jb20thae Samba Member
Posted: Wed Sep 08, 2021 9:19 pm Post subject: Re: Fiberglass bumper/cladding repair |
Great info, thank you.
Flash Silver Metallic... paint bumpers body color, black, or the oem two-tone?? |
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1141 Location: Northern Nevada
Posted: Thu Sep 09, 2021 8:36 am Post subject: Re: Fiberglass bumper/cladding repair |
jb20thae wrote: |
The OEM silver/gray bumper color looks good with the original blue and burgandy colored vans, but does tend to fad to a semi-green-ish hue. I think it sort of clashed with Vesuve Grey and Flash Silver though.
My personal preference is either black or Flash Silver to match the body. If paining silver, I prefer the "rub strips" to be left black though.
I'm sure yours will look great, whichever direction you go!
Jim _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 951 Location: Northern California
Posted: Thu Sep 09, 2021 8:50 am Post subject: Re: Fiberglass bumper/cladding repair |
Thanks, all! Scarlett is now at the “spa” (body shop) for a fresh coat of OEM “Cloud Gray Metallic” paint on her bumpers/cladding. She will also get new paint on her front clip to remove the “road acne” accumulated over 31 years, and a new windshield! _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red
DuncanS Samba Member
Posted: Thu Sep 09, 2021 10:21 am Post subject: Re: Fiberglass bumper/cladding repair |
I might be wrong here, but I once heard the term "clip" referred to the part which was ruined in the accident. This means if you want the front part of a car you need to order a rear "clip".
Is this true? |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1348 Location: PNW - its a dry rain.
Posted: Thu Sep 09, 2021 2:28 pm Post subject: Re: Fiberglass bumper/cladding repair |
A little late but for others doing this. Here is a no fiberglass approach.
Mine were in pieces. I glued mine together with two part auto panel glue called Lord fusor. It shrinks a little when dry but hardens like concrete.
You can also form it with a wet finger. Make sure you remove any excess as it will require a grinder.
https://www.thesamba.com/vw/forum/album_search.php...ts=summary
_________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Thu Sep 09, 2021 3:03 pm Post subject: Re: Fiberglass bumper/cladding repair |
DuncanS wrote: |
Is this true? |
I was using the term generically to refer to a section of the body separated by seams or obvious edges. To be more precise, new paint will be applied to Scarlett’s entire front end forward of the driver/passenger doors and up to the “A” pillar seam with the roof.
Tornado Red
?Waldo? Samba Member
Posted: Thu Sep 09, 2021 3:06 pm Post subject: Re: Fiberglass bumper/cladding repair |
I have only ever heard a front clip meaning the front of the vehicle and a rear clip meaning the rear of the vehicle. A quick search on Google supports that nomenclature. |
Posted: Thu Sep 09, 2021 3:18 pm Post subject: Re: Fiberglass bumper/cladding repair |
Yah. I thought it sounded pretty weird. |
Posted: Thu Sep 09, 2021 11:38 pm Post subject: Re: Fiberglass bumper/cladding repair |
SyncroHead wrote: |
jb20thae wrote: |
Jim |
The oem silver/grey does seem to clash with Flash, doesn't it. Black would be easy but you lose the uniformity somehow. This looks good but it's the money shot angle
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32592 Location: Reading Pennsylvania
Posted: Fri Sep 10, 2021 5:26 am Post subject: Re: Fiberglass bumper/cladding repair |
West System is one of the easiest epoxy choices. They have pumps which deliver exactly the correct ratios. 10 oz cloth and some 406 colloidal silica to thicken it for certain applications. Disposable chip brushes and acetone for clean up. I always use exam gloves when chemicals have a part B. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
pdm777 Samba Member
Joined: August 06, 2012 Posts: 348 Location: Clovis, CA
Posted: Thu Jan 06, 2022 9:04 pm Post subject: Re: Fiberglass bumper/cladding repair |
Just DO NOT paint the bumpers
Black
Gloss Black
Satin Black
Wrinkle-Finish Black
BedLiner Black
Primer Flat Blat
_________________ 1990 Westy Full Camper |
Posted: Fri Jan 07, 2022 1:43 pm Post subject: Re: Fiberglass bumper/cladding repair |
pdm777 wrote: |
Black
Gloss Black
Satin Black
BedLiner Black
Primer Flat Blat
Well, most aftermarket bumpers are painted black so standby for incoming!😁 _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Tornado Red |
pdm777 Samba Member
Posted: Fri Jan 07, 2022 3:47 pm Post subject: Re: Fiberglass bumper/cladding repair |
The Factory color for fibreglas bumpers is not black,
Factory bumpers are grey.
and looks awesome.
Rattlecan Black paint
on the rockers is a common
ploy to hide rust.
kamzcab86 Samba Moderator
Posted: Fri Jan 07, 2022 4:27 pm Post subject: Re: Fiberglass bumper/cladding repair |
pdm777 wrote: |
Depends on the model. Most are, in fact, Graphite or Black:
Some special editions are color-matched:
_________________ ~Kamz
2016 Golf GTI S
pdm777 Samba Member
Posted: Fri Jan 07, 2022 5:08 pm Post subject: Re: Fiberglass bumper/cladding repair |
Kamz,
THank You!
Fun to see the variety of colors.
I wonder why some of the
plastic bumpers were grey,
some were black. _________________ 1990 Westy Full Camper |
atarasi Samba Member
Joined: October 19, 2004 Posts: 320 Location: Seattle, WA
Posted: Fri Jan 07, 2022 6:12 pm Post subject: Re: Fiberglass bumper/cladding repair |
I’ve repaired a few fiberglass bumpers. Make sure you use a SMC resin and filler. These bumpers were made with a release agent where regular fiberglass resin won’t stick.
Factory paint color for the bumper is Cloud Gray Metallic LV7N with the center darker color Graphite LH7B |
dart330 Samba Member
Joined: July 19, 2004 Posts: 454 Location: Houston, TX
Posted: Fri Jan 07, 2022 7:29 pm Post subject: Re: Fiberglass bumper/cladding repair |
If anyone knows a source for Cloud Gray Metallic LV7N paint in the USA, there are many people looking for it. Nobody has that color code in their system. _________________ Driving a 90 Carat since 2014
Previous Buses: 59 Westy, 60 Westy, 74 Bus, 82 Westy, 85 Westy, 87 Syncro
Checkout my Syncro Video: https://www.youtube.com/watch?v=0JSWhLS7jLY |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6351 Location: Honolulu,Hawaii and France
Posted: Fri Jan 07, 2022 8:04 pm Post subject: Re: Fiberglass bumper/cladding repair |
pdm777 wrote: |
Kamz,
THank You!
some were black. |
Grey is painted, black is raw. The raw ones turn kinda grey/chalky black with the sun. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
