jbost Samba Member
Joined: September 01, 2021 Posts: 2 Location: on the road
Posted: Wed Sep 01, 2021 4:33 pm Post subject: Noisy axle or CV before and after replacement |
Hi all,
We are on the road and have this situation. We took van in and had tires rotated and aligned (a front tire was wearing very unevenly - outside getting bald). This tire ended up on drivers' rear. A couple hundred miles later, there was some serious clunking going on rather suddenly. Isolated that it was related to the axle - only when clutch engaged, no noise when in neutral and coasting. Most notable when at low speed. It got really bad, really quickly. So we ended up getting the axles replaced. Apparently one of them had pretty dry grease in the CV. The problem then went away for few days, few hundred miles. But now its returning. More subtle, but notable and getting worse.
Any ideas on what this could be? Is the bad tire wear making the tire be at an angle that is causing some friction in CV that should not be there? Did the alignment throw something off? Would shocks in getting in need of replacement have anything to do with this?
We have a long haul on the horizon and trying to decide what to do...
Thanks!
1986 Vanagan Westfalia camper... |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7300 Location: Honolulu,Hawaii and France
Posted: Wed Sep 01, 2021 4:43 pm Post subject: Re: Noisy axle or CV before and after replacement |
double check the cv bolts are tight , axle nut and wheel lugs too. Lift the wheel, feel play. Until then, it's all worthless guesses....
Also what brand axle did they install? Prolly some chinese junk if it's a complete unit....rather than installing Löbro CV joints on your original shafts.
Your tire didn't do anything to it. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Yellow Rabbit Samba Member
Posted: Wed Sep 01, 2021 5:07 pm Post subject: Re: Noisy axle or CV before and after replacement |
| Did you get the old axle back? If not call the shop and see if it happens to still be there. New CV joints are crap. Get the old one and rebuild it. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4588 Location: ABQ NM USA.... Except when not
Posted: Wed Sep 01, 2021 6:11 pm Post subject: Re: Noisy axle or CV before and after replacement |
they make money on the parts and if it fails they warranty, they just replace the failed part. curious - if they repack and issue still exists, then what is the warranty and what is the next solution and who pays for the next solution?
and of course there are just the stories like this (mine): a decade+ ago, I got my wheels aligned while on a trip at the Firestone shop under my lifetime alignment...I got a urgent call that the brake pads were dangerously thin and HAD to be replaced for $480...I'm still on those same pads. I think the alignment went ok but I had it rechecked when at home. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Wed Sep 01, 2021 6:39 pm Post subject: Re: Noisy axle or CV before and after replacement |
On your original axle, you could have just gotten a long needle fitting for your grease gun, stuck the needle under the small end out the boot, and added grease to the bearings (you want the grease in the bearings and not in the boots). A lot of time this is all you need to do to get back on the road again, and even if it didn't work would not have cost you much.
You could have also tried just moving the boots on the axle shaft to force the axle one way or the other. This may quite a noisy axle for thousands of miles. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Thu Sep 02, 2021 9:15 am Post subject: Re: Noisy axle or CV before and after replacement |
| djkeev wrote: |
Reading repeated stories like this is certainly rekindling my strong dislike for so called auto repair shops…..
Can no one fix anything any more?
As mentioned, check everything to be tight. If they are tight you probably need grease.
When you can retail a new axle shaft complete with two new CV’s for $80 ….. you really can’t expect them to have grease can you?
Consider that one quality CV joint with a new boot is is about what they sell a entire crap unit for.
Heck I paid almost $40 for one quality new CV boot!
You didn’t know ….. and you had to get on the road again, I get it.
Dave |
Please Dave, stop tarring all mechanics with that brush.
Plenty of people show up at the shop - and when given a choice of a cheap Chinese axle replacement or a double-the-cost CV joint replacement - they choose the cheaper option.
I'm in a position where I refuse to do the cheap way but plenty of tradesmen aren't. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Thu Sep 02, 2021 9:22 am Post subject: Re: Noisy axle or CV before and after replacement |
| Jake de Villiers wrote: |
I'm in a position where I refuse to do the cheap way but plenty of tradesmen aren't. |
The sad part is this woman paid for the expensive work and got the cheap work which seems not have even been done well, a double insult.
