BonesBIR Samba Member
Posted: Thu Jun 10, 2021 6:07 pm Post subject: Period Rally Fastback |
I have recently aquired a 1968 Type 3 Fastback that the previous owner built as a go-fast street car before parking it 15 years ago.
The car has been substantially modified, engine bay expanded to accommodate type 1 tins and dual carbs, the front clip is a one piece fiber glass and there are Gene Berg parts used throughout.
The point. I collect and restore old racing motorcycles and have decided that this car really wants to be a period rally car. I believe this is the folder to document the build.
Inspiration:
My Car:
Lot's to do, best get after it. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Thu Jun 10, 2021 8:54 pm Post subject: Re: Period Rally Fastback |
thats dope! ive been wanting to do something like that with a fasty or a notch so i will be following along 100%. maybe a 2in lift. a subaru ez30 and 6speed swap. tall tires. long travel irs.
oh wait... thats not period correct. not unless you talking about this period
good luck! and welcome to the samba! _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Thu Jun 10, 2021 9:15 pm Post subject: Re: Period Rally Fastback |
Chickensoup wrote: |
good luck! and welcome to the samba! |
I wont likely do any more suspension than what is on a baja bug, with the appropriate wheel/tire combo. I still want it to be streetable.
As far as the powertrain, it already has an overbuilt 1800 mill and a Close Ratio four speed w/ Gene Berg short throw shifter. The previous owner grew up in a drag-racing VW family, so it is really going to be about getting the chassis up to the level of the running gear. |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Fri Jun 11, 2021 6:32 am Post subject: Re: Period Rally Fastback |
Dual Weber DCNF carbs would be a huge, period correct improvement. Get some big Marchal lights for the front… looks like fun _________________ modok wrote:
Posted: Fri Jun 11, 2021 11:09 am Post subject: Re: Period Rally Fastback |
esde wrote: |
Dual Weber DCNF carbs would be a huge, period correct improvement. Get some big Marchal lights for the front… looks like fun |
You mean these?
esde Samba Member
Posted: Fri Jun 11, 2021 7:18 pm Post subject: Re: Period Rally Fastback |
Those are Dellorto DRLA, which IMO are actually a better carb than the Weber DCNF. But the DCNF was one of the carbs that Berg sold a ton of back in the day, and as they're a little shorter than the DRLA they fit a little better in a type 3. But with the right manifolds those DRLA could work too. _________________ modok wrote:
Posted: Fri Jun 11, 2021 7:26 pm Post subject: Re: Period Rally Fastback |
esde wrote: |
Those are Dellorto DRLA, which IMO are actually a better carb than the Weber DCNF. But the DCNF was one of the carbs that Berg sold a ton of back in the day, and as they're a little shorter than the DRLA they fit a little better in a type 3. But with the right manifolds those DRLA could work too. |
the Engine bay has been modified to allow for more room on top of the engine, it was intended to accommodate a type 1 fan shroud, dune buggy manifold with these carbs on top. In reality there is enough room for a supercharger, if I wanted to go that route. There is no room for cargo or groceries, and that is OK for this build. |
Posted: Sun Aug 01, 2021 1:35 pm Post subject: Re: Period Rally Fastback |
Moved up to the shop to prep for winter building and repairs.
Starting from the inside and working outward. |
Posted: Sun Aug 01, 2021 3:24 pm Post subject: Re: Period Rally Fastback |
Before and after. (1st cleaning pass)
Posted: Mon Aug 23, 2021 9:13 pm Post subject: Re: Period Rally Fastback |
Here is a concept sketch of the direction I am going
mkbug Samba Member
Joined: October 12, 2004 Posts: 145 Location: Northern California
Posted: Tue Aug 24, 2021 10:51 am Post subject: Re: Period Rally Fastback |
I like it.
One suggestion based on my experience...put the fuel filler in the center of the hood...not off to one side. Makes it so I dont have to worry about what side of the pump I have to go to.
Good luck on your build. _________________ I'm Martin
My Build: https://www.thesamba.com/vw/forum/viewtopic.php?t=667183 |
Posted: Tue Aug 24, 2021 5:38 pm Post subject: Re: Period Rally Fastback |
Did get all the old carpet out and the pan cleaned.
Posted: Wed Aug 25, 2021 5:57 pm Post subject: Re: Period Rally Fastback |
I spent the day in the shop scrubbing parts.
I pulled my spare engine from out of the shed to begin tearing it down and cleaning it up. It had a set of single port heads on it, but I have a nicer pair of dual ports for it.
Engine # H017319R If I am decoding this correctly it is a 67-70 1500cc.
the R at the end meant it was re-manufacturered at some point after 1972, correct? Also, if my math is right, this is a good basis for a +53hp engine and certainly worth rebuilding.
Posted: Thu Aug 26, 2021 11:54 am Post subject: Re: Period Rally Fastback |
Ive never seen one with an "R". Usually, youll see a vw recycle symbol for factory rebuilt engines, or just a letter code for replacement cases. Although the factory, when rebuilding an engine for a costumer using a replacement case, was suppose to restamp the case to the original engine code that would of came with the car, so its possible the employee just wanted us to know its a replacement block as well.
either way, flip it over. If its a dual relief, keep it, if its a single, then it may be a factory replacement engine that was purchased for you car a long time ago.
Replacement cases, came with dual relief and larger oil passages. Recycled cases, were just original cases with whatever machine work they needed. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Thu Aug 26, 2021 12:30 pm Post subject: Re: Period Rally Fastback |
It is a dual relief case.
I'll be keeping it and rebuilding as a spare at some point.
thanks |
Posted: Sat Feb 05, 2022 10:14 pm Post subject: Re: Period Rally Fastback |
It has been a while since I have posted anything
I have been slowly getting the engine sorted out. I have since learned that is has a fairly well-put together 1776cc engine in it and the bores and heads are in decent shape. It is getting fresh gaskets and seals, an oil pump and a Gene Berg sump that I found in the boxes of spares.
The DRLAs have been rebuild and mounted on GB 580A intakes, with a set of CB sand rated intake filters.
Additionally, I had some wire mesh that I welded to a pair of headlight rings and mounted to the front clip.
Progress is progress.
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Mon Feb 07, 2022 1:57 pm Post subject: Re: Period Rally Fastback |
Good question with the wheels. these are a really nice set of Dan Gurneys, but I am finding they are too narrow for the tires I want to run. for now they are fine, but it is something to consider.
And yes, there is definitely some overlanding influence. I hang out with a bunch of Jeep overlanders, even though I am usually on a kitted out Husqvarna Dual-Sport Motorcycle. You do not see many over-road fastbacks, so why not. |
Posted: Sun Apr 24, 2022 6:47 pm Post subject: Re: Period Rally Fastback |
Engine went back into the car today. I needed to ensure to air cleaners will fit (they don't but it is workable) and the car is going into storage while we relocate.
