charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Thu Aug 26, 2021 9:01 am Post subject: Best uses for external hookup ports |
I’m sure a few of you have seen my build thread and said to yourself.. wtf is up with those external hookups on that green van?
Yeah, non standard. I know.
So I’ve got 4 circular hookup holes. I’m debating exactly what to use all of them for. I think stock is: external power, water, vent line, and mouse holder.
120vac input seems interesting
Water input/fill is necessary
Don’t need a vent as im not doing propane.
Leaves me with two ports.
Ive seen External solar which seems cool
Shower out
Air compressor
Anyone else have good uses for the spare ports? _________________ -------------------------------------------------
An example of my labor in action:
https://www.instagram.com/wileythewesty/
My Build Thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=730525&highlight= |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6245 Location: Portland OR
Posted: Thu Aug 26, 2021 9:15 am Post subject: Re: Best uses for external hookup ports |
_________________ 89 Westy 2.1 Auto |
Zeitgeist 13 Samba Member
Posted: Thu Aug 26, 2021 9:34 am Post subject: Re: Best uses for external hookup ports |
For our Eurovan I've recently installed external boxes for both 12v (solar) and 120vac in, and plan on adding a third for air out. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Thu Aug 26, 2021 10:50 am Post subject: Re: Best uses for external hookup ports |
I think we VW addicts need talk our venders into fabbing a “donations” box to add to the mix.
Make our vans work for us while parked _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2237 Location: Olympia, Washington
Posted: Thu Aug 26, 2021 11:02 am Post subject: Re: Best uses for external hookup ports |
As personalized as the vans can be, that a really subjective question; solar, beer tap, city water, etc. To each their own. What do YOU want to do with it? _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
SCM Samba Member
Joined: January 26, 2011 Posts: 3115 Location: Bozeman MT
Posted: Thu Aug 26, 2021 11:30 am Post subject: Re: Best uses for external hookup ports |
dobryan wrote: |
If you off road a lot an air pressure port with an internal compressor would be great. |
Or if your van is basecamp for mountain biking trips or time spent at a lake/rier with inflatable "vehicles". _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
designer Samba Member
Joined: November 05, 2009 Posts: 484 Location: Idaho-but just the tip
Posted: Sun Aug 29, 2021 8:31 pm Post subject: Re: Best uses for external hookup ports |
i put a quick connect compressor fitting in one of mine. best thing ever. I went with the ARB twin air compressor as the first one i put in couldn't blow up a soccer ball. fits like a glove behind the driver tail light. _________________ __________
87 Syncro Westy : 2.5l
"It is that annoying, accelerating downhill so I can make it up the next hill in the same gear. Foot to floor hoping I can get out of the way of other cars getting onto the highway." - somebody on here around 2013. |
the_benjamin_effect Samba Member
Joined: May 31, 2010 Posts: 192 Location: Gateway to the North Cascades, Washington State
Posted: Sun Aug 29, 2021 10:44 pm Post subject: Re: Best uses for external hookup ports |
designer wrote: |
i put a quick connect compressor fitting in one of mine. |
Agree. I did the same. I went so long without deflating my tires because I had no way to re-inflate until I installed my on-board ARB compressor. If you travel off road often, even on logging roads, washboards, beach, etc., makes a world of a difference. Best mod I have made. _________________ -1967 Sundial Camper 1914cc "Sunny"
-1978 Deluxe Westfalia Jake Raby built PowerStroke 2109cc "Westy"
-1987 SYNCRO Westfalia GoWesty 2400cc "Ruby"
-2000 Subaru Impreza Sport EJ22 ¼ million miles "Trusty"
International Association of Machinists and Aerospace Workers. I.A.M. 751
International Brotherhood of Naval Flight Engineers. I.B.N.F.E. LOCAL 8251
My other ride has 18,400 horsepower! |