The first time I ever rebuilt CV's I am sure it didn't take me any longer than five hours to do the work, though I did pretty much ruin the clothes I was wearing. With experience CV's would become a quick, easy, and not that dirty of a job. |
harvgwen Samba Member
Joined: February 11, 2021 Posts: 308 Location: Okanagan Valley, British Columbia
Posted: Thu Sep 02, 2021 11:00 am Post subject: Re: Noisy axle or CV before and after replacement |
When I go to do my CV’s, is there a way to determine if my shafts are original German ones or already replaced with Chinese? _________________ 1986 Westfalia Vanagon, 2.2 Subaru
Okanagan Valley, British Columbia |
Posted: Thu Sep 02, 2021 11:07 am Post subject: Re: Noisy axle or CV before and after replacement |
| harvgwen wrote: |
| When I go to do my CV’s, is there a way to determine if my shafts are original German ones or already replaced with Chinese? |
Originals look like this:
Posted: Thu Sep 02, 2021 12:46 pm Post subject: Re: Noisy axle or CV before and after replacement |
Get a putty knife and with the rear wheel raised spin the tire while using the putty knife to scrape the crud off the joints, at least the inner ones. Fast and easy, just let the crud fall into a tray for easy disposal. |
Posted: Thu Sep 02, 2021 1:35 pm Post subject: Re: Noisy axle or CV before and after replacement |
Thanks for the info. _________________ 1986 Westfalia Vanagon, 2.2 Subaru
jbost Samba Member
Posted: Mon Sep 06, 2021 4:37 am Post subject: Re: Noisy axle or CV before and after replacement |
| Seems like the issue is that there is alot of horizontal play in the axle. The CVs are fixed in place but I can slide the axle 4" or more back and forth. When the axle is slid all the way towards the wheel it hits something (not sure what) and clunks. That is what was making the noise while driving. By pulling the axle back towards the transmission (and using the rubber boot to secure it) sound resolved. I think this is probably a short term solution. Wondering if the axles that show up as a fit for a Vanagan are different than what would actually be appropriate with a Subaru conversion? |
Posted: Mon Sep 06, 2021 4:40 am Post subject: Re: Noisy axle or CV before and after replacement |
| jbost wrote: |
Are there clamps on the small axle side of the boots?
If not pull the axle back and clamp It.
If so, remove the clamp and the lamp after pulling the axle back.
The clamped boot will help keep the axle shaft in place.
Ghia
Vanagon
Beetle
Posted: Mon Sep 06, 2021 5:43 pm Post subject: Re: Noisy axle or CV before and after replacement |
| The axle has to have axial movement to allow it to get longer and shorter as the suspension moves up and down. This is 100% normal. When installing new boots, I tend to position the boots to force the axle shaft toward the centerline of the van a bit as the axles will tend to move away from center in use. This way as the boots softens with age the axle will slowly move outboard a bit thus allowing the balls to ride over a larger area of the races instead of concentrating the wear in a smaller area. The total axial movement of the joints is around an inch, so if you are actually seeing 4" then you would have to have very short axles along with joints with far more axial play than the stock VW joints and/or the "C" rings would have to be missing. |
Corninmypoo Samba Member
Joined: October 31, 2021 Posts: 1 Location: San Diego
Posted: Mon Nov 01, 2021 2:51 pm Post subject: Re: Noisy axle or CV before and after replacement |
| djkeev wrote: |
| jbost wrote: |
Dave |
Hi there!
I have a funky noise in my 90 Westy with Auto trans. Might be related to this issue.
It was time, so I bought some replacement axles at O'Reillys. Maybe first mistake?
I had to grease pack them myself and I may not have put enough grease in there. ugh..
I'm hearing a knocking noise when I go straight or slight to hard lefta-hand turd and under a little load.
I don't hear it much at all when going right. It's worse when going straight and slightly uphill
I've tried all 3 gears. No difference. I do hear it as well when just crawling at about 1mph.
I recorded it and put a vid on You Tube.
If someone can listen to this and give me some wisdom, I'm be forever grateful!
https://youtu.be/p8PqpWOkK-k
Cheers! |
Posted: Mon Nov 01, 2021 4:35 pm Post subject: Re: Noisy axle or CV before and after replacement |
Water pump pulley?
Alternator bracket? |
