screw them in. These are the short ones, 32mm
Ian Godfrey
PostPosted: Sun Sep 19, 2021 9:14 pm    Post subject: Re: 69 road race Ghia rebuild Reply with quote
The other job was a bit more complicated. The Mendeola front suspension is very good in its adjustability along with a good camber curve, and it fits in with very little trimming of KG steel. But.... it has quite a lot of bump steer, over 3mm across the wheel travel. Halbug solved this by lowering the rack into the tunnel, inverting the tie rod ends and reworking the rack mount. His solution is very elegant and I was tempted Confused
But in the end I went a different way, raising the outer end of the tie rods with spacers.
Unfortunately I couldn't find any 14mm high misalignment rod ends so I opted for 1/2". I drilled out the 1/2" thread and retapped it M14, luckily both tie rods (Golf 1) are RH thread, and then I used 1/2" bolts and spacers to get the 19mm rise.
I now have to measure the bump steer to confirm if I need to change the size of the spacer.
Meanwhile I've been woking on my engine upgrades, match porting manifolds to new heads. I'll post some pix in a few days
Page 5 of 8
