dhubz Samba Member
Posted: Fri May 21, 2021 7:35 am Post subject: Pertronix Flame Thrower Coil |
Is anyone familiar with these, I purchased a kit from CIP, came with carb/dist/coil/wires.
Is there a way to test the coil, is there something else I should be looking at? I was out driving yesterday, and it started to mis-fire and ended up stalling out. I towed it home. I checked for spark at the plug with an inline tester, no spark at the cylinder. I pulled the centre wire from the distributor and held it near ground, only got a very faint yellow spark. I replaced the Flame-Thrower coil with a Bosch coil I have, and the vehicle started right up. Is there something that would cause the flame-thrower coil to burn out? or Did I just get a bad unit, I probably have less than 20km on the engine since I put the parts in.
[/img] |
KAmes Samba Member
Joined: February 16, 2014 Posts: 876 Location: Illinois
Posted: Fri May 21, 2021 4:52 pm Post subject: Re: Pertronix Flame Thrower Coil |
That's curious about the coil. I guess if your back up coil works good that's a result, probably nothing you did caused it to fail. I've been using that carburetor and that distributor with a bosch blue coil for a long time now without any problems. |
sailtexas186548 Samba Member
Joined: December 01, 2014 Posts: 423 Location: Kemah, Tx
Posted: Sat May 22, 2021 6:31 pm Post subject: Re: Pertronix Flame Thrower Coil |
Coils just go bad sometimes, the quality of them has gone downhill since they these style aren’t used by OEMs anymore. Internal shorts, overheating, All kinds of stuff affects them. Leaving the key on and having power to the coil while the engines not running is not great for them either _________________ it's more fun loud and dirty |
larryducas Samba Member
Joined: October 25, 2011 Posts: 233 Location: Fallbrook, CA
Posted: Fri Aug 27, 2021 7:14 am Post subject: Re: Pertronix Flame Thrower Coil |
I bought a flame thrower coil, 3 ohm in my bay bus, type 1 motor.
I was running pertronix ignitor system.
The coil failed after 3 weeks of weekend driving. While it was working, it ran very hot.
The coil is completely open, no resistance anywhere. old bosch blue is back in.
I chalk it up to cheap chinese parts. not sure to trust pertronix anymore. _________________ 71 deluxe, 1968 type 1 engine rebuilt, 009 distributor, pertronix module, Empi 38 EPC / DGES carb |
sshae Samba Member
Posted: Fri Aug 27, 2021 9:04 am Post subject: Re: Pertronix Flame Thrower Coil |
For what it is worth, I installed the Pertronix coil and distributor on my buggy, but I could not get it to run without missing. I tried several different distributors, and for some reason they all seemed to work well at first, but within about 20 - 30 miles I would start experiencing missing again. I finally thought I had it, so I took a 150 mile trip... 75 miles from home it started missing again. The only thing I can think of was that maybe the coil was breaking down with heat (It was 95 degrees out that day). I ended up changing the distributor, wires, and coil over to Magnaspark and that fixed it. |
